How can I remove the thermostat cover from a radiator?
  • Heating & Co... Master
  • 2,557 Answers
Some have allen key you undo or a screw on the side or they un screw
Posted on Nov 11, 2010
Engine Diagrams
Hello. Here a non-photo diagram. Hope this helps!!!
The thermostat is located on the side of the water pump, the water pump is located just above the a/c compressor, the thermostat is fed coolant from the radiators lower radiator hose.
Thermostat :
1. drain coolant and tighten drain plug ( easier method : remove radiator cap, get big drain pan, place drain pan under lower radiator hose to radiator connection, remove clamp, slowly remove hose, allow coolant to drain into pan, now is a good time to remove radiator hose and clamp from thermostat housing )
2. remove thermostat cover / cap ( easiest to get at this when front of car is supported by jack stands and right hand side lower cover is removed ).
3. thermostat cap is held on by 3 bolts / remove thermostat.
You will notice that the thermostat's air bleed hole is pointing up and lines up with notch in water pump housing,,
ATTENTION :failure to install new thermostat in the correct location will cause engine to overheat.
1. install new thermostat to water pump, make sure air bleed hole lines up with notch, install and tighten bolts, install a new lower radiator hose, fill cooling system.
thermostat # 17670-77E00
lower radiator hose #17854-65G20
hose clamp #09401-36403
upper radiator hose # 17852-65G20
Suzuki factory manual
Oct 21, 2013 | Cars & Trucks
Tip
How to Change Thermostat in Bentley Arnage car?
1) First buy a new thermostat for you car year and model.
2) Then as per the procedure. Remove the radiator cap. Be careful that there will be pressure in the radiator. So just let the pressure release first before removing the cap completely.
3) The thermostat is connected to the black hose coming from radiator.
4) On the top of the engine there will be thermostat cover. The cover is fitted by two bolts on each side.
5) Then remove the hose connected to radio with the help of a pier.
6) The other end of the hose is connected at thermostat cover. Carefully remove the other end of the hose. A bit of coolant will flow from the hose while removing the hose.
7) Remove the screws holding the thermostat cover. Lift the cover after the screws are takes out. Then take the thermostat seated under the cover.
8) Remove the old gasket out from the thermostat with the help of knife.
9) Before removing the old thermostat carefully notice the position of old thermostat. In the same way place the new thermostat with the spring assembly in the down side of the engine.
10) Refit all the parts removed while removing the old thermostat properly.
11)After every thing is fitted proper as it was before, then check the coolant level if its low get it refilled till the required level.
This will help. Thanks.
on Mar 19, 2010 | Bentley Arnage Cars & Trucks
Tip
How to Change Thermostat in Avanti Studebaker car?
on Mar 19, 2010 | Avanti Studebaker Cars & Trucks
How to change thermostat
Instructions
    • Trace the top radiator hose from the radiator to the location where the hose secures to the engine. The metal cover that the hose connects to houses the thermostat.
    • 2Remove the two 10-millimeter bolts that secure the cover onto the engine with a wrench. If you cannot reach the bolts or you are using a socket/ratchet, remove the radiator hose from the metal cover by removing the radiator hose clamp.
    • 3
    • Lift the metal cover off the thermostat to expose the thermostat. With the radiator hose still attached to the cover, lift upward on it to drain the fluid back into the engine. Push the cover and the hose off to the side. If you removed the hose, simply lift up on the metal cover and place it off to the side.
    • 4Pull the broken thermostat out of the engine and place a new one into place. The new one should be orientated in the same manner as the old one to ensure proper fluid circulation.
    • 5Lift the old gasket off the engine and place the new gasket into place. The new gasket should remain dry throughout this process.
    • 6Bolt the metal cover back onto the engine using the old bolts. If the radiator hose was removed during the tear down process, secure the hose back onto the metal cover with the radiator hose clamp.
Aug 29, 2012 | 2002 Dodge Neon
Where is the thermostst located in a 2006 cobalt LT 2.2 eng.
Check this diagrams...
