Question about Monster Cable Monster 300 Digicap Stiffening Capacitor
I cant get no power to my cap how do i hook it up
    Sniper:
  • 58 Answers
There sould be two post one for a positive and one for a ground, connect the wire from your battery to the positive, then run another wire from the cap to the amp. For the ground run a wire from your car body (the shorter the better) to the ground post on the cap, then you can run a ground from the cap to your amp OR you can run a ground from the car body to the amp (whichever may be easier for you) Remember to disconnect the ground from your battery before wiring, this will help prevent arching wires and damage to your system.
Hope this helps.
Posted on Nov 10, 2010
My battery is dead,cant get into truck
I would try crawling under vehicle and hooking red jumper cable to big copper stud on starter where the battery cable hooks up, hook the black cable to the frame and hook the other ends up to another vehicle like you were jumping it off. And it should feed the battery with enough power to get the doors open to get the hood up. Good Luck
Jul 04, 2012 | 2004 Lincoln Navigator
I have a 1200 watt amp and 2 12 in pioneer champions and it keeps killing my battery how do I hook up this capasitor I just bought?
first make sure your power wire is directly hooked to the battery, {make sure ure in line fuse is pulled} power wire that goes to positive of power cap , ground wire is grounded to chasis, now attach aditional power wire to amp and aditonal grond to amp . make sure all conections are solid and tight { also make sure inside of power cap is tight as well after long periods of time the insides loosen } i have 2 -1,000 watt sony xploid amps and 2- 1,200 watt sony expoid subs and they pound hard . i probley should have 2-1.2 farrid caps for what i have but it seems that its holding its own
Dec 04, 2010 | Metra Tsunami 1.2 Farad Capacitor
Describe how to connect a scosche 500k micro farad
Put the capactior in parallel with your battery right before the amplifier. So Postive lead of cap to your 12 Volt line and negative lead goes to ground. It is also suggested that you charge the cap before placing it directly in parallel with the 12 volt rail. yo ucan do this by using a 1000 ohm resistor with a power rating of 1 watt. Disconnect your amplifiers so it is just your cap and battery. Replace the fuse with the 1000 ohm resistor. Once the resistor is in place hook up your cap. It will take a little bit for it to charge. RC time constant is T = Reistance X Capacitance. So 1000 ohms X .5 Farads = is about 8 minutes, or you can just measure the voltage with an volt meter and when the cap reads 12VDC you can then hook it up. BE CAREFUL NOT TO SHORT TERMINALS. THIS CAPACITOR I STORING A LOT OF CHARGE.
Jan 26, 2010 | Car Audio & Video
25 farad cap slowly losing its charg if the car sits for to long
Cap is hooked up wrong, should shut off after a certain amount of time and reactivate with the ignition hot wire. If it's draining your battery continuously then you should look at the wiring.
Dec 24, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
How do I hook up a Nitro capacitor?
the cap will connect "between" the main power/gound leads and the amp. If your amp is currently hooked disconnect the power (be sure to disconnect from battery first) and ground leads from amp. Place ring terminals on both leads (red + black - ) and connect to the appropriate terminals on the cap. Then place another wire from the appropriate terminals on the cap to the power connections on the amp.
Oct 28, 2009 | Car Audio & Video
I cant remember where my leeds go on my distributor cap
how many cylinders? for 4 the firing order is 1342 for example--if you have 6 or 8 lookit up on the net and you will find the firing order and then just count round the distibutor and hook up accordingly--modern cars don't have this issue--no distributor.
Jul 11, 2009 | 1983 Ford Fairmont
Cant get picture when hooking a video player to my 37 inch protro
Hi!
First I would rule out the power supply, a quick way to do this is to visually look for any bad caps (Capacitors), that are bulging on top and or leaky (brownish stain). I would say you need a new signal board as this processes the video to the lcd controller. This can fail, an yet still pass the audio! Now this may be part of the main board, in which case you would need this!!
Feb 16, 2009 | Protron PLTV-32 Television
Lanzar viberant 5.0 farad cap
Both "+" connections on the cap are tied together within the cap, as are both "-" connections. Lanzar provides two sets to allow the cap to be more easily shared between the power/ground lines of two amplifiers. If you have only one amp, connecting to one or both of the +/- sets should not matter (although connecting to both +/- sets might reduce the resistance between the cap and the power wiring of your amp).
Feb 16, 2008 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Dell 5100 laptop
if you can hear the one beep sound when booting that means your laptop's system is in good condition. try putting it in the external monitor if still you cant see anything both in external and the LCD just install the old keyboard and press the Fn then external monitor... hope this helps...
Jan 20, 2008 | Acer Aspire 3610 Notebook
Monster Cable Monster 300 Digicap Stiffening Capacitor   Logo
202 people viewed this question
Top Monster Cable Car Audio & Video Experts
xxxxxx xxx
Are you a Monster Cable Car Audio and Video Expert? Answer questions, earn points and help others
