Question about Carrier 38CKC042 Air Conditioner
Squeeling noise coming from AC, compressor is on, fan not turning
I also noticed a loud squeeling sound coming from the AC unit when the AC was running yesterday. Not sure when it started but had turned it on about 1 hour before i heard the noise. Never heard that noise before. I also turned the AC off because it sound like something was wrong. Now, when I turn the AC on I can hear what sounds like the compressor running but fan is not spinning and then the squeeling sound starts. While off, i can spin the fan. If it's a capacitor problem where is it located and is it and easy inexpensive fix. I also reset the circuit breakers and they didn't fix the problem. Any other help would be appreciated. Thanks
I would first make sure there is correct voltage reaching the start capacitor and fan motor before automatically replacing those two parts.
Posted on Jul 06, 2008
    Novelist:
    Champion:
  • 230 Answers
The squealing noise is coming from the compressor. This noise is common when the unit reaches extreamly high pressures. The pressure is most likely high because the fan is not running. Since you can spin the motor it could be that the motor has damaged windings. Leave the unit off until the repairs are made to ensure no further damage to the compressor. You will need a multi meter and some experience reading wiring diagrams to properly diagnose the system. You can perform an amp draw on the motor to see if it is in spec. You can measure the volts to the motor and see if they are in spec. Finally the contactor can be measured with the proper meter to see if it is working properly.
My suggestion is to have the Motor and capacitor both replaced. Also inspect the wiring in the condenser electrical compartment for any signs of damage or burning.
Posted on Jun 25, 2008
Loud squeeling noise. Sounds like a bearing.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 20, 2010 | LG DLG5988 Gas Dryer
My kia spectra was making a loud squeeling noise and it has stopped but now my Air conditioner will not blow cold air ( only blowing warm to room temp. air)...is it my fan belt?
it sounds belt related. i am not sure if this vehicle has a seperate belt for the ac compressor, but if so, it sounds possible that the compressor seized and tore the belt off. have a look
Mar 04, 2010 | 2004 Kia Spectra
Making squeeling noises and center devider is hot
Your condenser fan underneath the unit is probably making the noise and is not turning fast enough. When that fan don't work when the compressor runs you get the heat in the center divider and possible loose cooling efficiency.
Jan 19, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Is my car ok to drive with a broken fan or AC belt?
Open the hood and start the car with the a/c off. Do all the components running on the drive belt seem to be working ok?
Turn on the a/c and check to see if the symptoms repeat themselves...
If with the a/c off everything is ok, then you're probably fine to drive until you can get the a/c unit serviced.
If the symptoms are happening with the ac off, then it could be an idler pulley or a water pump or alternator, or powersteering.
Best bet is to open the hood and do a bit of inspection/investigation with motor running.
Jul 01, 2009 | Honda Civic Cars & Trucks
Outside unit will not operate
Sounds like a bad fan motor. Inside fan runs, compressor runs. Outside fan. Are your contactors pulled in when thermostat set on cool? If not might be a contactor. If contactor not pulled in touch the top of it with the end of a screwdriver. If fan spins turn unit off a buy a contactor...
Tip: Always make sure power at disconnect is off
Jun 10, 2008 | Carrier 38CKC042 Air Conditioner
Squeeled, then hot on exterior
normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Sep 03, 2007 | Whirlpool 26.6 cu. ft. Side-by-Side...
Carrier 38CKC042 Air Conditioner Logo
859 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
