Question about JVC Audio Players & Recorders
I have a JVC Model number AA-R1807 external power supply for a portable sound system. 18V 1.0A output. Any thoughts on how to fix or replace?
  • 12 Answers
SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Posted on Sep 22, 2008
  • 14 Answers
SOURCE: Miising power supply
It takes a 5V adapter
Here is the part number
C14627 - AC ADAPTER FOR USB BUS-POWERED FIRELITE - ACFLB
Hope this helps!
Posted on Feb 27, 2009
  • 59 Answers
SOURCE: have an hp pavilion desktop that wont power up.
You can purchase a power supply tester, they are not that expensive. Here is a link for some and if you want you can shop around. Make sure to get a 20/24 pin tester.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=power+supply+tester&x=0&y=0
Also if you do have a bad power supply here is a replacement.
http://itwinkle.stores.yahoo.net/hi20posu09h.html
Hope this helps you out.
Posted on Mar 01, 2009
SOURCE: Sony CD Walkman-(portable Radio -CD player)Very low sound output.
Problem solved by trying another set of headphones.
Thanks anyway.
Gerda
Posted on Apr 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: lost 18V AC adaptor- can I use one made for laptop with 18V output?
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
Posted on May 25, 2009
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
How to fix problem of jvc crt tv model av-21l31 power ok no video/audio no display with lines coming from flayback
Look at the horizontal output transistor then the fly back transformer.Check ALL the voltages coming from the power supply. One or more of them have to be missing for the audio and video to be gone at the same time.
Sep 24, 2014 | Televison & Video
I have a black frame around the picture and I would like to know how to get rid of it?
It sounds that, the secondary power supply voltage output from main power regulator section is less than normal. What is the exact model number to your JVC TV?
Jun 10, 2012 | JVC Televison & Video
I have a Behringer xenyx 802 audio mixer and have lost the power supply. I tried to buy a replacement, but cannot find any in stock. I'm very resourceful and thought I'd make one. The spec sheet calls for...
No, you can't just jump the pins together. The power supply in the mixer needs two separate 18-volt AC inputs because it makes two supply voltages, +15 and -15 volts.
The external supply is just a potted 36-volt transformer with a center-tapped secondary. I bought an open-box Behringer (not your model, but similar) that was missing its supply, and found this transformer which works fine. (I actually did find a couple of sources for a replacement Behringer supply, but it cost more than I paid for the mixer!) Just connect the three output leads to the appropriate places on the mixer's PC board. In mine, I removed the original input connector and soldered a pigtail with a 3-pin connector from Radio Shack to the PC lands, then attached the matching plug to the transformer leads. You'll also need to provide an enclosure of some kind to prevent contact with the line voltage input to the transformer and to protect the thing if you carry it around.
Mar 29, 2011 | Audio Players & Recorders
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
I have a JVC Rear Projection television and there is no power!!!
This is a very complicated unit. There are several safety circuits involved. I hate to say it but you don't have many external fixes. It would be better to have a repair shop check it out for you. Sorry but thanks for using fixya.
Nov 06, 2009 | Televison & Video
Yamaha Portable piano - Loud 50Hz sound only on mains
MAKE IT THIS WAY FRIEND, IF YOUR POWER INPUT IS OK, AND THE OUTPUT IS FINE, THEN GO FORWARD FOR THE NEXT STEP, IF YOUR LA4558, (2CHANNEL AUDIO OUTPUT IC) IS HEATING UP, THEN JUST CHANGE THE IC, ALSO CHECK FOR CAPACITORS, ANY SIGNAL DIODES IF HAD DAMAGED, AND RESISTORS NEARBY...CHANGE THE AUDIO AMP
Oct 16, 2009 | Music
Hope this helps!
Feb 27, 2009 | SmartDisk 40GB - 4200rpm - 40MBps - IEEE...
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
