Question about Tools & Hardware - Others
Use Hot Air Gun / Blower for Removal of SMD IC's without damaging the ICs and the Boards We represent STEINEL from Germany for their Hot Air Heat Guns useful for various applications. Microprocessor-controlled, high-end heat gun with temperature control, LCD display and cold air stage for Removal of SMD ICâ??s & PTH Componets / Microprocessors of Mini Systems, Mobile Phones, CTV, LCD TV, or any other electronic Chassis is difficult using our Normal Soldering Irons. Hot Air Gun is useful to facilitate easy rework without damaging the ICs and the Boards. For more details please write to us and we will be happy to assist you. Board: 022-26731904 / 26731052 Ext # 35 Fax: 022-26731901 Email: hamir.charania@pammvi.com Corporate Web: http://www.pammvi.com Heat Shrink Gun Web: http://www.heatshrinkgunsindia.com/ Plastic Welding Gun Web: http://www.hotairgun-heatguns.com/
  • hamir_charan Nov 12, 2010
    Apart from above there many other applications like:
    1. Removal of SMD Components and Dualin IC's through Printed Through Hole Circuits (which otherwise would be difficult without the expensive De-soldering Stations, SMD Rework Stations).
    2. Removal of small particles that get stuck in the small holes, while removing Dualin IC's through Printed through hole Circuits.
    3. Removal of SMD IC's specially Micro Processor for System etc.
    4. Removal of moisture on the PCB's can also be done with the Steinel Hot Air Gun.
    5. Shrink Sleeving and Shrink Tubing.
    6. Softening of Wires in Motors during repairs.
    7. Drying of Adhesives / Filters / Activating Emulsions etc.
    8. Several other applications where flameless heat is required.
    Applications in Refrigerators / Washing Machines / Air-conditions
    1. Alignment of Gaskets in the Refrigerators.
    2. To Smoothen the Doors of the Refrigerators.
    3. To Remove White Marks in HIP Blow Moulded Sheets.
    4. To Remove Moisture.
    5. For drying of metallic parts after washing in water jet
    Web:http://www.pammvi.com
    New Web:http://www.heatshrinkgunsindia.com/
4 Suggested Answers
  • 2712 Answers
SOURCE: Heat Guns Troubleshooting
Uses for the heat gun include: * drying paint or varnish - 30 to 130 °C - care has to be taken as dust particles may be blown onto the paint/varnish. * drying out damp wood (before filling or painting) - around 100 to 200°C. * softening adhesive (such as when applying worktop edge trim or lifting floor tiles) - 300 to 400°C. * bending plastic pipes - 200 to 300°C. * heat-shrinking plastic film - 200 to 300°C. * welding some plastics - 330 to 400°C.
Posted on Aug 27, 2008
  • 1509 Answers
SOURCE: Milwaukee 8977 - 20 Variable Temperature Heat Gun
With out the thing plugged in with an OHM meter the heting element can be checked with the nose removed. Most of the time once the nose is removed the problem is easy to see the end is burnt off the element connection. Remake the connection reinstall the nose and test. The heating element runns right off the switch and the connection there is easy to see with the handle opened. This is simple unit and wires burnt off from being too hot is almost always the problem. look it over carfully and the problem will be seen.
Posted on Apr 21, 2010
  • 30 Answers
SOURCE: hi my heat gun has
Either the thermostat or heating element is bad.
Posted on Jan 30, 2011
Phone shows no sim card inserted
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Dec 02, 2012 | Nokia Classic 2700 Cell Phone
The mobile works normally without SIM card
First All Check:
Last Option:
Nov 10, 2012 | Nokia 5800 XpressMusic Smartphone
Insat sim
First All Check:
Last Option:
Sep 19, 2012 | Samsung star II duos GT-C6712
B319 sim ic jumper images
First All Check:
Last Option:
Jul 19, 2012 | Samsung Cell Phones
Heating problems of set
Pratap, it sounds me water damage problem,if you are not Technitian dont try this please.give some oficial repairer.this is a hardware problem and probably problem is with PA Network IC or/and Avilma, 1.First clean board with Alcool2. after this let it dry completely then apply paste in ICs and rehot to 310 to 375c up to 12min with Hot air gun, make sure ic's and board's doesnt move on the place during process.3. after this leave board to 15 min for come to normal temperature.4. then try to charge and use to check if solved (90% of cases it solved) other 10% possibility of camera flat cable damaged cause the same problem. so Best Of Luck.
Jun 29, 2012 | Sony Ericsson K850i Mobile Phone
My question is why the Sony when I switched on with a cd inside, it show me reading and a few seconds after ,it will turn off displays PROTECT
hi,
You have to check your system after removing all the speaker. If it shows protection then also then any one the audio outpout ic insid the player is faulty. If it work without showing protection then there will be some problem with the speaker.you hve to find out which speaker is faulty by conneting one by one. If the output ic of the system is faulty then you have to consult some electronic repiaring shope. Because to replace there ics you need SMD rework soldering station. All the audio output ics in your palyer is SMD (surface ***** device). Also need a good skill in electronics to replace these SMD ics
ok
Aug 06, 2011 | Sony DAV-FC9 System
Why does my system say protect when i turn it on?
Possible that the output section is SHORTED and so the power is cut off to protect from further damage. This is due to the fact that the stage consumes more current than requried due to a damaged component. So check the output drivers/IC, remove the speakers and check in case the speakers are damaged.
Feb 10, 2011 | Samsung HT-Z310T Theater System
Tools & Hardware - Others Logo
370 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
