Question about Acer Aspire One PC Notebook
Notebook will not turn on - Acer Aspire One PC Notebook
  • 1,679 Answers
There are few steps you have to try since this could happen due to any reason.
Check which one is possible for you to try out of these steps below.
1. Can you do a chip level repairing OR
2) Try a known good adapter. OR
3) Remove the battery and adapter. Press and hold on the power button for one minute and then release it. Now connect the adapter and switch on the system.
Hope this fix the issue. Do let us know if the issue is resolve or if not resolved.
Posted on Nov 10, 2010
Compaq Presario F756NR - I go to turn on the laptop, it blinks a couple of times like it is booting up and then turns back off. Could this be the mother board?
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 12, 2010 | HP Compaq Presario F756NR Notebook
My Gateway laptop model MX6453 wireless adapter is shut off and I'm unable to find how to turn it back on
Frequently Asked Questions
Q: How do I turn my notebook's wireless on and off?
A: Most Gateway® notebooks have a designated multi-function button or function key to turn your wireless on and off. This information is located in your notebook's user guide. The user guides for the Gateway® branded notebooks are installed on your hard drive. To access your user's guide, from the Start menu, point to All Programs, and then click Gateway Documentation. User guides are also located on the Gateway® Web site. To download or view a copy of the user's guide from Gateway.com, select your notebook type from our Notebook User Guides support page. http://support.gateway.com/support/manlib/Notebooks/notebook.shtml Another source of reference for networking your computer is the Gateway Notebook Networking Guide. http://support.gateway.com/s/Mobile/Gateway/M250/8510650.pdf Quick reference:
  • Gateway® M675 - Multi-function button (last on right)
  • Gateway® 200ARC - Multi-function button (last on right)
  • Gateway® M505 - Multi-function button (first on top)
  • Gateway® M500 - Multi-function button (first on top)
  • The Gateway® M275 notebook uses the system keys FN+F7
  • Most other notebooks use FN+F2
Dec 08, 2010 | Gateway MX6453 Notebook
Why won;t my laptop power up
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check if the notebook works fine or not. However, if the notebook turns on and if the display stays blank then connect an external monitor to the notebook and check for the display on it.
Step 2: External Monitor
You can follow the steps below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook.
Incase, if the notebook does not turn on at all then the issue is due to internal hardware malfunction. In all the cases, the notebook requires a detailed onsite diagnosis by a service technician.
If your notebook is under HP warranty, then I suggest you to contact HP support to get the notebook repaired under warranty.
Jun 02, 2010 | HP Pavilion dv9000z Notebook
My hp notebook dv2201ca power on by itself, but lc...
Hi, to isolate the issue perform the following.
Step 1: Hard Reset
Step 2 :External Monitor
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
May 20, 2010 | HP Pavilion dv6000z Notebook
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: the screen goes black after the hp logo comes on w...
its generally due to static stored in the notebook ....which stuck the turn on process of the notebook...
turn off the notebook ,, remove the battery .. press and hold the power button on the notebook for 4-5 sec and then put the battery back and then turn on the notebook it will start ,,,
if it not check in the safe mode
May 18, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000z 17" Notebook Laptop PC PC Notebook: My Hp laptop turned off by itself and wont turn on...
Make sure your Notebook is not overheat if it is then you have to make sure the fan is working and have to work on the NB by placing it on a hard surface and also BIOS update will also help to resolve the issue.
if in case the notebook is not overheating boot to BIOS screen and check if the Notebook turns off by itself in bios if it does then its a hardware issue and you need to contact manufacturer to service the notebook
When I turn on My HP Laptop the system start booting and all of the lights on the laptop turned on but the screen doesn't display a thing it is always dark could anybody help me... Thanks in advance...
This could be due to presence of static charges or hardware malfunction of video card or defective LCD display screen of your notebook. To isolate this issue, perform the following:
HARD RESET
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists then connect an external monitor to the notebook and check if it works fine. You can follow the steps listed below to connect an external monitor to the notebook.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
May 18, 2010 | HP Pavilion dv1000 Notebook
It wont turn on whether its plugged in or not....
Step 1: Hard Reset
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook.
Step 2: Remove and reseat memory modules
You can refer the service manual provided below for information to remove and reseat the memory modules.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Refer page no: 121, 122 & 123
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
However, if the issue still persists, then it is clear that the issue is due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. At this point, I would recommend you to take the notebook to a nearest Computer Service Center to get it repaired/serviced. I hope the information provided would be helpful.
May 14, 2010 | HP Pavilion dv1000 Notebook
Acer Aspire One  PC Notebook Logo
61 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
