Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Error code C2801 Bizhub C500 (started with continous paper jams then completely stopped copying )
SOURCE: hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Posted on Nov 09, 2008
  • 3 Answers
SOURCE: canon ip1880 continous paper jam error on screen
first you turn off your p.
Posted on Mar 26, 2009
  • 26 Answers
SOURCE: HP Officejet Pro L7780 constantly gives false"paper jam" error
Step 1:
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. The unit must be powered down and the power cord unplugged before cleaning the rollers. This will allow the rollers to be turned by hand in most cases. The paper should also be removed before cleaning the rollers.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the unit and check the four small metal paper rollers (not the rubber rollers) in the interior of the unit. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the unit and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
Step 2:
==== Partial Reset ====
Press and hold # and 3 button on the unit while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+) instead of #.
==== Semi Full Reset ====
Press and hold # and 6 button on the unit while plugging in the power cord.
NOTE: For models that are not fax capable, press plus (+) instead of #.
==== NVM RAM Reset ====
Press and hold OK and Cancel button while plugging in the power cord
Posted on May 19, 2009
SOURCE: x215 continously displays paperjam 1, there is no paper jam,
I didn't have this exact problem, mine was a paper jam 0 error. The problem was caused by a spring that got old ended using one out of a retractable ink pen. Once you take the four screws out that hold the back plate on and remove it. When facing the front of the printer the left side where the handle is will push back and top can be pulled down to remove. Be careful this is where the speaker is located. The speaker is connected by a six inch wire that can be easily unplugged. Facing the side of printer that was just removed is a plate with 5 or 6 numbered screws only remove the ones that are numbered. This is the drive system for the paper tray and out feed. My problem was the cam gear located to the right of the plate that was just removed. It is like two gears made as one with a spring in the middle and two coils used as a brake for the in feed. I did notice on the left side of the drive system was a light that is used for paper detection pointing towards a photo eye. Most likely that light has burned out for you. There is a side diagram located at http://support.lexmark.com:80/perl/support/support.cgi?relevance=&ccs=229:1:0:393:0:0&mode=DOCS&doctype=topdoc&term=&docid=ENUS20058
Posted on Apr 02, 2009
SOURCE: error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Posted on Aug 23, 2009
Bizhub 420 is showing me a C2801 code please help if u have an idea.
Please explain as per documentation what is C2801 error code I can help you
Jun 29, 2015 | Office Equipment & Supplies
Error code 6508
Could not find a Error code c-6508. But I did find a paper jam 65-08. Check you document feeder there is a jam paper or sensor problem (PS302).
Mar 23, 2015 | Konica Minolta Bizhub C 6501 Color...
C2801 bizhub 750
Sir/Mam,
There is a sensor that monitor the drum some times it gets cover with toner and can not do its job of monitoring the drum which it has to do before copying/printing Sometimes you may also get "please wait" same problem. Have to remove the drum assy. Two bolts and center bolt. Then pull out assy. BE CAREFUL DONT NIC THE DRUM!!!! Then you remove the drum and clean the sensor. (Two sensors the white covered one, clear one is for paper jams) When was the last time a 250,000 copy Preventive maintenance kit was installed? and Drum replaced at 500,000 developer also replaced at 250,000 copies/prints. every 250K PM kit install.
May 10, 2013 | Konica Minolta Konica 600/750 Mount Kit...
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Error code 29-16 on minolta bizhub pro c500
connect your printer us b cable again to computer.
also check there is not any paper jam on printer.
also refix cartidgev again.if problem remains check u installed driver properly.download driver from here and remove first old driver then install printer driver from here.
press power buttton for 10 seconds.also refix your ram after clean dust from it.
Nov 27, 2008 | Office Equipment & Supplies
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
582 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
