Question about RIM BlackBerry 7290
Device Error 373 Reset
The device is displaying a message Device Error 373 Reset
How can I resolve this problem ANY CLUE HOW TO RESET THE ERROR 373 CODE?
    President:
  • 1,257 Answers
I would suggest try to upgrade your firmware (if not already at the latest) or wiping it clean and
re-installing but it appears that may not be the fix as the thread seems to
be pointing to corruption.
Resolution Re-install the BlackBerry® Device Software and applications to the BlackBerry smartphone by completing the following steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Double-click Application Loader. The Application Loader Wizard appears. You may need to unplug and re-attach the USB cable to the BlackBerry smartphone at this point for it to be recognized by Application Loader.
  4. Click Next.
  5. Choose the port that the BlackBerry smartphone is connected to and click Next.
  6. If prompted, type the BlackBerry smartphone password and click Next.
  7. The Device Application Selection screen appears. Select the applications to be loaded onto your BlackBerry smartphone.
  8. If the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry smartphone. Click Next.
  9. Click Next. The Completing the Application Wizard screen appears, displaying all the software that will be loaded to your BlackBerry smartphone.
  10. Click the Advanced button and make sure that Erase all application data and Erase all currently installed applications are both selected. Note: If the Application Loader is not able to access all of the BlackBerry smartphone data, then both Erase all application data and Erase all currently installed applications will be grayed out.
  11. Click Next, and then click Next again.
  12. Click Finish. The BlackBerry Device Software is now loaded on the BlackBerry smartphone. Do not disconnect the BlackBerry smartphone until the process has completed.
Posted on Jun 17, 2008
  • 790 Answers
Hello afterhours!!!
Is seems funny but according to blackberry customers , seems the error is fixed by dropping down the phone on a floor!!!
Not sure about the solution .. But y not give a try on a carpet floor!!
Regards
Smilemaker
  • 1 more comment
  • Kanth raj
    Kanth raj Jun 17, 2008
    If that doesn work please try soft and reset whichever fixes your problem!!
    Performing a SOFT reset on the BlackBerry device
    Performing a soft reset stops all applications on the BlackBerry
    device by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. A soft reset
    re-establishes communication between the BlackBerry device and the
    computer.
    Note: This does not apply to the BlackBerry® Pearl™ smartphone.
    Performing a DOUBLE-SOFT reset on the BlackBerry device
    Performing a double-soft reset stops all applications on the
    BlackBerry device and is nearly the equivalent of a hard reset. Timing
    however is critical. Perform a soft reset by pressing the ALT+RIGHT
    SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no
    longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You
    should then see another blank screen followed by an hour glass.
    Performing a HARD reset on the BlackBerry device
    The first step in troubleshooting a network, software or hardware
    error is often to perform a hard reset. With Java® based devices, this
    is accomplished by removing the battery, while the BlackBerry device is
    powered on. Hold the battery out for about 30 seconds, and replace. The
    BlackBerry device will reboot.
    Note: A hard reset on a C++ based device is accomplished by pressing the Reset button.
    Note: To perform a hard reset on a RIM models 850, 857, 950,
    or 957 device, insert the end of a paperclip inside the small hole on
    the back of the handheld.
  • Kanth raj
    Reasons to perform a hard reset
    The following shows the possible reasons for performing a hard reset on a BlackBerry device.
    Network Issues
    • Handheld displays an X beside the coverage indicator.
    • Handheld displays GSM (Global System for Mobile
      Communication) or lower case gprs (General Packet Radio Service) as the
      network status indicator.
    • User is unable to send or receive messages on the handheld.
    Software Issues
    • User receives an error code on the handheld.
    • Applications do not appear to be functioning correctly.
    • Desktop Manager is stuck at “working” status when the handheld is connected.
    • Bluetooth is not detected.
    Hardware Issues
    • Handheld display is hard to read. For example, the display shows lines obscuring text.
    • Keypad is not functioning correctly. For example, keys do not
      work, the trackwheel is not functioning correctly, or the handheld does
      not turn on.
  • Kanth raj
    If my solution fixes your problem do rate me or if you are not satisfied you can repost your problem where other experts can help u more related to it!!
    Thanks for using fixya!!
    Smilemaker
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
Error 322 on my black breey 7290
Trying to find out if anyone can help me with this problem:
I have a Blackberry 7290 that displays an error message "error 373" it also displays "reset" at the bottom. The indicator light is lit continueously red and I'm trying to find out how I can upload my stored information from this Blackberry to my new phone - the Blackberry Bold.
Thanks
Jul 09, 2009 | RIM BlackBerry 7290
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Blackberry 7290 device error:373 reset
Hi Anand
Practically speaking i spent 3 hours looking for your solution but nothing much even the BB intelectuals failed .Try these steps out it may resolve the issue and lets hope for the best .
This error : 373 : Device Error means that the Timers are corroupted
1. Remove the battery for at least 5 minute.
2. Make sure u have working SIM card, other wise remove the old SIM.
3.You should receive an Hour glass spinning. Give a few minutes, after that u will see a 507 message on the bb screen, (which means there is no app loaded on the bb)
4.If this dosent work
Use application loader to wipe handheld clean and reinstall base software but do backup your data
And please let me know .
Apr 04, 2009 | RIM BlackBerry 7290
Canon mp830 error code 5010
Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request
Nov 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Device error 373 reset
the device is nuked! i have lots laying around with same error and i use them for parts! the device is nuked has hardware errors even if you re install the os it still will error out!
Aug 10, 2008 | RIM BlackBerry 7290
Blackberry Rim Error: 373.......HELP!!!!
A reset should allow you to turn the device back on.
Hold down ALT+RIGHT SHIFT(CAP)+DELETE simultaneaously for a few seconds.
Aug 04, 2008 | RIM BlackBerry 7290
I am getting Device error 373... i coudnt acess my mobile..
is there any solution
Apr 27, 2008 | RIM BlackBerry 7290
Blackberry 7290 reset 373
How can I resolve this problem blackberry 7290 reset 373 problem
Apr 08, 2008 | RIM BlackBerry 7290
Device error :373 reset
Bang your device hard on the floor a few times and it will come back to life. Seriously!
I REALLY threw it down hard, and then now, after the revolving hourglass for Many many minutes, it's back up and running.
Nov 20, 2007 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
148 people viewed this question
Top RIM Computers & Internet Experts
Andrew Wright
Trisha
Trisha
asber
asber
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
