Question about Sony Vaio S150P (VGNS150P) PC Notebook
My laptop lcd issue
Thank you for your response to my problem! I have a bit more information this time. After starting it and turning it off several times, it finally started up. The LCD display seems to be fine.
So the pc finally starts up, but, it freezes up very often. I'm not referring to the type of freeze up associated with viruses and spyware. It seems as if the pc actually crashes. If I turn it off and turn it back on, it will still sometimes not display anything on the screen (by the way, when nothing is displayed on the screen, the pc does not boot up). The times that it DOES display something on the screen and starts to boot successfully, it ALWAYS freezes up at one point. It freezes up even in the middle of booting windows.
I also noticed the bottom of the laptop is VERY hot, so I'm thinking it could be constantly over heating (but I can hear the fan is working), do you think that could be the issue?
  • 38 Answers
SOURCE: Sony Vaio VGN-N250E/W Not Booting/Responding
Take the battery and power supply out and hold down the power button for 30 seconds. This will reset your hardware settings. Your backup battery isnt your problem. Does your battery light turn on when charging? Does your keyboard lights light up when it runs for a second (try pressing caps lock)?
Posted on Mar 25, 2009
  • 24 Answers
SOURCE: my sister's pcg-frv25 has a VERY weird problem.
you might be having hard drive problems, press f2 and make sure the hard drive is showing up ok. if it is then press f8 when booting select safe mode. if it comes up fully then go to the start menu, help and support and select system restore. select a date 1 week prior to the problem.
Posted on Jul 15, 2009
  • 51 Answers
SOURCE: display flickers on boot. then goes black
Before making any decision on whether it's a hardware failure, please try and boot from a CD or DVD (recovery disc). If it does successfully boot from an external disc - and there is no flickering problem, then the hardware parts are okay. In that case, please go to this link: http://lifehacker.com/5413223/how-to-fix-your-relatives-terrible-computer?skyline=true&s=x for more information on what to do when you can't enter into your operating system and how to fix malwares that might be causing the flickering. If you find my ideas satisfactory, please do rate me. Thanks
Posted on Jan 23, 2010
Testimonial: "same problem when CD boot. How can I decide whether it's the LCD screen or some internal circuitry?"
techresolve
  • 109 Answers
SOURCE: LCD Display not working correctly
LCD problem, u have to replace or repair the screen of your laptop
Posted on Apr 13, 2010
madhatter639
  • 260 Answers
SOURCE: sony vaio vgn-fs8900p isn't booting
Most likely your hard drive has gone bad. It could be your RAM too. I know that you said you checked your ram one stick at a time. What if both sticks are bad? I would get some cheap (low MBs) sticks of ram that are compatible with your computer to see if your computer will start to run right with those in.
Posted on May 20, 2010
My laptop after beeing in ibernation can't wake up. The hard drive starts for 2 seconds and stucks. On the screen there is only a dash that disappear afte a bit of time. Some suggestion, please! Is it...
when you start it up hit the f8 key a few times right away and it should bring up your boot options page and chose your method for start up start in safe mode to keep options down to a min. and it will only load mandatory winsys drivers and soft weare. good luck
Sep 26, 2013 | Acer ASPIRE 8935G-904G100BN LAPTOP LCD...
Why is my acer aspire 5050-5459 continuously restating I can't do anything because when I do it restarts.
The default is for automatic restarts which does not let you see the error message.
  • Power off your computer,
  • turn it on;
  • immediately hit F8 several times a SECOND;
  • You'll get a screen that will have a number of options, one of which is turn off automatic restart. Check that.
  • Now you will get a "blue screen" message that will help diagnose the real problem.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Oct 12, 2011 | Acer Aspire 5050-3242 Notebook
Disabling restart on failure for presario sr2011wm
The default is for automatic restarts which does not let you see the error message. Power off your computer, turn it on; immediately hit F8 several times a SECOND; You'll get a screen that will have a number of options, one of which is turn off automatic restart. Check that.
Sep 28, 2011 | Computers & Internet
Disabling reboot on failure
Your response is very much appreciated. Thank you for using Fixya... Hope this information will help.
My laptop will not start up it keeps going to a black screen with the cursor how do i fix it?
Several things could be happening here
1. failing Video card
2. Broken/ loose video cable
3. failing hard drive
Please provide more information as to you issue such as :
a. You have checked the user manual 1st.
b. Have you contacted the manufacture for support.
Please give detailed information as to your issue to better assist you in your resolution of the problem you are having.The more information given will help determine the resolution and guide you to the proper fix for your issue.
Thank you.
Jun 17, 2011 | Everex StepNote VA4103M Notebook
Sahara n3156 network driver
In order for me to trouble shoot your issue I am going to have to see your System Information
If you do not know to find and tell me your system information follow the steps that I will give you to locate it.
Steps
Windows XP and Vista
  1. Click "Start" on the Taskbar
  2. Go to "All Programs".
  3. Go to "Accessories".
  4. Go to "System Tools".
  5. Click "System Information".
Windows 7
  1. Click "Start" on the Taskbar.
  2. Click on Control Panel.
  3. Click on System.
Once you have located the System Information, you will have to copy and pate it into the response box, so I can be of further assistance. I should have the Network driver for you in no time, and you will be able to be on the internet once again.
Thank you for your assistance
Mar 16, 2011 | Computers & Internet
I have a problem with my laptop: when i turn on
The video information to the LCD screen is lost. This can be a faulty video cable/connector or a faulty LCD screen.
The graphics card on the Acer is OK, that is why when you connect a LCD monitor to the video port on the Acer you see the normal Windows images.
Try re-seating the video cable connector on the motherboard.
If this doesn't fix your then the LCD screen is faulty.
Replacement screen are available on the Internet. Try this company for replacement screen.
www.lcdparts.net
May 25, 2010 | Computers & Internet
Dell latitude D600 display blacks out, showing just a ghost image
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 21, 2009 | Dell Latitude D600 Notebook
Screen is Black even when the machine is on
Good day,
since you can still hear that your laptop is starting, the system is still fine, hence, we can isolate the problem to several causes that would make your screen turn black, it might be due to a loose connection between the video card and your screen, the cable connection to your screen, or your screen might be busted already.
if you are the techie type of gal, you can dismantle your laptop yourself and isolate the problem. be sure that the warranty is already expired since you will automatically void the warranty if you open your laptop yourself. however, i suggest that you contact a competent technician to check the problem as it might also include other problems that might have caused the black screen (software driver for your video card perhaps).
i hope this will help
Oct 13, 2008 | Toshiba Satellite A105-S4004 Notebook
Sony Vaio S150P (VGNS150P) PC Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
