I have purchased a Refrigerator bearing Sl.No. TMA083101256 on 8.11.2009 and one year over. The Refigerator is presently under AMC. As advised by your, Engineer, have purchased Stabilizer Model DX1404 bearing Sl. NO. 77112 on 9th March, 2010. Due to the problem in stabilizer (always showing Red Light - both red lights) and refrigerator off most of the time. We have reported this complaint in Aug.10 and stabilizer has been replaced with another stabilizer (repaired one) during Aut.10. Again the same problem occurred on 7th Nov.10 and made complaint thru your Customer Care. Two persons visited my home on 09.11.10 and they have just plugged the stablizer and informed that there is no problem in the stabilizer. In the night, again the same problem occured (both the red lights ON with jerking sound from stabilizer/ refrigerator) and we have removed the refrigerator from Stabilizer. Presently we have given the refrigerator connection directly. We have been issuing Washing Machine of Whirlpool without any problem during the last 9 years. Due to this performance only, we have gone and purchased the Refrigerator and also Stabilizer. We are very upset with the performance of Stabilizer. We request you to kindly replace the stabilizer with NEW STABILIZER and resolve this issue for ever. Hope, you will resolve this issue. Regards Ajith Kumar 72-A, SEctor - 5 Kalpana, Vaishali, Ghaziabad - 201010 - UP
  • Computers & ... Master
  • 20,997 Answers
Nothing will be resolved by writing a letter to us, as we are not they. We are a self help website, but product issues like yours must be dealt direct with the company, not Fixya.
Posted on Mar 01, 2017
SOURCE: dell dimension 5100, power light orange
I have found this kind of problem to be related to one of two things. It will be either the power supply or the motherboard.
Test points to try would be...
Power supply:
When the issue occurs, unplug the power cord from the computer and look for the red toggle switch (it will have 115/230 in white lettering) on the back of the power supply. Toggle this back and forth a couple of times making sure that it is PUT BACK TO THE 115 setting before plugging in and turning on again!!!!!!!!! Plug the power cord back in and if it starts up immediately, the power supply is going bad. This is only a temporary fix as it will quit completely in a rather short time.
Motherboard:
Shut the machine down, unplug the power cord from the computer, open the case and inspect EVERY CAPACITOR on the motherboard. Capacitors are the little round pieces with with a silver top stamped with a letter (T, K, X. Y etc..). Look for ones that are buldging or oozing. It will look like a battery that has gone bad with corrosion. Should you find a capacitor like that you should be able to call Dell and have them replace the motherboard even if it is out of warranty.
One thing to note would be, if your issue happens to be bad capacitors, your machine will just shut down as if someone unplugged your computer without warning. When you start it back up again you should get an error saying your "System was shutdown due to a thermal event". This is the classic tell tale sign of bad capacitors.
Unfortunately either way you will end up having to call Dell for a replacement part of a power supply or a motherboard. Hope for the latter because if it is a capacitor problem, Dell should replace it for free. Plus the motherboard is one of the more costly expenses of computer repair.
Good luck.
Posted on Jan 27, 2008
  • 177 Answers
SOURCE: Acer Aspire 5600 wont turn on.
Ther is only one thing that you have not tried I think. Try to remove the CMOS battery from the motherboard for about 15 minutes and reconnect it. It's a small lithium battery.
Posted on Nov 25, 2008
blulite111
  • 56 Answers
SOURCE: battery not charging
most probably you have an IC problem have a licenced repair man to check on it.
Posted on Dec 11, 2008
Joed911
  • 4338 Answers
SOURCE: e Machine T6534 fails every 6 to 9 months
You are correct in your deduction: If the processor is bad , none of the motherboard would have worked. You probably have a flaky power supply. What symptoms did the PC have when the motherboards were replaced? Lockups, no video, Blue Screens?
I would replace the power supply. The power supply could be checked for noise, but you need an O'scope to do so.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 10, 2009
  • 12 Answers
SOURCE: Freezer with ice buildup and refrigerator not staying cold
If you unplug for a couple of days it will just happen again.
I sounds to me that either the defrost heater has burned out or the defrost timer has quit, locate the timer and see if you can advance it to defrost manually.
The defrost timer is quite easy to replace but the heater requires a lot more skill
Posted on Aug 02, 2009
I have a GE Profile refigerator ( model # PSCS3VGXAFSS ). I have had it for a year. It is still under warrenty. The question that I have is that the ice maker just stoped making ice. It goes through all of...
There is a dual solenoid water valve. One solenoid controls the water dispensor the other is for the ice maker. If its under warranty you should definitely have it looked at.
Sep 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refigerator is not cooling properly. Temp
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 28, 2010 | GE Profile Stainless Bottom-Freezer...
Our Kenmore Refigerator was purchased July 1992. Model # 363-9524720 Serial # L220-16905. Problem: Refigerator runs but freezer section does not freeze and ice cubes are not forming. Food storage area does...
As a start, try cleaning the coils and fan under the refrigerator.
You would not believe how many refrigerators and freezers I've worked on which required nothing but a good coil cleaning. The dirtier these coils get, the less efficient the unit becomes until it reaches a point that it almost appears as if the refrigerant unit is not working at all when all it really needs is a good cleaning.
While you're under there, be sure the fan is running to pull air over the coils to cool and condense the freon inside them.
Sep 11, 2009 | Refrigerators
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Refigerator leaked oil after moving and storage
no if there was oil leaking out then that means the refrigerant has leaked all out. you will have to have it repaired by a service tech.
Feb 22, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice Maker on GE TFX25ZRYD quit working
make sure the water line is not kinked when the refrigerator was pushed back.
Jun 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung rs2630hs
Well, it sounds like your condenser fan motor has seized up and needs to be replaced. I had the same problem and additionally it woudl onhly produce about twenty cubes of ice a day. Best Buy repair guy came replaced the fan motor and within 10 minutes the heat was dissapated from the strip and it started churning out ice agin.
Apr 06, 2008 | Samsung RS2630SH Side by Side Refrigerator
PSC 23 SGRD Not working
1. Can anyone tell me the length of warranty on the PSC 23 GRD SS refrigerator? Purchased in 2006.
2. Water and ice despenser light is on but not working.
3. Both refigerator and freezer temps not working.
Please advise on solution to problems. Thanks.
Sep 09, 2007 | GE PSC23SGR Stainless Steel Side by Side...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
