Call sawgrass tech support for the reset.... it is straight forward and easy to follow. As per customer support, you will need better than 20% full cartridges, they recommend new ones, which they will provide overnight free if still warranted.(ERR28212) As discussed, here are the reset instructions.
1. Turn the printer
off.
2. Open the cartridge door
and leave it open until step 15.
3. Turn the printer back
on.
[img id="Picture_x0020_1" alt="3110 Panel" src="file:///C:/Documents%20and%20Settings/Nancy%20Smith/Local%20Settings/Application%20Data/IM/Runtime/Message/%7B944CD05A-8C76-404B-84B9-E5D3FB8CED31%7D/Show/image0011.jpg" width="500" height="143"> (was a photo of machine front, the down button is also "menu") 4.Hold down both the
Up
& Down arrows together
for 3 to 5 seconds (nothing on the LCD display will indicate the appropriate
amount of time has passed)
5.Release the arrow
buttons and press
#Enter (if nothing happens, try again)
6.When successful the
LCD will display SYSTEMver with 3
optional menu selections starting with Service
Menu
7.Press the down
arrow once to Engine
Maint. and press #Enter
8.The LCD will
display SP
No. with the default 1000000
underneath 9.Using the
Up
& Down arrows, and
pressing #Enter after each
number, enter 3009002. Press #Enter when
complete. 10.CARRIAGE CHANGE
3009002 will display on
the LCD. Press #Enter. 11.CARRIAGE CHANGE
EXEC
will display on LCD. Press #Enter. 12.OK? will display on
the LCD Press #Enter. 13.Then Running
will flash on the LCD panel before going back toCARRIAGE CHANGE EXEC.
Continue to
next step.
14.Exit the SP mode by
pressing the Escape button
repeatedly until you are back at the Engine Maint.
screen. Press the down arrow once to
End.
Press #Enter one more time
to completely exit.
15.Turn the printer
off.
16.Replace the four
ink cartridges with new ones.
17.After the new
cartridges have been installed, close the right front
cover.
18.Turn the printer
on.
19.Wait for the
machine to fill go through an initialization procedure which may take about 7
minutes. This 100% worked for me.... be certain that the screen displays EXACTLY what the directions tell you!! -NSmith
Hello! This code is related to a Fusing temperature error. You probably need to change Hot roller (or fusing roller), Pressure Roller and both thermistors. You can reset this code but it will pop-up again sooner or later. The best advise i can give you is to call a technician (if you do not have technical knowledge) If you still want to reset the code try this: Press yellow key Press in the key pad 107 Press red key at least 5 sec. Press "copy SP" On the key pas press 5810 and #. On the touch panel press "execute" Exit all the way out. Turn the machine off and on.
you will see a button with [/123] in the upper part of the control panel, press the button and on the lCD screen will appear (counter) press the left arrow next to the LCD screen until on the LCD screen appear [sprache] or [language] оr [langue] this depend on which language is current when this will appear press the OK button and select the lenguage which you want to use by pressing the OK button. To exit this mode press the [/123] button.
its temp. or fixing error. try to clear it in service mode. yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
