My pass word is not working - Computers & Internet
  • 1,719 Answers
U may have forgotten the password.
1. Try default password, which for most routers is admin.
Or if it doesnt work then,
2. ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory setting from the reset button on the back side of the router. use a paper pin to press the button for few seconds, the lights on the from would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...
CreativeTECH
Posted on Nov 10, 2010
How r15 radiator works
r15 radiator works under the same principle as most systems work in regards to radiators, water is pumped throughout the bikes cooling system that is under pressure so it can pass through the system in a circular method this means that the water passes over parts of the motor that have a heat build up due to combustion and is then passed through the radiator which is getting cooled by fresh air either by the bikes fans or the movement going forward that forces cool air to flow over the radiator and cooling down the hot water that can then get recycled and pass over the parts of your motor dispersing the heat back to the radiator for cooling , this heat transfer was done by the motor having fins built into its shape therefore the passing air would pass through and around the fins taking much of the heat with it, but most modern motorcycles use a radiator much the same way as a car does .
Nov 29, 2013 | Yamaha YZF-R15 Motorcycles
High beam passing lights
Hi Razorsedgesf, sounds like you have a faulty high beam element in your headlite bulb. Your passing lamps are suppose to turn off when your high beam is activated so as not to blind oncoming traffic. Good luck
Dec 28, 2012 | 2007 Harley Davidson FLHRC Road King...
Short circuit in Stratoliner passing lamps
Hi, Doug you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away from the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable free downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Need help passing lamp probs
passing lights
Yamaha XV19SX Service Manual
OEM parts for Yamaha
Yamaha STAR XV19CSX Owner Manual
Jul 30, 2012 | 2009 Yamaha Stratoliner
MY EMAIL AND PASS WORD ALL OF A SUDDEN DOES NOT WORK
My email adress and pass word no longer open my mail it j
Nov 25, 2011 | Yahoo Computers & Internet
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw] Receiving response... [FAILED] *** ...
sometimes YM is very busy for connecting people..that is why you are unable to connect but try reconnecting again...it works
be sure your password and username is correct and your internet connection is stable...
Jun 27, 2011 | Yahoo Messenger
I have 2005 softail as listed,was bought used,someone replaced front forks due to being in accident.the only thing not working is front running and turn signal lights. Passing lights work,headlight works....
No, the TSM does not have this function in it. It controls nothing but the turn signals. Whoever wired the passing lights in used the wire for the high beam light as a power wire for the passing lights. This was probably done so that they would not overload the charging system. If you have the high beam light and the passing lights on, it's a tremendous draw on the charging system and it may have caused a fuse to blow. So, they probably wired the passing lights to operate without the high beam light. I think the wire is white for the high beam.
Good Luck
Steve
Apr 11, 2011 | Harley Davidson FLSTC - FLSTCI Heritage...
Dryer does not dry clothes in 1 pass. Usually takes about 3 passes before clothes dry up.
  • heater not working...do the clothes get hot?
  • fan not working....no air flow.
  • identify this and then attack the one that does not pass the test
  • http://www.appliances.cjb.net
Jan 22, 2011 | Dryers
Plz tell me the flatbed scanner or pass through scanner is same type or different?
They are different.
A flatbed scanner works like the usual scanners you see - you put a document on a flat surface area and have it covered. Canon Lide is an example.
A pass through scanner works like the usual fax machine system wherein you will have the document to be scanned feed, and as it passes though the imaging part of the machine, it's digital copy is generated.
There are machines that works as both - Brother 185c and Samsung SCX4521F are examples of both flatbed and pass through scanners.
Jul 31, 2010 | Kodak i1220 Pass-Through Scanner
Computers & Internet Logo
David Payne
David Payne
