Question about Samsung VP-L600 8mm Analog Camcorder
Tape will not eject but makes a whirring noise when the eject button is pressed
3 Suggested Answers
silly girl
  • 513 Answers
SOURCE: Problems ejecting a tape
Take to a decent camera shop, they probably won't charge fr pulling it out, if it can be done w/o disassembly. They could also give you a better idea on the problem at hand, and you'll be able to make a more informed decision. It could be something small stuck in the teeth of the gears and jamming it. Good luck
Posted on Jun 21, 2006
  • 458 Answers
SOURCE: Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Posted on Aug 14, 2009
The tape won't eject. press any button and nothing happens makes a whirring sound
I would take the top cover off the machine and see what is happening inside. It's clearly trying to get the tape out from the noise.
Aug 23, 2014 | Mitsubishi HS-U410 VHS VCR
My Aiwa HV-MX100 vcr has not been used in about 18 months. When I insert a tape, I can hear a whirring noise, but the tape will not eject properly. Also, the power will not shut off completely - the...
Is your VCR fixed?
From what you have written, I understand that you have not used the VCR for many months. And since you are hearing a whirring noise, the eject motor is working, but the belts are spoilt, and are slipping. Hence your problem. I suggest you open the top cover of the VCR and observe the eject mechanism. As suggested, you will - in all likelihood, observe that the belt driving the eject gears is slipping.
May 27, 2011 | Aiwa HV-MX100 VHS VCR
My ps3 320gb has frozen i cannot get the game out
Turn the PS3 off as normal, then turn the power off by flipping the switch at the back so that no light are on the console at all. Once the console is off fully, hold the eject button as you flip the power switch at the back on. The PS3 should start with a loud fan whirring noise. Once powered up, release then press the eject button once or twice and it should force the game to eject.
Best of luck!
Mar 06, 2011 | Video Game Consoles & Games
The dvd will not eject just makes a whirring
There is always a small hole in the front of the tray. Insert a pin through it and press gently when it encounters resistance. The tray will open.
Jan 18, 2010 | Televison & Video
Tape stuck in VCR
hi
chek this site nd follow the steps
http://www.leaders-site.com/stucktape.html
also chek this site for more idea
http://www.answerbag.com/q_view/13913
hope u will b helpfull
regards
Jun 10, 2009 | Televison & Video
Tape tray won't drop back in
Take it to a service provider - seems to be something wrong with the loading drive system.
Jan 09, 2009 | Canon ZR830 Mini DV Digital Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Help! having similar problem with my camcorder?
Sounds like something is jammed in the tape carriage
Call canon and send it in for sevice.There is no tip or trick for carriage jamming issues
Jul 10, 2008 | Canon ZR500 Mini DV Digital Camcorder
VM9511TS wont eject
Does it make noises like it's trying to eject? Like whirring motors?
Sep 10, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Ultrium LTO 2 Tape Drive
Try holding the eject button down, for a long time, about 20 seconds (1 and 2 and ). This resets the tape drive, the lights on the front should go off, then come back on again. The tape will either eject automatically or will eject after the button is pressed normally.
The only time this dosen't work is if the tape is still out inside the drive.
Aug 14, 2007 | HP StorageWorks ESL712e Ultrium (AA934B)...
Samsung VP-L600 8mm Analog Camcorder Logo
53 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
