Question about Dell E176FP 17" LCD Monitor
E176FPb REPLACED C703 AND C704 STILL FAILS DISPLAY AFTER 3 SECONDS POWER LIGHT REMAINS ON
  • 11,361 Answers
You need to find out if you do have 12vdc and 5vdc for the inverter circuits and logic board, I usually repalce the caps in a set not just the bulging one since bad cap can look normal but has high ESR, you need to use low ESR type cap in switching power supply, generic Radio Shack will not work or last very long. I use Panasonic FM/FC series for all my repair works because it has low ESR, 105c and high ripple current and high rated life.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Please post back what you find.
Posted on Nov 10, 2010
Display not available after a few second....i already replaced tl1451acn inverter ic, back light , , ballast capacitor (replaced)...the only one not replaced yet is high voltage transformer (4 pcs), 2...
Replace the high voltage transformer. It is the ballast for the backlight.. If you could pinpoint the one that's overheating then that is the one that needs replacement. Much better if you will replace the four transformer...
Hope that answer your question..
Much appreciated if you could rate this help. thanks.
May 21, 2010 | Dell E176FPB 17" TFT LCD Flat Panel...
I have a dell C521 tower,switch it on but light stays on orange,fans work but it wont switch on.help.
if the light remains Orange, Possible In Standby/Sleep/Hibernate Mode.
Try pressing And Holding The power Button For 4-5 seconds Or more.
If this Fails, remove the power Cable, remove side-panel ( Unless Warranted ) locate the silver cmos battery, on the motherboard. remove the battery for 10 seconds, replace and repower and startup. failing this i,d suspect the ram/memory or cpu.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension C521 PC Desktop
Battery status light remains orange
chance are its not the battery!
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 800,860,2000,2200t,2500,3000,3050,3100,3140,4000,4040,4050 and the 6000t are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it themselves.
you can get it repaired here
or buy the port here
if you need further help, just let me know
Aug 22, 2009 | Magellan RoadMate 800 GPS Receiver
With power on, the back light goes off after 3 seconds
Hi
If the picture remains on the display and just the backlight is gone, then most likely the inverter is bad and would need to be replaced. In this case the screen would be worth the repair, you may take the display to a local repairer to get the inverter replaced.
If you lose picture aswell (if you can't see any picture on the screen even under a flashlight etc) the problem is worse than a inverter board.
the display may not be worth the repair.
If you are in warranty use it.
Thanks and good luck,
Ekse
Aug 14, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Wont come out of standby
The problem is most likely a defective lamp. See your owners manual on lamp replacement as this can be done by the consumer.
Dec 05, 2007 | LG RU-44SZ51D 44" Rear Projection...
Oasis - DU and LF error codes
Ky, see if you can put the machine in the service mode by doing this: turn the washer on, select any one button except for power,start and stop. press and hold it for 3 seconds--release for 3 seconds--press and hold for 3 seconds--release for 3 seconds--press and hold for 3 seconds....if you entered it correctly all the indicators will light for 5 seconds and 88 will show in the 2 digit display..It will now go into a automatic test cycle. If no faults are found it should unlock the top. This auto test will go through c0 to c9, you will see it in the display. If this all fails, you can access your wash by pushing in the clips on the left and right side front of the washer lid. The whole top will lift up. I would still call for service while it's under warranty. Catriver...post back.
Sep 11, 2006 | Kenmore Oasis HE 27082 Top Load Washer
Dell E176FP 17" LCD Monitor Logo
197 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
