When i boot my pc up (windows vista) it goes through the motions of booting up i see all the bios stuff on the screen as it scrolls through but then the screen goes blank however i can see my curser in the middle of it and can move it around. I have tried a safe boot or a boot from last known good config and nothing seems to work
  • 6,826 Answers
I'm afraid that in this situation, the operating system will have to be installed from a DVD. If you can't get to the 'recovery console' or the 'restore' area, then that's the only way I know that it can be reinstalled.
Unfortunately, many newer computers don't come with the backup disks or recovery disks, and you should make your own whenever the computer is first used.
Good luck on this repair or reinstallation of windows vista.
Posted on Nov 10, 2010
Reinstall windows vista
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
Feb 27, 2013 | Dell Dimension 4600 PC Desktop
Booting operating system to install from usb
rather disconnecting the dvd you could just uninstall your dvd drive then reinstall it after
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives right click select uninstall
or
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to usb,press escape then press f10 to save to cmos to restart
or
http://www.bootdisk.com/art/penboot.jpg
hope this helps
Oct 09, 2012 | Gigabyte Ga-g31m-s2l Motherboard Intel G31...
The computer will not boot up.
It may caused by the curreption(deletion) of important system files,
You can format and reinstall xp,vista,win 7,linux,mac os .
Restart computer when booting goes on press F5 Or DEL key to goto bios setup menu change boot order to first cd drive then hdd
PressF10 and press Y and enter.
computer will restart
Insert xp,vista,win 7,linux,mac os cd.
Press enter to boot from cd
Follow the instructions
Then your problem will solve.
Jul 28, 2010 | E-Machines eMachines Desktop PC
Laptop will not load windows vista from bios mode. I have tried recovery discs but still NG, from start up goes past bios & then stops as Vista is starting.
have you tried a system restore and then booting up? I had an issue booting up with vista and tapping Alt+F10 during BIOS fixed, it seems to skip the corrupted part of the boot.
Feb 08, 2010 | Toshiba Satellite A300-0CF035 Notebook
I have a aspire 6930 laptop from acer it will boot past post but not into windows not even in safe mode it just goes to green bar like windows is starting then blue screen with error stop:oxoooooo7b...
id reinstall vista ! if you want to do this you need to get in to the bios which u press F2 i believe when the comp first starts up when your in the bios scroll along to boot menu u shud see a boot list with your hard drive at the top ,you need to change your dvd drive to the top so itll boot from dvd , restart your computer with a windows vista disc in the dvd drive and i think it shud give you an option to fix your system if doesnt work then definitly do a clean install of vista using your product code . hope this works
Oct 18, 2009 | Acer Aspire 6930-6082 Notebook PC
Blinking white dash during boot.
Something has messed with your MBR, master boot record, which is a small sector at the beginning of your first hard drive which tells the bios which partition to boot. You'll have to use your xp or vista's installation disc to repair the system.( Choose; repair this installation of windows when prompted )
While you are in the bios check under the boot section the order of your boot devices. If you have more than 1 HD check that the one containing your OS is first.
May 08, 2009 | Toshiba Satellite A105-S4384 Notebook
When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Mar 28, 2009 | ViewSonic VX2035WM LCD Monitor
I have a Aspire 3680 Laptop/Notebook 80GB 14-WXGA Vista HomeBasic 9980286710 PC Notebook. The problem is that when you turn it on it only boots as far as the windows logo screen and then it goes black.
Press the start button then hold down F8 to go to a black screen with writing. Scroll to boot windows to last known good boot (maybe not exact words, but do last known good start) Click that option and windows should boot to the last good start of your computer.
Dec 14, 2008 | Acer Aspire 3680 Laptop
When logging into windows vista, screen says locked. Once I type password in the desk top appears briefly and then goes back to login screen
Boot up your PC then when the bios screen disappears press F8 (to give you menu options like safe mode) one of these options is a vista repair option.....choose that and your pc should boot into windows properly....I believe this is a corrupt winlogon.exe....
Dec 06, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
