Question about KitchenAid KSRS25IL Side by Side Refrigerator
In door water/ice dispenser not working
My Kitchenaid KSBP25FKSS00 was not producing ice. I replaced the icemaker unit and filter. I am now getting ice but can't get ice (or water) to dispense through the door.
Any ideas?
  • 3 more comments
  • galneedshelp Jul 23, 2008
    Sorry...I was on vacation and didn't have a chance to look at it until now. Could you explain the connect part? Where would that be located? There was a connection at the bottom of the freezer next to the filter that was not connected (I was hoping that was the problem). When I connected it, however, it didn't make any difference. Still no indication that the dispenser is working. Thanks!
  • galneedshelp Jul 26, 2008
    It looks like everything is lined up. The icemaker is definitely producing ice but just not able to get the dispenser to work...no water, no ice, and no light at the dispenser.
    Just a slight clicking noise when you push the button but no noise coming from the icemaker tray.. Is there a specific part that needs replacing for the dispenser and is it hard to install?
    Thanks so much for your help so far!
    P.S. There is also no light coming on from the light switch on the dispenser. I replaced the bulb just to make sure that it wasn't burned out. But it seems like there is nothing coming to the dispenser unit.
  • galneedshelp Jul 27, 2008
    Thanks for your help...
    Sergeant:
    Champion:
  • 330 Answers
Check the connect part, see if the gears in the right position.
Posted on Jul 02, 2008
  • 1 more comment
  • Frank Chen Jul 23, 2008
    behind the ice maker, try to push it first see what's happening.
  • Frank Chen Jul 26, 2008
    When you push the botton to release the ice from the dispenser, did you hear a little noise from the ice maker tray, if doesn't make noise, that probably your despendser switch doesn't work right.
    There is no electrity supply, probably the switch had problem, I wish I could help you, if you are a handy person, you can try to fix it otherwise ask the service person.
Kitchenaid french door refrigerator not making ice
Water valve has 2 solenoids. One for water in door and one for water to ice maker. Most likely water valve is the problem b
Sep 16, 2017 | KitchenAid / Architect Series II...
Tip
Ice maker not working
This problem where the icemaker is not working properly is usually broken into sections on diagnoseing the issue of why your not getting ice out of the icemaker. One of the first things that you should check is if the icemaker is getting water to the ice tray. If you are not getting water to the ice tray then the first thing you should check would be your water filter. If your water filter is clogged or dirty you will not get any water going to the icemaker. Following checking the filter and if you still had no water going to the icemaker you would then go around the back of the machine and test the water valve. By using a multimeter you can test the two connectors that plug onto the solenoids to assure that you do have power going to the water valve. Also in some cases you may be able to disconnect the line and clean the small screens on the inside of the valve but most of the time if there is any issue with the valve it is by far easier to just replace the water valve itself. If you do have water going to the Ice maker yet your icemaker is still not working. You can also try defrosting the ice maker by disconnecting the three screws holding the ice maker in place and removeing the entire icemaker and running it under hot water. Sometimes this does help to defrost parts that are froozen in the unit. If after you reinstall the ice maker and you do have water going to the ice maker yet your unit still does not produce ice, and you can feel ice on the inside the tray and you have tried defrosting the ice maker. It is always easier and cheaper to replace the ice maker as a whole rather then buying parts for the ice maker which would cost you about Four times as much as buying a new icemaker
on May 20, 2011 | Refrigerators
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Kitchenaid refridgerator/freezer/icemaker model KBFS5ET5500 EVERYTHING WORKS BUT THE ICE MAKER...JUST QUIT. THERE DOES NOT SEEM TO BE A SHUTOFF VALVE AT THE BACK OF THE FRIDGE. I AM LOOKING TO SEE IF THE...
Hello Raymond,
In a most of cases if the filter were clogged it would affect BOTH the icemaker and the in door water dispenser,its never a bad idea to replace espically if they is a foul odor or taste in the ice or water. The water valve on the back is going to the most likely problem if the in door dispenser works yet the icemaker does not,a lot of times when the water valve is bad when its supposed to be fully closed cutting all water flow into icemaker it stays open a wee bit allowing water to seep through it causing the hose that connects to it ,running up the back wall into the icemaker to freeze up at the top where the tube enters into the freezer,that tube needs to be thawed, and to prevent it from freezing in the future the water valve needs to be replaced.
Goodluck,i hope this helps you to fix your icemaker,
Gene
Aug 09, 2011 | KitchenAid Superba Architect KSCS25INSS...
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
My icemake does not make ice
Hello.
It sounds like it is time to replace your icemaker. It is not requesting water and it is not going to restart once it fails. The part number is 2198597 and it is about 130 dollars. You can try to look around for a cheaper price but don't buy a generic unit. You will regret it.
Jul 16, 2009 | KitchenAid KSBP25INSS
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
351 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
