Question about Zenith IQB42P97G 42 in. Television
Zenith HD LCD TV monitor
Ther is a large yellow spot in the center of the screen
    Genius:
  • 1,847 Answers
Go to menu and reset to factroy setting, make sure the video cable is pluged in properly and in the correct port.
Posted on Jun 17, 2008
Purple spot on left middle of screen
That large purple spot is telling you that you bought a TV with a defective light engine. The problem will just get worse.
Mar 20, 2013 | JVC HD-61FN97 61" Television
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Yellow spot in middle of screen (sony-large screen-hd)
Sounds like the optical block (the projector part of TV is failing) The block cannot be repaired it has to be replaced. It can easily cost several hundred dollars to fix. Sony did extend the warranty on some models, you can try going on their website to see if your model is covered or not. good luck!
Jul 04, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Yellow spot
Good Day, dv28;
No, the lamp will not correct this. The TV has a bad light engine, it's very common for this TV and very expensive. Call the manufacture and try to get a concession for the part. They normally give it about 75% of the time.
Good Luck, big IRISH.
Aug 14, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
60" zenith tv
Call LG electronics, they bought Zenith and fixed my 60inch Zewnith for free , my model is D60WLCD
Jun 07, 2008 | Zenith D60WLCD 60" Rear Projection...
Zenith lcd with a yellow dot
CALL LG I HAVE THE SAME PROBLEM WITH MY TV AND THEY EXTENDED MY WARRANTY FOR A NEW LIGHT ENGINE I HAVE HAD MY TV SINCE 2004 AND THEY PUTIING A NEW LIGHT ENGINE FOR FREE IN 2009
Dec 13, 2007 | Zenith E44W46LCD 44" Rear Projection...
ZENITH E44W46 LCD HDTV
Its your light engine failing. It can cause different colored "spots or ovals" to appear in the black background.
My Zenith ( now LG ) E44W46 LCD had the engine replaced after only 10 months, and now 3 years later it is failing again. There is a lawsuit against LG for using defective engine assemblies in this particular model.
After much searching I located this number, 800.243.0000 and called from work this past Monday at 8:15 a.m. central time. I was blown away to actually have someone pick up and direct me to a rep who reassured me that LG was aware and has set up a department to handle claims.
I was issued a case number and told that I will be contacted by a rep from this "department" and they would replace the set. With what I don't know yet but I will post back after I get thier final answer and the details.
Dec 02, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Zenith IQB42P97G 42 in. Television Logo
88 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
