Question about ASUS P4S800-MX Motherboard
Where can I obtain a diagram showing the motherboard components & connections?
  • 4,737 Answers
It's clearly mentioned with illustrated pictures (graphics) on the Manual. Here's a screenshot of the front panel :
\You can download the Manual (click here), open the link and click "Download (1MB)" or you can simply read it on your browser.
The motherboard overview layout is on Page #.1.6, you can check out the details about every connection(s) from Page # 1.15 to 1.23.
If you have problem, let me know which exact connectors do you want to connect.
Good luck.
Thanks for using FixYa.
Posted on Nov 10, 2010
Testimonial: "Thankyou for the quick response. The info is just what I need."
Need vacume diagram /routing 1984 B series pick up
We do not have thses diagrams. There is a sticker under the hood that has the routing diagrams.
Sep 27, 2012 | 1987 Mazda B-Series
I need the wiring diagram for emachine t5224 desktop pc
Do a Google search for " emachine t5224 manual", and get one. The manual should contain the wiring diagram showing how all components and cables are connected to the motherboard.
Oct 27, 2010 | Computers & Internet
Motherboard diagram
A Computer Motherboard Diagram motherboard-diagram-01.jpg Once you know what you are looking at, you can recognize the components on any motherboard layout. A computer motherboard diagram is very useful for when you need to replace motherboard, do motherboard upgrades, troubleshoot motherboard, or build your own computer.
  1. PCI Slot - This board has 2 PCI slots. These can be used for components such as Ethernet cards, sound cards, and modems.
  2. PCI-E 16x Slot - There are 2 of them on this motherboard diagram, both are blue. These are used for your graphics card. With two of them onboard, you can run 2 graphics cards in SLI. You would only need this if you are a gamer, or working with high end video / graphics editing. These are the 16x speed versions, which are currently the fastest.
  3. PCI-E 1x Slot - Single slot - In the PCIe 1.x generation, each lane (1x) carries 250 MB/s compared to 133 MB/s for the PCI slots. These can be used for expansion cards such as Sound Cards, or Ethernet Cards.
  4. Northbridge - This is the Northbridge for this motherboard. This allows communication between the CPU and the system memory and PCI-E slots.
  5. ATX 12V 2X and 4 Pin Power Connection Power Connection - This is one of two power connections that supply power to the motherboard. This connection will come from your Power Supply.
  6. CPU-Fan Connection - This is where your CPU fan will connect. Using this connection over one from your power supply will allow the motherboard to control the speed of your fan, based on the CPU temperature.
  7. Socket - This is where your CPU will plug in. The orange bracket that is surrounding it is used for high end heat sinks. It helps to support the weight of the heat sink.
  8. Memory Slots - These are the slots for your RAM. Most boards will have 4 slots, but some will only have 2. The color coding you see on the motherboard diagram is used to match up RAM for Dual-Channel. Using them this way will give your memory a speed boost.
  9. ATX Power Connector - This is the second of two power connections. This is the main power connection for the motherboard, and comes from the Power Supply.
  10. IDE Connection - The IDE (Integrated Drive Electronics) is the connection for your hard drive or CD / DVD drive. Most drives today come with SATA connections, so you may not use this.
  11. Southbridge - This is the controller for components such as the PCI slots, onboard audio, and USB connections.
  12. SATA Connections - These are 4 of the 6 SATA connections on the motherboard. These will be used for hard drives, and CD / DVD drives.
  13. Front Panel Connections - this is where you will hook in the connections from your case. These are mostly the different lights on your case, such as power on, hard drive activity etc.
  14. FDD Connection - The FDD is the Floppy Disk controller. If you have a floppy disk drive in your computer, this is where you will hook it up.
  15. External USB Connections - This is where you will plug in external USB connections for your case or USB bracket.
  16. CMOS battery - This is the motherboard's battery. This is used to allow the CMOS to keep its settings.
May 31, 2010 | E-Machines T2542 PC Desktop
Need ip address for syrens, not sure if i remember right: 192.168.1.1???
Hi Stephan,
the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
Where can I obtain service manual for the Dell A525 computer speakers as I probably have a dry solder joint problem. Require circuit diagram with component layout on PCB. Roger Alban...
Ahh..there is no "service" manual for your computer, but there is an owners manual..it can be downloaded directly from Dells help and support pages
Your best bet would be to find a diagram of the motherboard, but your not likely to find a circuit diagram of the board, that info is usually not released to the general public
Nov 30, 2009 | Dell A525 Computer Speakers
Connection diagram plug the USB ports to the EliteGroup P4S5A/DX+
Here is a link to the manual for your motherboard. It should show you how to connect your usb cables.
Hope this helps.
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=39&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Nov 09, 2009 | EliteGroup P4S5A/DX Motherboard
What is the purpose of the diagram of jumper setting?
The jumper settings (if this is the one you are speaking about) are for clearing the BIOS (times, dates, hardware etc...). The diagram is probably showing the settings on which pins to jump when clearing.
Hope this helps.
Nov 09, 2009 | Intel D865GBF Motherboard
'04 Nissan Sentra S factory installed subwoofer wiring diagram
A FACTORY INSTALLED AMP/SUB WILL BE WIRED INTO THE VEHICLES FACTORY WIRING JUST AS ANY OTHER COMPONENT. YOU WOULD THINK THAT YOU WOULD FIND THICK POWER AND GROUND CABLES ALONG WITH RCA CONNECTIONS AS YOU FIND WITH MOST INSTALLS.NOT THE CASE HERE.YOU MUST FIND THE HARNESS THAT HAS THE POWER AND GROUND CONNECTIONS ALONG WITH THE INPUT WIRES FOR SOUND. YOU MUST OBTAIN A VEHICLE SPECIFIC WIRING DIAGRAM THAT HAS THE WIRING FOR THE SOUND SYSTEM PACKAGE THAT CAME WITH YOUR VEHICLE. YOU MUST THEN WIRE IN THE BLUE REMOTE TURN ON LEAD FROM YOUR UNIT TO TURN THE AMP AND SUB ON WITH YOUR RADIO AND NOT YOUR CAR BATTERY. YOU WILL ALSO NEED TO FEED SOUND TO THE AMP USING ONE OF THE REAR OUTPUTS FROM YOUR RADIO.
Sep 05, 2009 | Car Audio & Video
Where can i get a motherboard connection diagram for rs400a board
Theres things called motherboard maps that show all teh connections and what everything is and where it goes on the motherboard map which is ussually in the manual.
This manual for a pentium 4 intel motherboard shows all the connector and how to connect them in the manual. I do not know what motherboard you have and components but ussually you can go to the manufacturers website and go to product support and find the manual or just do a google search for your motherboard map.
I hope this helps, If you need any more help just post here.
Nov 13, 2008 | Computers & Internet
ASUS P4S800-MX Motherboard Logo
1,130 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
