Question about Foxconn 661FX7MI-RS (661FX7MIS) Motherboard
My HDD is working fine,tried it with another pc,but when i put it on the board that i use which is foxconn it does not load o.s it displays blank screen and tried to format the drive on the board it takes the whole day untill i cancell it. i suspect the motherboard is faulty, please advise
    President:
  • 1,812 Answers
Did you seen THE HDD in BIOS ? If not please change the id cable or sata cable ,if yes select the hdd from BOOT PIORITY
Posted on Nov 10, 2010
  • richoline Nov 10, 2010
    I already did that and it still does the same thing
  • shiboram sardar
    shiboram sardar Nov 22, 2010
    please download hbcd
    choice any link
    1. (it is better) http://hotfile.com/dl/53375744/8e3594b/H...
    2http://phpfusion.org/software/system/109...
    3http://phpfusion.org/software/system/109...
    4 FROM TORRENT: http://fenopy.com/torrent/hbcd v11 dlc v 1 2/NjI3MTQwMA
    boot from cd >go from dos mode >go hdd tools>go dm>choice your company for hdd>advance>maintence >uttility>zero fil>hit.
    OR create a bootable dm from nerro or download ultimateboot cd http://www.computerbild.de/download/Ulti...
    zerro fil the hdd by ontrack then create a single partion it must be solve your problem
Blank screen
I'll try to help you, but I'd need to ask several questions. Was the pc working before the problem, or is it your first time putting it together. Have you tried connecting just the bare minimum parts like one HDD, one memory, connecting the onboard video etc.. Get back with me as soon as you can.
Mar 02, 2014 | Foxconn A6VMX AM2 Am3 Ddr2 PCI-e Sata2
Just put a computer together with the Foxconn M61PMV board. It loads up with the Foxconn logo, all the parts are in the right places, and it works fine. However, I cannot input at all with a keyboard (USB...
I would assume you've tried different ports and different keyboards.
If you have, I'd contact the reseller and RMA the board.
There's really nothing you can do with a board that won't go into the setup.
Just for kicks, remove the CMOS battery on the board before you email/call the reseller.
Mar 16, 2011 | Foxconn M61PMV Motherboard
No display after restart
bro I am having the same problem!! after searching I found that the pc gets display on my case if I remove power cord and press the power button (and holds on) of pc like 30 seconds and then reconnect the power cord and powers on!! this is how I get back display after restarting pc.
Feb 02, 2010 | Foxconn 45CMX socket LGA775 motherboard...
I lost all conection from mother board (USB2 and
there is a label on the mothereboard on what connector you will put..youll see hdd,pwr something like that
Dec 13, 2009 | Foxconn 865G7MF-SH Motherboard
Foxconn 648fx4mr-es boots up no display
u take M.B outside .then u install cpu , agp, ram , power supply ,finish u running . please u try.
Dec 11, 2009 | Computers & Internet
Pc problem
try to reset the bios,
Jun 16, 2009 | Foxconn (865G7MC-ES) Motherboard
No on board graphics after power up.
there are only a few things i can think of that might help. recheck to make sure all of the power supply cables are plugged in, although im sure that you've allready done that. you don't wan't to clear cmos due to the fact that you only do that if you are going to reflash it. could mke it unbootable. try going in to cmos and enabling quick boot this bypasses POST test and might get you in. also try reinstallling the Operating system as this load drivers for your display. the only other thing is you might have recieved a faulty motherboard, this happens mor frequently than you might think.
hope this helped.
please rate good.
best of luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 02, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
Jun 20, 2008 | Foxconn P9657AA-8KS2H Motherboard
Monitor port not working
ok...let's assume the monitor works, right? got another one around, by chance, an older dell one, maybe?
Feb 18, 2008 | Computers & Internet
Computer won't boot
did you load the raid drivers?
Dec 05, 2007 | ASUS P5LD2 Motherboard
Foxconn 661FX7MI-RS (661FX7MIS) Motherboard Logo
80 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
WTF Chuck.....
WTF Chuck.....
Joe Negus
Joe Negus
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
