Question about HP Pavilion dv4000 Notebook
Wont let me log on to my windows 7 it say's log on error.
    Genius:
  • 1,542 Answers
Hi was it working ok before this problem
If so you could try to start up in safe mode poss F8 then do a system restore or sign in as administrator and check out or alter the sign in procedure good luck
Posted on Nov 10, 2010
I'm having a problem logging in to my computer
Windows 7, Pavilion dv6 Laptop Log in Error - HP Support ...
h30434.www3.hp.com > Laptop & Notebook > Notebook OS
Aug 6, 2011 - 10 posts Windows 7, Pavilion dv6 Laptop Log in Error ... I am having the identical problem ... after the 08-05-2011 Digitial Fingerprint software update to ...
Sep 27, 2015 | HP Pavilion Computers & Internet
Stay logged in facebook
It seem s that you have two problems, I will address the windows 7 issue. you still need to retrieve your password from Facebook...
it seems that you networks is going into a sleep / hibernation mode. you need to go to the control panel...
power options... advance....
go to sleep.. never.. save and exit.
Tony Mitri
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 14, 2014 | Microsoft Windows 7 Home Premium 64BIT...
How do I fix error 571 on my 9800 monarch ticket machine using my loftware 32 design ticket?
If you are getting error 571 from Nebraska Book Company's WinPrism inventory control system, File --> System Settings --> set the Receipt Type to 8-1/2 X 11. It seems irrelevant but it works.
Another possible resolution to the problem is to remove the Windows (XP, 7, 8, 10) profile of the offending user:
0. Login as the offending user and backup anything they want to keep, like browser bookmarks/favorite or documents on the desktop.
1. Log into Windows as a local administrator.
2. Control Panel --> User Accounts --> select the offending user --> Remove.
3. Restart.
4. Log into Windows as a local administrator.
5. Delete C:\Users\offending_user
6. The following is necessary to avoid a "temporary profile" error: Regedit.exe HKEY_LOCAL_MACHINE --> Software --> Microsoft --> Windows NT --> Current Version --> ProfileList --> select each entry until you find the one with a ProfileImagePath of C:\Users\offending_user and delete it.
7. Control Panel --> User Accounts --> add the user.
8. Login as the offending user, add the printer, and now it should work.
Jun 15, 2012 | Office Equipment & Supplies
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
My laptop wont log off the error message is other people are logged on (they arent) it makes no difference if I click yes or no any ideas
go back into windows and hit the CTRL+ALT+DELETE keys simultaneously and release, in XP the task manager window will open. In vista or 7 you will have to click on Start the Task Manager.
once it is open click on the Users Tab and see if there are users logged in other than yourself. If you do not have any other users set up on that machine and you see other users, then you could be infected with a virus or some type of Trojan malware. Click here to download a real good free and safe malware remover.
If there are users listed, click on them one at a time and hit Logoff. Confirm you want to log them off and when finished try shutting down again.
Apr 15, 2011 | Computers & Internet
I just install windows 7 and our hyundai software gdms is not working an error showing(c:\prgramfile\gadiasoft\log\gadisinstall.log\
For gdms to to make it work you'll need netframe 3.5 to be installed on your system and then gdms will work in windows7
Jan 17, 2011 | Kitchen Ranges
My problem is my computer is always reastart in working my opareting system is windows 7
This sounds like a hardware issue, you need to check your error logs and see what is happening. Hard drives sometimes manifest errors like this. The Windows error logs are listed under the EVENT viewer, press start and type event. What you are looking for are errors or critical errors. warnings and information is of little concern. If these logs do not show errors, of significance, hard drive is suspect, again, as failure precludes the error being written to the disk.
Dec 15, 2010 | Computers & Internet
When i turn on my laptop sony vpcs117gg windows show "prepairing your desktop" and when log on show vaio gate error and in this case logging windows is like safe mode? pleaz help me can i soleve this...
Have you tried press the F8 key before windows 7 starts and try last know good configuration, or tried to restore the system using system restore to a point before the problem occurred...
Aug 07, 2010 | Computers & Internet
Windows event log service wont start, error code 5
Your right its not a virus, and its not because your running one of the top anti- virus software,the problem is else where.
Have you checked the log files to see if you have permission?????
Have you checked event viewer to see if you have permission????
I need to know or the fix I have for you will not work.
Mar 13, 2009 | Dell Inspiron 530 Desktop Computer
HP Pavilion dv4000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
