Question about Mx Max Cn890s Coil Nailer O`ring Parts Kit
Max-CN35041 seal is obsolete -no replacement- (cn565 gun) -any other seals fit, or throw gun away?
    President:
  • Mx Master
  • 1,388 Answers
Do not throw gun away, lots of life left. Most major suppliers say that the part is no longer available but by comparison when GM stopped making pontiac there were still thousands of cars lift in stock at various dealers around the country. Similarly, your cylinder seal is out there in quantity but you will need to contact fastener companies that retail Max nailers. I live in Texas and have contacted Southern Fastening and have been told that they have stock. I am sure that you will find that part in your area. Start by contacting Max dealers in your area and the net. Buy two seals because in the future you may have trouble, however aftermarket dealers will most likely start selling that part. Good luck
Posted on Nov 10, 2010
After waiting for a seal for two weeks from an online supplier, only to find they were unable to get the part and cancelled the order, I then discovered "The New Yooper Workshop". Much about nailers. This website states they have manufactured a replacement seal for the discontinued CN35041 seal . I just ordered one. Here's the site: http://www.airnailerparts.com/servlet/the-1947/Max-CN565-Coil-Nailer/Detail
I'm expecting a perfect fit, I'll let you know if otherwise.
Posted on Apr 17, 2013
I drained the transmission fluid put of my Jeep. I got taken away from it for about 4 days before I could get back to it. I have added fluid back in slowly.
Sounds like maybe the filter isn't seated in the seal or the seal is missing/broken and sucking air into the pump, this would cause bubbles, one way to tell for sure is to overfill the transmission by a couple quarts for testing and see if the bubbles go away.
Jan 03, 2016 | Jeep Cars & Trucks
Need a cylinder seal 41209 central penumatic nail gun
I have used seals from Bostitch framing guns, however you must experiment. Bostitch seal number T60006 has inside diameter (lip of seal) of 1.875" and seal # N70155 measures slightly over 2". The lip should be about even with the bore of cylinder so that the piston will not push it off. If the seal fits a bit loose, you can apply RTV to inside and push on the seal and install the head. The head valve will center the seal while the RTV firms up. Wait 24 hours or longer before use. Small seal will usually not work; will split or fall off inside gun. Finally, I have made seals using hard roller blade wheel on my small lathe. Roller blace wheels are made of material that will work in oil and is about shore 95a hardness. Good luck.
Nov 06, 2012 | Tools & Hardware - Others
Max CN565 main piston is shearing off the new cylinder seal I just installed, causing leak out the back
Cylinder seal for the Max cn565 when installed on the cylinder does not have any overhang into the path of the driver. The seal only comes into contact with headvalve. Seal # cn35041 is hard to find because it is no longer made. If you use a seal from a different gun,be sure seal is about same thickness and no part of the seal is in the path of the driver. The seal should snap into place on cylinder and be difficult to remove. Good luck
Sep 09, 2012 | Mx Max CN445R Coil Nailers
I have a N59 FN air is leaking from the bottom of gun I put ne trigger and O rings still leaking now what.
Air leaking from the bottom of the gun (path of driver) indicates that cylinder seal orings are leaking (if without nails in gun the driver is slowly pushed down the cylinder when air is connected then cylinder seal is leaking ). Cylinder seal snaps on the top of the cylinder and should fit snug and have no cracks. Easy fix for cylinder ring. Remove head and pull out cylinder. Then remove the cylinder ring (part #n50015). Examine ring for cracks and replace as needed. Examine body of gun where spacer oring makes contact and sand fine scratches. Replace orings as needed. If air is leaking between body of the gun and nose casting, replace gaskets. Good luck.
Jun 25, 2012 | Stanley Bostitch Nail Gun
Sns 41 as soon as i connect air hose, driver goes down and air comes out exhaust
May need cylinder seal # bc0438. When this seal fits loose or is cracked, air will leak past and push piston down to bottom of the cylinder. If the seal fits snuggly and looks in good order, suspect headvalve orings and cylinder spacer orings leaking. Order oring kit and seal. Use silicone paste lube on all the orings. Look carefully at the surfaces where orings make contact and remove scratches with 300 grit sandpaper(fine scratches will allow air to leak past new orings). To make the gun work with poor fitting orings. Clean inside of gun with diesel and apply plenty of silicone paste to orings (using same orings if not cut or broken). If gun works as normal, the silicone paste is temporarly sealing the orings. It may continue to work for a while untill you get new parts. Good luck with repair.
Aug 13, 2011 | Senco SNS41 16Ga Stapler 1" 2"
When I connect my Bostitch N12B to air the plunger/driver will activate completely and not retract. It will then cycle in and out about 1/2 inch continuously. This happens regardless of the trigger or...
Air is leaking past the cylinder seal and trigger valve orings are loose. The seal is no longer made by bostitch however the seal from CN55 max nailer will fit. This seal is sold thru some ebay dealers. You could try a trick I use to get more life out of seal. If seal top surface is smooth without cracks, cafefully remove with breaking and clean inside surface of seal and where it sits on cylinder. Apply a light coat of RTV sealant inside of seal and place onto cylinder cleaning off access sealant. Replace head and do not use gun for 24 hours or less depending on required drying time of sealant. The trigger valve is a TVA6 also sold on ebay in a generic form for under 20 dollars. While gun is apart take a look at the upper bumper at center of headvalve. There should be no cracks and it must be flexable. This part will usually turn to wax and crack, if marginal just replace. Good luck
Nov 22, 2010 | Stanley Bostitch N12b Coil Nailer...
I need a part for my max coil nail gun cn555 part # cn35041
try "nailgundepot.com" for the replacement part, let me know if you still have problems finding it.
Sep 21, 2010 | Mx Max Cn890s Coil Nailer O`ring Parts Kit
I have a constant flow of air coming out of the front of the firing nozzle. What is causing this? I have a Bostitch N50FM.
Air leaking from gun where nail is driven out is caused by faulty cylinder seal and /or orings that seal cylinder to body of gun. Remove head and examine cylinder seal that sits on very top of the cylinder, if cracked, damaged or is loose fitting, replace. Pull cylinder from body of gun and remove the plastic ring. Examine ring and replace if cracked. Replace orings that contact ring. Parts are available at www.toolpartsdirect. Good luck
Sep 16, 2010 | Stanley Tools & Hardware - Others
On daisy 200 it has no seal on co2 piercing needle how do i fix this
Doesnt take a seal, it seals it self as it pushed its way into the co2 cyl. the tapper makes the seal, If the gun is leaking, it is the seals inside the gun. no one makes them. the gun is 'unrepaireble'
Aug 21, 2009 | Daisy Toys
Glue Gun Troubleshooting
1. Insert your wax stick into a standard sized glue gun. The fit may be tight. The more wax you use, the smoother the fit. 2. Use a second wax stick in the gun to help advance the first, if needed. 3. Heat the gun up to temperature. 4. Do a few test pulls on the gun to get a feel for the quantity of wax you would like to use with your seal. (Two good pulls of the trigger will produce a full seal for the larger sealing coins.) 5. Wait for 10-15 seconds, then press your seal firmly into the wax before it hardens. 6. Lift the seal slowly off the wax. If it comes away and the wax is still quite soft, wait a little longer before pressing the seal down.
Aug 27, 2008 | 3M 5/8 x 8 - Low-Melt Adhesive Clear
Mx Max Cn890s Coil Nailer O`ring Parts Kit Logo
454 people viewed this question
Top Mx Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Mx Air Tool and Compressor Expert? Answer questions, earn points and help others
