Question about Bose Companion 2 Computer Speakers
One of the speakers (one with the power terminal) is not working The other speaker is working well Would you help me please
  • 62 Answers
Check the lead...........
Posted on Nov 10, 2010
Yamaha emx 88s
amplifier module faulty, it may even damage your speakers if it had dc on the speaker terminals. have a qualified technician to check and confirm all components.
Dec 11, 2014 | Yamaha Music
MY SPEAKERS ARENT WORKING AT ALL!
No! All speakers cannot be dead! Check the speakers by multimeter. If you do not have multimeter, then use a 1.5V pencil cell. Connect negative of the cell to one terminal of the speaker & brush another terminal against the positive. You will hear a brushing sound in the speaker. If you don't, then the speaker is dead & needs repairs. Repairing of drive units is not recommended as it will lower the quality of sound. Please check the Theatre System for its functioning.
- sonsunny
Jul 10, 2011 | Coby DVD938 Theater System
Radio turns on speakers connected ok but no sound when tuned into any station
Without the make & model of your receiver, I can offer only generic solutions. Turn the volume DOWN to a normal level - if the speakers suddenly turn on it may startle you or damage the speakers.
In no specific order - here's what I suggest to do: Check connections at receiver's speaker terminals and at the speaker's terminals. Note the speaker system (A or B if a choice of terminals are offered). Check and reset or replace any overload device or fuse for the speakers. Make sure the speaker selector switch is set to a valid speaker system A or B (most people have one speaker system and wire speakers to "A" and leave B unused), change it from "Off", "B" or "Phones" to "A". Make sure that the headphone / earphone jack isn't being used. Disable the "Tape Monitor" selection.
If none of the these suggestions worked for you, please provide the receiver make & model. If one did, please rate my reply "very helpful". Thanks!
Jun 18, 2011 | Audio Players & Recorders
I cant remember how to hook up the speakers to the system
Speakers use a cable that consist of 2 insulated wires. The two wires are identified by one or more ways: 1) one wire may be golden colored and the other white or silver colored, 2) the insulation on one of the wires may have a raised ridge, or 3) the insulation on one wire may have some marking along the surface where the other will not
The terminals on speakers and terminals for the speakers on the amplifier will both have a (-) and (+) symbol for each cable (one for each wire). I like to assign the (+) terminal to the golden colored wire or the insulation with the rib or marking on it, and the (-) terminal to the white or silver colored wire or on the smooth or unmarked insulation. It does not matter which wire you assign to which terminal - as long as the (+) and (-) terminals of the speaker connects to the (+) and (-) terminals on the speakers of the amplifier (you should see to it that they do not get crossed so that the (+) of the speaker is connected to (-) terminal for the speakers on the amplifier).
Connect each speaker location to the corresponding speaker terminal on the amplifier (the front right speaker to connect to the front right speaker terminals on the amplifier - continue until all speakers are connected). Failure to connect correctly will make fading front to back and balance left and right work unexpectedly.
I hope this helps and good luck! Please rate my reply. Thank you.
Apr 09, 2011 | Audio Players & Recorders
The power light is on but the sub not playing at is also a kicker product. A 12 inch sub all wires are in the right place a audio shop did the work for me. Can you please tell me what is going on.
Is your sub in a box? the power light is on your amp? try to connect a car speaker to the port you have the sub plugged into, if the speaker works its not your speaker terminal on your amp it's the sub. Check the wiring on the connectors of the back of the sub itself and the wire terminals inside the box (if sub in bass box)
Please let me know if this was any help and let me know if it solves your problem
Mar 05, 2011 | Kicker Car Audio & Video
How do i connect the speakers to a pc
What I want you to do is need a little work okay..
In your speaker set there are two satellite speaker which Right and Left. Also it has the sub woofer that contain the three terminals, the red,white and the power terminal. Connect the right speaker to the red terminal, left speaker to the white terminal and the power cord will be connect to the power terminal. In the back of your computer you can see the three sound terminals colors below. Insert the green speaker plug to the green terminal in the sound terminal on the back of your computer.
Oct 21, 2009 | Logitech Z-4 Computer Speakers
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here...
error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Jun 17, 2009 | Sony STR-DA5000ES Receiver
Left speaker terminal on the sub doesn't work properly
This is common with the type of powered speakers where the IC package that drives the speakers (the amp) is getting to hot and shuts down. Usually it is damaged and not reversable. There is a lot of reports of this same model loosing one channel or playing quietly. The air most likely cooled the chip down until it heats back up.
Jan 15, 2009 | Logitech Z-2300 Computer Speakers
SA HE200 ~ Overload at power up
First of, be sure volume is turned all the way down before or as you are powering it it.
Second if that does not work disconnect all speaker, and input/outputs.  Power the device on and see if it says overload.
If it does skip the rest of these steps, your capacitors are bad or the power supply is no longer functioning correctly.
If it doesnt, start with testing each speaker at power up.  Match the speaker to the output it goes on, power the device see if it says it.
If it does on any speaker test it is a speaker issue or a terminal issue.  To test for terminal or speaker issue plug a different/ known to work speaker in that same terminal, if it doesnt say overload it is a speaker issue, if it does say overload it is a terminal issue.
Once you have made sure all speakers and terminals work correctly start plugging input and outputs in and test individually.
Jan 09, 2009 | Panasonic SA-HE200 Receiver
Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
May 11, 2007 | Koiiler XM-7676W Car Audio Amplifier
Bose Companion 2 Computer Speakers Logo
64 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
