Flash drive wont work on my computer - Computers & Internet
    Champion:
  • 214 Answers
Hai Charnley
Your OS may not have the required driver for you flash/pen drive.
If its XP, most of the flash drive drivers are included in it and it will automatically get installed. After connecting the drive wait for the device driver to get installed.
If its not happpening, Try connect the drive to your computer, it will detect the device, note down the device name it display towards the right bottom of your screen.
Then with this device name, brows google and enter device name + 'driver' in the search field and click the search button.
U will be provided with numerous sites where from u can down load the driver for ur device.
good luck
vrabby@yahoo.com
Posted on Jun 17, 2008
My flash drive does not show up on my computer and the red light won't stop blinking.
I had the same problem for weeks and I couldn't figure out why it would work on my personal laptop but not my work PC.
My problem was that the Flash drive was using "H:" as the drive letter and I already had "H:" assigned to a network share. The computer obviously recognized it because it appeared in the Disk Management, but it was assigned to H: and the PC already had "H:" connected to my share. I could have just changed the drive assignment for the flash drive to another letter and restart the PC as previously mentioned but I was in the middle of working on something and restarting my PC wasn't the best thing to do at the time. I decided to try to disconnect my "H:" network share and reconnect it using a different drive letter ("J:" in my case). After doing that I reconnected the flash drive and it opened fine under "H:"
Just another option to look into.
Oct 16, 2016 | Computers & Internet
Wont read a flash drive
Make sure the flash drive will work on a normal computer. If it does try a different port on the xbox. If it works on the computer and not the xbox you might have to format the flash drive to work with the xbox Go here USB flash drive support for Xbox 360 or How to Configure any USB Flash Drive as Storage on Xbox 360
Apr 03, 2014 | Microsoft Xbox 360 Console
One of two USB drives wont recognize anything
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Dec 13, 2009 | Toshiba Satellite A205-S5804 PC Notebook
Crw4048 tray wont open drive light flashes
power the computer off before you try the paper clip trick
Oct 12, 2009 | Computers & Internet
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
Flash drive not working
Yeah your going to need to get a new flash drive!
May 04, 2009 | Computers & Internet
Cant install program from DVD drive GWA-4164b
First check that your system meets the minimum requirements...ie. you have at least 512mb of ram, CPU of at least 2Ghz Pentium4 or equivalent(with off-board video), and your hard drive has >4GB of free space.....can view full list at:
http://www.amazon.com/Spore-Mac/dp/B000FKBCX4
Is SPORE on a duel layer dvd? If your drive is on the older side, you might try a newer one or you can try the following:
--take out an empty flash drive with
--go to a computer that will read the disk...if you have another computer or u can use someone elses
--put the disk in their computer and if the computer is able to read the disk, then put your flash drive in the computer and copy the disk onto your flash drive...
-y-ou can now try to install the program from your flash drive instead of using the disk...
NOTE: Trying this method wont cause any damage, but if the disk is encripted or if the install software is set to check for the disk during installation, then this may not work, but is worth trying since because a) even if it doesn't work, no harm is done, and b) you wont need to replace your disk drive if it does work.
Feb 12, 2009 | Acer (4432A-002) CD-RW Burner
Flash drive ports on teh fron wont work on pc
If your system is USB 1 rather than USB 2 then some flash drives will not work. Not all usb 2 flashdrives are backwards compatible. My kids flasdrives will only work on my usb2 ports & will not work at all on my wife's computer which has the older usb 1 ports.
Dec 19, 2008 | E-Machines etower 500is PC Desktop
Modem says no dial tone, phone line is ok. Also USB ports wont work with flash drives.
plz check your pc for viruse then post your findings for further help
Jun 06, 2008 | Computers & Internet
Imation 512mb flash drive
you need a driver for that to work. i think...
Oct 06, 2007 | Electronics - Others
Computers & Internet Logo
David Payne
David Payne
