Question about Canon ImageRunner C-3170U Copier
Canon IR 3180C. Error code E000008-0001.Enter mode service procedure. Tthank you. Vasile Constantin, tedissprest@yahoo.com
  • Canon Expert
  • 242 Answers
Click this link to find the service mode procedure
and here is the service manual:
http://www.4shared.com/file/P_7SU82j/ir3100c-smpart1.html
http://www.4shared.com/file/6X_eK9Cx/ir3100c-smpart2.html
Posted on Nov 17, 2010
    New Friend:
    Problem Solver:
The links you posted are asking for a password.
Can you help me please?
Thank you!
Posted on Dec 09, 2014
Solution off error code 000002 off IR 3245 Canon ?
Hi. That error means there was a temperature error . You need to enter into service mode to clear that error.
with the copier powered on press the next secuence
press adittional function once
press 2 and 8 at the same time once
press adittional function once again.
service mode should appear in the screen. If it doesn't. Repeat the procedure.
with service mode in the screen :
select COPIER.
Select FUNCTION
Select CLEAR
in the list below select ERR and press ok in the lower corner of the screen .
turn off from the main switch of the machine for about 10 seconds.
power on the machine and make some copies .
if problem persist that mean that fixing heater is defective and need to be replaced
Feb 26, 2018 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202
Canon iR2202
Hi
Please follow the below procedure to enter Service Mode
1. In standby mode, press the "Settings/Registration" key.
4. Press the "Settings / Registration" key.
5. The service mode screen is displayed.
Use the "Back" key to exit Service Mode
COPIER> FUNCTION> CLEAR> ERR; and then turn OFF and then ON the power.
Jul 24, 2015 | Canon Office Equipment & Supplies
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
How to remove error code (E000004-0010)from canon iR-6570 photocopier?
gmana ya cara benerin error e000004-0010 pada mesin canon ir6570
Jul 07, 2011 | Canon Office Equipment & Supplies
What does error code E00007-0201 on a cannon c5800 WE cannot get it to clear.
Couldn't find any info on this error code, but did find a procedure that might help you. It's for clearing a Waste Ink Error and might help:
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3)SET ABS-M LEVEL TO 0
4)OK
Here is the whole blog on the problem:
http://www.fixyourownprinter.com/forums/printer/42902
Refer to your manual for the error codes.
If you don't have a manual or service manual, try this link:
https://www.2instructions.com/search.php?cmarque=CANON&modele=IR%20C5800
Good luck, hope this helps
Jul 13, 2010 | Canon Cameras
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
Error code E OOO in canon iR 1600
press * press id (#) then goto service mode 7 sub mode 4 (printer reet) then pres ok key trun off machine on agine it'll be ok now.
Sep 08, 2008 | Office Equipment & Supplies
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
1,425 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
