Question about Timex Ironman Triathlon Heart Rate Monitor
The watch automatically stops the heart rate counting... message is "no hrt rate". I have only had this 2 months and i have changed the battery on the strap once.
SOURCE: Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Posted on Jan 19, 2009
  • 2976 Answers
SOURCE: Timex heart rate monitor does not keep correct BPM. I changed the battery, now the heart rate hovers in the 30' and 40's, never getting to the correct BPM
Make sure the back of the watch is spotless and your skin isn't too dry.
Posted on Apr 23, 2009
SOURCE: inaccurate/intermittent heart rate info?
Here are the things I have noticed that help:
- enough moisture between the HR monitor and your chest. Apply water right before your workout to make sure it isn't all dry between the time you put on your monitor and when you actually started your workout.
- Make sure the strap is tight enough. Mine gets loose over time and the bouncing of running will give me inaccurate readings until I tighten it up again. You can test if this is the problem by using your hands to press the monitor more tightly against your chest - if that seems to fix the problem that a loose strap could be it.
- Use a "conductive gel" instead of water between the monitor and your chest. Conductive gels are pretty cheap.
Posted on Jul 03, 2009
escapement
  • 2334 Answers
SOURCE: just purchased timex 1440sport watch with heart
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.If you can not sort the problem after following instructions, you may need to replace battery. Rate me, please
Posted on Mar 28, 2010
  • 11800 Answers
SOURCE: I have had my Timex
The heart rate is recorded at these abnormally low levels because the sensor has lost its sensibility. This can be caused by only 2 things:
1 - the battery for the watch is almost dried and its voltage has dropped so low that the sensor can't work no more. You will have to replace the battery. because your watch is a sealed type you should take it to a repair shop: they will know how to open it carefully enough as to not damage the rubber seals.; and if they can't open it without damage they will have replacement rings.
2 - the sensor itself (which basically is just a microphone that listens to the beats) is clogged by dirt. Wash the watch in hot soapy water and look very carefully for cracks in the rubber of the strap - if you find one then the sensor has been permanently damaged by the sweat that seeped in. In that case it's time for a new one.
Posted on Dec 15, 2010
I need to replace the battery in a Hrt Slim Mini heart rate pedometer.
https://www.nbmonitors.com/assets/Manuals/Archives/HRT%20Slim_HRT%20Slim%20Mini/HRT%20Slim_Slim%20Mini_English.pdf
Dec 26, 2013 | New Balance Balance Hrt Slim Mini Heart...
Need to "unlock" my Sportline
all you have to do is hold down the start/stop button for like 3 seconds and at should unlock it so you can use the heart rate monitor...
Sep 20, 2011 | Heart Interface Sportline S12 Ecg Heart...
My watch face shows many of the "screens" all at
it can be done by moisture so put it in the heat to remove the moistuere or put it the rice bag for 5 months so the moisture can be remove
Aug 11, 2011 | Polar F11 Heart Rate Monitor
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
My watch does not show heart rate
I have a problem solving checklist about getting Heart rate readings in my tips and tricks page that may be helpful.
#1) you have to make sure the strap is across your chest and contacting the skin directly
#2) you have to push the button on the front of your watch to turn it on.
After that it should read automatically, there is no trick to your watch.
Jan 04, 2011 | Polar FS1 Unisex Heart Rate Monitor Watch
The heart rate function has turned off. So the calorie count won't work. Everything else is working fine. It happened about four days ago. I have lost my owners manual.
Press and hold the reset button, for 5 seconds, while in Time mode. this will reset the heart monitor and the symbol will reappear on the screen.
Nov 26, 2010 | Sportline 915 Solo Heart Rate Watch
Polar F6, stopped counting calories and stopped showing heart rate. Buttons will not work and it reads Calorie? at the top
You will have to go to Polar for this problem. Sorry.<br /> <a href="http://www.polarusa.com/us-en/">http://www.polarusa.com/us-en/</a>
Aug 26, 2010 | Polar F6 Wrist Watch
Timex Ironman 30 lap heart rate does not display
the battery type is written on the back of the watch.
Jul 12, 2009 | Timex Ironman Tri 30 Lap Sleek T59671...
Exercise & Fitness Logo
325 people viewed this question
Top Timex Exercise & Fitness Experts
Dennis Fitzsimmons
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Timex Exercise and Fitnes Expert? Answer questions, earn points and help others
