Question about HP Office Equipment & Supplies
My hp deskjet d2568 printer does not connecting wid pc its connecting cable is ok
SOURCE: printer deskjet 3650
saks
Posted on Jul 10, 2008
SOURCE: HP deskjet 3920
Hi kenjustify!
Let me help you with your concern.
First lets concentrate on your "Cartridge have problem" issue. That message means that the Cartridge of your printer has a problem (Cartridge - is a part of your printer that contains the ink, you may purchase this separately at HP since you have an HP Printer), it may not have enough ink, or its already broken. Both conclusion that i gave needs the cartridge to be replaced. But if the cartridge was newly replaced, you might try reseating the cartridge.
Lastly, on you OFFLINE issue. Just go to "Printers and Faxes" at the Start menu, then double click on your printer inside the Printers and Faxes window, and Click on "Printer" then select "Connect".
Those steps, will definitely solve the issue.
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Posted on Jul 27, 2008
yooperbud
  • 8637 Answers
SOURCE: HP Deskjet 930C USB connection
Yes but you may have to re-install the software for the camera. If so,
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 23, 2009
MUKHTAR
  • 2017 Answers
SOURCE: HP Deskjet 5550 green and amber lights flashing
remove the catridge and see also the steel rod is not dry apply some lubricant oil on the head rod.
Posted on Sep 10, 2009
  • 109 Answers
SOURCE: I cant install the driver of HP Deskjet F2100
Are you trying to use the CD? If so go to HP.com/support and see if there are Windows 7 drivers available for the printer (be sure to note whether you have 32 or 64-bit Windows 7).
Posted on Feb 06, 2010
Hp deskjet f4140
1.Uninstall the installed driver first.
2.Disconnect Data cable from CPU.
3.Then connect the printer with CPU.
4.Turn on the printer.
5.If the PC detect the printer, install it.otherwise check the data cable or ports are ok or not.
Aug 16, 2014 | HP Deskjet F4140 All-in-One Multifuntion...
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
My HP Deskjet printer won't turn on even the power supply is ok.
Loose cables. Ensure all cables are tightly plugged in. If that doesn't help it could be a major hardware failure.
Jul 02, 2010 | HP DeskJet 3745 Printer
Where do I connect the usb cable from my printer to the pc.?
First thing to do install the driver CD of the printer, After the installer searches for the hardware or your printer, plug the printer to the power outlet as well as to the USB port of your PC as shown below, and power on the printer, wait until the installation completed successfully.6278244.jpg
Oct 21, 2009 | HP Deskjet 3845 InkJet Printer
HP Deskjet D1460 I have lost my printer CD
Click the link below to download all the required drivers. You will then be able to install these drivers and use you r printer again:
HP Deskjet D1460 Drivers for Windows XP
HP Deskjet D1460 Drivers for Windows 2000
HP Deskjet D1460 Drivers for Windows Vista
Note: These files are greater than 50 MB.
To install: Remove any old HP Deskjet D1460 drivers and you printer cable from your pc and install the driver first. Connect your printer when the driver software asks you to.
Sep 11, 2009 | HP Office Equipment & Supplies
Printer does not print
The following hints might help:
1. It is better to reinstall the driver (from hp site)
2. Do not on the printer until the usb cable is plug to computer
3. If it happens offen, you need to off the printer using printer switch and not from power source. You may have a habit of unplugging the usb cable without off the printer swich.. this will later lead to switch chip damage.
Apr 17, 2009 | HP DeskJet 3745 Printer
Installation of driver software from web for my printer
Go to this link and enter your model number, which i believe you may want to re-check, because I don't think you have the right one listed.
http://www.hp.com/#Support
Mar 19, 2009 | HP Office Equipment & Supplies
Color ink ceased after 10 copies
i think u are using the introductory cartridge which comes when the printer is new and it only has one forth the ink of original cartridge
Feb 24, 2009 | HP DeskJet F380 All-In-One Printer
Seeker5211
Seeker5211
