Question about Panasonic PT-53WX42 53" Rear Projection Television
Convergence problem.... I have the Panasonic PT-53WX42 HDTV Projection Monitor; and have a convergence problem I guess......the problem is that its in a 3D look and gives you a head ache with red hue outlining objects or people......after reading some of other peoples' problems that seemed similar to mine I think all I may need to replace is the- convergence ICS part number STK392-110. So I will need to get two new ones? And where can I find the service specs "free," on how to replace it? Does it just pop in and out? I didn't where it was..... Thank You, Jarrett
  • tarfin Jul 02, 2008
    I have a PT-53wx52f with a similar sounding issue. What model number ICs do you recommend and how difficult is this to fix?
    Glenn
  • tarfin May 11, 2010
    I have a PT - 53wx52f that sems to have the same issues. What model numberICs would you suggest and how difficult is this to fix?
  • Panasonic Master
  • 8,617 Answers
Yes you need two new ICs STK392-110 you can get replacement ICs at the following link and they provide free instalation instructions with pictures so you can do the repair yourself. They also will give free tech support in case you need any additional help installing them.
http://servicemanuals.vstore.ca/
Posted on Jun 23, 2008
Picture out of line Problem with the Panasonic PT-53WX42 53 in. Rear projection. Possible convergence circuit? How do i change it
Picture colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?Yes.The tv convergence board is dead,the board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board.U must have tools like a soldering iron,a desoldering pump or a roll of desoldering braids and also can do soldering work?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit belong to ur tv model and make to repair it ur self.Or the shop will cost u like $300-350 for parts and labors.
Mar 23, 2011 | Panasonic PT-53WX42 53" Rear Projection...
The colors on my tv doesn't line up right. It has a 3D look and i tried to converge it. It will not let me do it. Its a panasonic HDTV PT-47WX42, PT-47WX52, PT-53WX42, PT-53WX52, PT-56WX42, PT-56WX52
set uses two of the STK-392-110 chips for convergence.
Both will have to be replaced.
I have start to finish step by step instructions for this repair based on me doing it in hundreds of these sets.
If you want the instructions, do you have a email?
SD TECH
Jan 15, 2011 | Panasonic PT-47WX42 47" Rear Projection...
Tv wont turn on
You need 2 STK392-110 Convergence ICs and possibly 6 2.2 ohm 2watt resistors. You can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the ICs, resistors and the CD with instructions. The PT47WX42 convergence kit is the correct one for your model.
May 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic 53" tv pt-53wx42
your convergence ic is going bad. remove front and adjust the level of blue.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Same as sleepless14 june 1, 2008 posting. I am getting green and red double lines.
convergence IC failure is the most likely cause. You can get the Panasonic convergence kit #1 at the following link which contains both convergence ICs the six feed resistors and step by step innstructions on how to do the repair.your model uses that same kit Heres alink to the kit.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Mar 06, 2009 | Panasonic PT-53WX42 53" Rear Projection...
I cannot converge the blue on my pt-53wx42
you need two STK392-110 convergence ICs. You can get new ICs at the following link and they give free installation instructions with pictures and also instant messaging with one of their techs while you do the repair. heres their link.
Apr 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT-53WX42
Need to replace the convergence amps and any 2.2 ohm resistors in the return. That unit takes two STK392-110 Sanyo amps - but for greater reliability use STK392-150's and get them, from some place like ACME to be insured their not chineese knock-offs..
Bill
Apr 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
