Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
My heater will rub for a minute or so then shut off ,,,unplug it and after a few seconds plug in back in and will run a little while again and help would be appreciated
Sorry, this is not a solution but some advice, Kerosene heaters can give off dangerous fumes if not working correctly, for your own safety you should contact the manufacturer.
Posted on Nov 10, 2010
I have a toastmaster model 2517 space heater. it comes on for a few minutes and then shuts off and then in a few minutes then comes back on. is that normal for that model? if not,how do I fix it?
it sounds like it is turning off when it reaches the temperature setting you have it at. turn it a little higher and see if it stays on longer.
Mar 05, 2015 | Heating & Cooling
Refrigerator will turn on if i unplug it and plug it back it but it shuts off after a few minutes
I have heard of this problem, I have found that the sensor near the ice maker is causing this issue. I can only assume you have a newer model because you didn't leave or insert a model number with your inquiry. I am willing to research this if I can get more information from you if you would like. Get back to me and I would be glad to help.
Thanks
Nov 28, 2013 | Frigidaire Refrigerators
Norelco 8894XL will not take a charge
Sounds like you're getting to the end of your natural battery life. As for replacing the batteries, it's not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
Not being at work, I can't check whether your shaver is a mains/rechargeable, but if you plug it in and it works full power immediately you've got a workaround. I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Apr 15, 2009 | Norelco 8894 XL Electric Shaver
Blinking error codes?
Unplug the machine for 30 minutes , plug it back it, start it for 1 minute, unplug it again for 5 minutes then plug back it and it should work. If not then write back with the error codes so further diagnostics can be done
Apr 08, 2009 | Kenmore 62602 Electric Dryer
All pro 115k
This sounds like you will need to replace the thermostat!
That should fix this common problem!
Dec 20, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Heating & Cooling Logo
69 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