Fig. Location of radiator outlet hose clamp (1) at thermostat cover for the removal of the radiator outlet hose from the thermostat cover - 2.2L & 2.4L engines
Fig. Location of thermostat cover bolts for removal of the thermostat and thermostat cover O-ring seal - 2.2L & 2.4L engines
Hope this helps.
Sep 22, 2011 | 2006 Chevrolet Cobalt
Tip
How to Change Thermostat in Audi Allroad car?
on Mar 19, 2010 | Audi AllRoad Cars & Trucks
Tip
How to Change Thermostat in Amc Eagle car?
on Mar 19, 2010 | AMC Eagle Cars & Trucks
Where is thermostat on my 2005 chevy classic
Thermostat Removal & Installation 2.2L Engine 2004-2005 To Remove:
  2. Remove the thermostat housing-to-water pump feed pipe bolts. chevy_cav_02-04_feedpipe.gif
  3. Remove the water pump feed pipe from the thermostat housing .
  4. Remove the thermostat from the housing.
To Install:
  1. Install the thermostat on the housing.
  2. Install the water pump feed pipe on the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Fill the cooling system.
2006-2007 To Remove:
  1. Drain the cooling system.
  2. Disconnect the radiator outlet hose from the surge tank and thermostat housing cover. Thermostat & cover gm-03-39-3601.gif
  3. Remove the mounting bolts and remove the thermostat housing cover.
  4. Remove the thermostat from the housing. Discard the O-ring.
To Install:
  1. Using a new O-ring, install the thermostat on the housing.
  2. Install the thermostat housing cover with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Connect the radiator outlet hose to the surge tank and thermostat housing cover.
  4. Fill the cooling system.
3.5L Engine (LZ4) W/ Variable Valve Timing & 3.9L Engine To Remove:
  2. Remove the air cleaner outlet duct.
  3. Disconnect the radiator outlet hose from the thermostat housing. Thermostat 3.9L gm-03-00-3054.gif
  4. Remove the mounting bolt/stud and remove the thermostat housing.
  5. Remove the thermostat from the engine.
  6. Clean the sealing surfaces.
To Install:
  1. Using a new gasket, install the thermostat on the engine.
  2. Install the thermostat housing with the mounting bolts. Tighten 89 in-lb (10 Nm).
  3. Connect the radiator outlet hose to the thermostat housing.
  4. Install the air cleaner outlet duct.
  5. Fill the cooling system.
  6. Check the cooling system for leaks.
3.5L Engine (LX9) W/O Variable Valve Timing To Remove:
  1. Drain the coolant.
  2. Disconnect the radiator hose from the thermostat housing. Thermostat 3.5L gm_mv_ven_tstat.gif
  3. Remove the mounting bolt/stud and remove the thermostat housing.
  4. Remove the housing gasket.
  5. Remove the thermostat.
  6. Clean the mating surfaces.
To Install:
  1. Install the thermostat on the engine.
  2. Install the thermostat housing and gasket with the mounting bolts. Tighten 18 ft-lb (25 Nm).
  3. Connect the radiator hose to the thermostat housing.
  5. Check the cooling system for leaks.
Jan 29, 2011 | 2005 Chevrolet Malibu
Where is the engine water thermostaton my Grand Cherokee 2.7 CRD
  1. Disconnect negative battery cable at battery.
  2. Drain cooling system.
  3. Raise vehicle on hoist.
  4. Remove splash shield.
  5. Remove lower radiator hose clamp and lower radiator hose at thermostat housing.
  6. Remove thermostat housing mounting bolts, thermostat housing and thermostat.
To install:
  1. Clean mating areas of timing chain cover and thermostat housing.
  2. Install thermostat (spring side down) into recessed machined groove on timing chain cover.
  3. Position thermostat housing on timing chain cover.
  4. Install two housing-to-timing chain cover bolts. Tighten bolts to 115 inch lbs. (13 Nm).
Dec 06, 2009 | 2001 Jeep Grand Cherokee
Tip
How to Change Thermostat in Acura Integra car?
on Mar 19, 2010 | Acura Integra Cars & Trucks
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
