Question about Honda Electrical Supplies
Motor runs fin but smoke major pouring out of generator end and circuit breaker will not stay on
    President:
  • Honda Master
  • 1,388 Answers
If you were drawing major power from generator, you may have fried capacitor or voltage regulator. Both of these parts tend to make smoke when they fail. Stator winding can fail also but rare. Remove end cap to generator. Look for melted strings that bind coils together or melted wires. This would indicate failed stator. If stator looks ok, look for capacitors that look swollen or leaking that my be easily replaced. Caps have a value printed on them and reading should be within 5%. If caps are good, look at half moon shaped regulator. Failed regulator will have melted potting compound. Good luck
Posted on Nov 10, 2010
What can cause the plastic fins on the rotor of my Onan 4ky generator to break off and rotor to rub on stator? Bearings are good no play.
Was every thing oily in the generator? It sounds like you may have lost a bearing in the engine. You definately don't want to spend without finding out where the play is that let it rub. It will do it again. Check and make sure that the rotor isn't loose on the motor shaft. Make sure the bearing housing on the end of the rotor won't let the bearing move around in it.
Dec 16, 2015 | Onan Microquiet RV Generator 4000 Gasoline...
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
Where is the breaker box on 1998 travleze trailer
All travel trailers and motorhomes have different set ups, but the majority of them install the breaker box in the generator compartment, even if it doesn't have a generator installed.
Jan 01, 2012 | General Electric GE ELECTRICAL TQD22200X2...
Honda ex 650 genorator carburetor not getting any fuel, and wont stay running
check the fuel filter and the fuel shut off to see if they are clogged
Jun 22, 2010 | Master Heaters MASTER HONDA POWERED...
Breaker tripped, wouldn't reset. After about 20 minutes it reset.
YES YOU ARE IN DANGER. DO NOT turn this breaker on again. Please get a registered electrician. There is a risk of fire or even explosion. BE CAREFUL. Have you got a smoke alarm?
Feb 05, 2010 | RTO Circuit Breaker Box For Electrical...
Generator runs but can't reset circuit breaker
It probably isn't the circuit breaker. The magnetic field has likely weakened (especially if the generator has not been used in a while). The magnet can be "flashed" by running a current through the generator briefly. The easiest way to do this is to plug in a motor and spin it backwards (by hand) while the generator is running (e.g. an electric drill). The drill acts as a weak generator when you put the energy into it by spinning it.
A previous answer I gave to the same problem...
Look in the manual. There is likely something about field flashing the magnetic field2.gif. According to the Briggs and Straton web site (similar solution for all generators), the easiest way to do this is to.
1) start the generator
2) plug an electric drill into the generator (without drill bit)
3) make sure drill is set to forward direction (if a reversable drill.
4) pull the trigger on the drill.
5) If the drill does not start, spin the drill's chuck in reverse [clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself].
6) Do this several times (hard) until the the generator will kick in and suddenly make the drill spin at full speed.
Be careful not to drop the drill or poke someone with it as you celebrate success.
Oct 27, 2009 | Coleman Powermate Premium Plus 6250W...
No electrical power
You must find the reason the main breaker is popping ...
I'd start by unplugging everything and remove all breakers. Turn the main on ... does it pop? If it pops here look between the breaker panel and the end of your cord. Turn the power off - reinstall the first breaker - turn power back on. What happens ... keep doing this until the main or individual breaker pops - investigate that circuit to find your short.
If you get all breakers back in with out popping anything ... start plugging stuff back in. Something is shorting somewhere.
Let me know what you find please.
thanks
a
Oct 06, 2009 | Hilltop Rv 60 AMP CIRCUIT BREAKER CARDED
No output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
Sep 10, 2009 | Coleman Electrical Supplies
McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Apr 11, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Hello Tech Team: I own a Coleman Powermate 1800 watt portable generator... I used this new generator one time for less than five minutes... the extension cord running from the generator was dragged thru a...
Wow, you've got an ugly problem. It sounds like you already know that you have to pretty much disassemble these little buggers down to the frame to see anything inside, so I'll say what to look for:
1 - Burned wires in the part of the generator that doesn't move. This is the bit that carries the current shorted out by the mud.
2 - Burned wires in the part that does move. This is the bit that makes the magnetism that makes the electricity. There are also some diodes and MOVs tucked into the end of the plastic insulator
You're likley better off getting some other generator, sorry.
Nov 21, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
234 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
