Question about Dishwashers
My Whirlpool Dishwasher runs for hours. It will run, stop, run again. Is there something we can do before calling a repairman?
  • vernas Nov 15, 2010
    There is no Air Dry on my dishwasher. There is a Heated Dry, I have pressed that for a few seconds but doesn't seem to change anything. Where is the Timer located?
    Verna
  • 4,323 Answers
Hi
You can try to reset the control by pressing the AIR DRY button and hold it for 20 seconds. If the reset won't work then check the Timer as that might have gone bad. Hope this helps....please let me know if you need further assistance.
Daniel
Posted on Nov 10, 2010
  • Daniel Scott
    Daniel Scott Nov 15, 2010
    Please tell me the model no. so that I can help you.
My whirlpool gold series dishwasher will not stop running through cycles unless i open the door. It will just continue to run for hours. Any relatively easy fixes before i call backup?
Some dishwashers can run for 4 hours or more normally depending on the options you choose. What do you mean by it runs through cycles is it always changing cycles by itself or is it just the cycle you pick just keeps on going, have you tried a quick wash or 1 hour wash does it do it then? is you hot water hot enough? if not it makes the unit run longer because it has to heat the water up. always run the hot water at the sink to bring hot water up from the water heater to the sing so the dishwasher fills with hot water and not cold.
Dec 28, 2016 | Whirlpool Dishwashers
My whirlpool dishwasher will start to run, then after about 30-40 minutes it will stop working. Normal load time is 1.5 to 2 hours. I have tried running it on all 3 cycles, heated dry, high temp and both....
Sadly this sounds like a logic board problem.
The only other possibility is that there is something on the supply side causing a problem. For example if you have a hot water supply to the dishwasher (unusual but not unheard of) you may find that it runs cold after a while and then your dishwasher has to revert to heating the water itself. At this stage you may think it has stopped but it is simply heating up.
If, in addition, the internal heater wasn't working for any reason, the machine would simply stop.
Have a look at the manual (you can access them here http://www.whirlpool.co.uk/support/instructions-for-use/instructions-for-use.content.html) and check to see if you are getting any fault codes/lights from the machine.
Hope this helps you
Oct 27, 2013 | Whirlpool Dishwashers
Dishwasher ran for an hour and was still on Start. I moved it ahead and it began to smell like something was burning. I turned it off. Should I call a repairman or just get a new one?
You can also try unplugging the unit. Then press the power button after unplugged for an hour. Then plug back in and see if machine resets itself.
Occasionally, dishwashers can run for hours, not finish washing
Oct 20, 2010 | GE Nautilus 24" Built-in Dishwasher
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Soap not used
There are 2 causes for this.
The first is most common, and easy to check. If you have something blocking the door from opening at the proper time, it will never release the soap, and by the time the cycle finishes, it will be locked again. Make sure nothing tall is near the front of the load, especially on the soap dispenser side. Try running it on normal cycle with the dishwasher empty (even take the racks out if you can) to see if it works with no obstructions.
The second cause is much less common, but harder to check. A mechanical failure inside the door could be preventing the trigger from opening the soap door at the proper time. For this, unless you are mechanical, it's best to call an appliance repairman. It requires taking apart a portion of the front door assembly.
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 18, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Stays in wash cycle Whirlpool Dishwasher Du1050SS
the stat is mounted to the bottom of the tub it will read closed if good if it reads open replace it
May 03, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Bosch sgi45e12gb/22 dishwasher won't stop
hey you..I have a whirlpool dishwasher too that would not
stop the wash cycle...it would run for 2-3 hours,
and then run thru the whole wash cycle again!
so..I had a whirlpool factory trained repair man come to
the home. He ran a diagnostic and it was 100% good,
so he called Whirlpool headquarters spoke to them;
said...........every 250 hours the dishwasher will
RE-CALIBRATE itself! running for 4-4 1/2 hours
straight, in order to re-calibrate itself. I was
interupting this by opening the door before it had
run the full 4 -41/2 hours of it's self-maintenance program.
Perhaps that your dishwasher is doing too?
p.s. always make sure you get a repairman that
is factory trained in your specific brand, otherwise
you'll waste $$$ money with a repairman who doesn't
have access to the corporate tech's and direct access
to their parts/inventory.
good luck with your dishwasher!
mine is the whisper quiet with computer control on front
of the door.
Apr 11, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
