Question about D-Link DI-704P Router
Vonage does not work with D-Link router
Hi, i hope you can help me. i connected my vonage phone to D-Link 704P router. i know router is working because i can access the internet. problem is, the vonage power led is still blinking. i read from other IT forums that when the power Led of the phone adapter is blinking, it means it does not recognize the IP address. How do i solve this?
many thanks,
say
  • midge1125 Feb 23, 2009
    Vonage and my d-link router. Just tried to hook up and vonage power light only blinks. no dial tone either . Tech support on hold for hours and they simply hang up.does anyone know what to do?
    thanks
    Lisa
Please provide more details to your network setup.
Which vonage device you are refering to when you say VOnage phone?
Regards.
Posted on Jan 14, 2009
    President:
  • 623 Answers
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Posted on Dec 29, 2008
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
My Belkin F7D4302 router will not work with my vonage. I have a clearwire modem. If I hook modem into my my vonage first then to my router, my router does not connect to internet but my vonage does, If I...
It should work with the Vonage hooked into the WAN port of the modem, then the router plugged into the router. I had same issue with a Belkin router. Vonage Customer Service will help you at all hours: 1-VONAGE-HELP (1-866-243-4357)
24 hours a day, 7 days a week If you are calling to speak to our technical support team, please make sure you are near the Vonage phone adapter you are calling about and at the location where you intend to use your Vonage service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 20, 2011 | Belkin Computers & Internet
HOW DO I HAVE TO CONNECT THE D-LINK TO VONAGE
1. plug one end of the cable into the vonage phone. 2. Plug the other end of the cable into a numbered port on the router. Any number will do.
Jan 03, 2010 | D-Link Vonage-enabled Wireless Router...
How should the D-link be setup to work with comcast and vonage? After I set vonage or internet do not work. I tried the comcast modem to d-link and d-link to vonage.
If you want to RECEIVE telephone-calls:
COMCAST ADSL/CABLE modem <---> VONAGE <---> wireless-router
Turn each piece off.
Turn on the COMCAST modem, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the VONAGE router, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the D-link router, and wait for its lamps to settle-down to a "steady" pattern.
Restart the computer that is connected to the D-link router,
and you should have Internet access.
Dec 01, 2009 | D-Link Vonage-enabled Wireless Router...
I have Vonage phone, and TimeWarner cable. My
Remove your router for the vonage equipment. Direct connect to modem. Does your internet ****? If yes its TW issue. If no its Vonage issue. Try it for a day
Hope this helps!
john
Oct 03, 2009 | Computers & Internet
Vonage told me to install my D-Link router between the vonage adapter and the computer and I don't know how or which wires go into which ports.
First of all: it would be good to know which vonage device you are using. This would help to be more specific.
But anyways:
  1. Connect a normal Ethernet cable form your DSL or Cable modem to the Internet (or WAN) port of your vonage router.
  2. Then connect another Ethernet cable from one of the LAN ports of the vonage device to the Internet (or WAN) port of you D-Link (The one that is separated from the 4 LAN ports.)
  3. Make sure that the D-Link is set to DHCP (Dynamic IP Address), so it can get it's IP address from the vonage router. (Look at page 14 of your manual. If you don't have one, you can get it here.)
  4. Connect your computer to one of the LAN ports on the D-Link.
If you have any more questions or this desciption is not clear to you, just come back here and leave a comment - I'm happy to help.
May 18, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Having difficulty installing DL 624 with vonage
On my Vonage setup, I had to hook the Vonage unit's blue port to the Cable modem, then connect the router to the Vonage's yellow port.
For some reason, the router would not assign an IP to the router the other way.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Need to connect directv from hard line to vonage.
I had vonage with dish network and was able to buy a phonex system for wireless connection. Worked great.
Mar 22, 2009 | D-Link Vonage-enabled Wireless Router...
Help!!!
Do you have the Vonage in front... or behind the router?
Behind: http://www.vonage.com/support.php?article=88
In front: http://www.vonage.com/support.php?article=1154
Also may need to log into your Router and setup port forwarding
http://www.vonage.com/support.php?article=1098&topic=20
Need more help.. let us know.
www.techvisitor.com
Jul 06, 2008 | Arris Wireless G Broadband Router (wr850g)
D-Link DI-704P Router Logo
671 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
