Question about Zhone 6212-I3-200 Router
Alarm light is on how do i fix it - Zhone 6212-I3-200 Router
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
2008 equinox,stabilitrac and traction control lights come what is the simple fix?
run the fault codes to determine the exact sensor that is faulty
Jan 06, 2015 | 2008 Chevrolet Equinox
My ignition switch light stays on and alarm does extra beep when set on. I think it a bypass warning. Now the alarm goes off randomly. I had the headliner redone. Do you think I have a short?
if there is a short in the overhead light it can cause issues with the alarm arming, bring it back to the person that did the liner and have them fix the light.
Sep 26, 2012 | Cars & Trucks
My new Firex 21007581 with a new battery keeps chirping. What is the problem and how do I fix it? Thanks Sal
He said it had a new battery so he already did that and why would you service a $12 throw away smoke alarm? This FIREX he identified is the 4618 and will also chirp while the LED light blinks, chirp is about 30 seconds after blink if the unit itself needs to be replaced because there is something wrong with it as opposed to a different chirp pattern for battieries. If still unerwarrantee FIREX will replace otherwise go buy a new one.
Sep 07, 2011 | Kidde 21007581 120v Firex 4618 Pro Basic...
Alarm went off had to disconnect battery to shut off, door open light stays on, interior light stays on door locks and window controls will not work
O.k. this is a security feature of your alarm the car now essentially thinks that it is being stolen. In order to fix this issue you need to reset the alarm buy reconnecting the battery and using your electronic alarm sensor if you have one (if this doesn't work get new battery for alarm sensor)
Jun 16, 2011 | 2002 Ford F350 Super Duty DRW Reg. Cab
Car alarm indicate led stay on all the time, although the lock and unlock work its a gm vsc3100 alarm system. Any help will be appreciate. Thanks
This is the aftermarket alarm may be time for a new set but before you go that direction the alarm light may have shorted to a power and not affecting the alarm itself by the way does the alarm horn work and is it diconnected because if it is it realy activated. If it isnt and alarm horn works but the light always stays on the the alrm internal relays doesnt switch over. The fix most area will make you get a whole new one
Apr 21, 2011 | Chevrolet S 10 Cars & Trucks
MY FORD ESCORT 1.6 FINESSE 1997 IMOBILISER FAULT
disconnect the battery for 1 minute and try again - ---quick fix possible with that---
if that makes no difference then I would like to know exactly what model of alarm and immobiliser the car has - what is the maker + model no/serialno of the keyfob for the alarm, I can get the info I need off that.
also you can check the fuse in the alarm if you know where the alarm is situated, it will have a fuse either on an inline fulseholder on as a spade fuse stuck into its casing somewhere - replace the fuse if blown and try again to start the car ------------ tell me the model no of your alarm and immobiliser if no joy after battery/fuses and I can read up on them and see if I can fix your problem...
Jan 24, 2010 | 1997 Ford Escort
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
When i lock the doors on a 2002 ford explorer about thirty minutes or so the alarm sounds. even if not activated. the only way it doesnt is when i leave it unlocked. any suggestions?
Check to see if when the alarm goes off if the interior lights are lit. Ford's have a problem at times with the door pinswitch in the door latch leaving the interior lights on, or coming on unexpectedly. Is this a factory installed alarm? WD40 sprayed into the latch will sometimes fix this problem.
Jun 12, 2009 | Code-Alarm Code Alarm Transponder
Zhone 6212-I3-200 Router Logo
222 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
