Question about Tokina 100mm f/2.8 Macro AT-X PRO D for Canon
I have a tokina 100mm macro mounted on a Canon 7D, last night i started getting a ERR O1 communication failure between lens and camera saying to clean the contacts. Its an intermittent issue, at the moment its fine and no error is coming up.
Auto focus failure
My experience with lenses is that they either work or they don't. If it does not work "as you usually used it", then there is a problem inside the lens and not something the average photographer can repair. Lenses are quite fragile, a slight knock on one occasion can damage the inner bits which are very intricate and more so with motorised lenses. I have experienced a battery problem error message through a damaged lens housing and the battery also subsequently got damaged through short circuit inside the lens mechanism. Send it for a check-up and repairs!
Feb 05, 2014 | Tokina 100mm f/2.8 Macro AT-X PRO D for...
Tokina lens problem
Try gently cleaning the contacts between the lens and the camera.
Sep 20, 2017 | Tokina 12-24mm /f4.0 for Canon
Is there an adapter for Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens to fit to panasonic gh2 m4/3?
Perhaps. Tokina makes lenses with a variety of mounts. If the lens already has an m4/3 mount then you won't need an adapter at all. Some Tokina lenses take the "universal" T-mount. In this case remove the current mount and put on an m4/3 mount. If it has some other fixed mount, m4/3 adapters are available for some of them. It all goes back to the mount already on the lens.
Jun 20, 2012 | Tokina Rmc 1 3.5-4.5 35-135mm Zoom Lens...
Hello, I mounted 12-24 mm f4 Tokina lens on my canon 7D, but when I change the aperture from F4 to anything else, I get this error message"camera cannot communicate with the lens, clean lens...
Did you clean the lens contacts with a pencil eraser or with something else? If memory serves F4 is wide open on this lens, right?
Feb 15, 2011 | Cameras
I have a Canon 100mm macro lens used on a Canon EOS 40D Camera. The problem I have is that the images produced seem to be not pin sharp, even when using a tripod and the mirror lockup function on the...
It seems that you have either a faulty lens or one which is performing outside of the minimum quality standards. You have clearly done everything possible to try and eliminate all other causes. Looking at the firmware updates for your camera, none of them mention an issue involving your lens but you may wish to ensure that you have the latest firmware anyway.
All you can do is to contact Canon customer care to request that the lens is exchanged.
Sep 07, 2010 | Canon 100mm f/2.8 Macro USM EF Lens
My Tokina 12-24mm /f4.0 for Canon got a little wet. When attempting to take pictures I get a ERR 01 message in my canon. Got the same error when I attached the lens to a second canon.
One of the internal circuits on the lens got more than a little wet. How long did you let it dry before putting it on the camera (which applies voltage to the possibly still wet circuit and probably shorted it out) ?. It sounds like a trip to Tokina is in order, unless you want to start a career as a repairman yourself
May 27, 2010 | Tokina 12-24mm /f4.0 for Canon
I have a Cosina AF Macro 100mm lens that I used on
you should be able to use that lens with it. As long as it attaches to the SLR body ok. The thing to be aware of is with better technology in the newer camera you may have AF issues with that particular lens.
May 08, 2010 | Canon EOS 400D Digital Camera
Tokina f2.8 100mm macro nikon mount. setting apature and shutter speed. little manual with lens not very informative.
Turn the aperture ring to the smallest aperture (largest f/number) and lock it there. Set the aperture and shutter speed on the camera body. You didn't specify which camera you're using, so I'm afraid I can't give you details there.
You will find all the information in the camera manual, not the lens manual.
Apr 24, 2009 | Tokina AF 100mm f/2.8 Macro Lens for...
Tokina f2.8 100mm macro. setting apature and shutter speed. little manual with lens not very informative.
Minolta Dynax 7D I fined it dificult to auto focus using a 100mm macro lens even with a very sharp subject the lens just keeps running in & out I never had a problem with this & wonder is this a...
I don't know if I can help you. But I will try a guess. Some cameras focus on 1 point and it is not necessary the center. Maybe if you give your camera a point to focus on then keeping your fingers half cocked on the shutter shift the focus off-center to however you want to compose it, then click.
But if it was working properly before and then stopped working properly, did you lend your camera to someone, drop it or subject it to impact? I don't think anything is really wrong but I could be wrong. Have you checked the AF/MF button. Could someone may have accidentally pressed it?
If you are using the macro lens, did you check the camera's distance limits? I understand that the 7D actually focuses faster than the Canon EOS and Pentax. Canon and Pentax need to hunt that's why they take longer.
Jul 22, 2008 | Cameras
Tokina 100mm f/2.8 Macro AT-X PRO D for Canon Logo
101 people viewed this question
Top Tokina Cameras Experts
Harrie
Andrew Taylor
Andrew Taylor
Tony Parsons
Tony Parsons
Are you a Tokina Camera Expert? Answer questions, earn points and help others
