Question about HP Computers & Internet
I have the HP f2105 and I am not able to copy files onto the f drive...
    Problem Solver:
  • 7 Answers
Dear Marina,
Hp f2105 is a flat panel monitor,you have mentioned that you are not able to copy files to the (f) drive,My question is what is the device which you are trying to copy and what type of files(format) are they and what is the error message you receive.please revert back.
Posted on Jun 17, 2008
I need to plug an HP f2105 monitor into an HP elitebook laptop
Elitebook has a vga port with is 15 pins. If the monitor only has DVI you can get a VGA-to-DVI-A cable. They are cheap and available on monoprice.com Make sure the monitor supports DVI-A
Make sure to check the DVI port on the monitor for the wide horizontal pin with two small pins on top and two underneath. See pic below.
Dec 03, 2012 | HP f2105 21 inch LCD Monitor
Ca i replace the hard drive in a acer aspire one 8'9 with one from a hp mini110? thankyou
Hi
most laptop hard drives are same size 2.5
but the hard drive from the hp may have a different face plate or holder but can easily be removed
also the os system on the hp will not load up and work on the acer
you will have to
either use windows easy transfer to copy your entire hard drive files and save onto spare hard drive
so that when you replace and format different hard drive you can then transfer it back onto new hard drive
or if pre windows 7 os you could use something like norton ghost to copy your existing operating system and files and make a system image and store on spare hard drive then when you replace the hard drive
you boot up with norton ghost and ask it to find the image and restore it to the new drive
Or if your lucky enough to have the operating installation disk or can get your hands on another retail installation disk you can reload a new operating system using the product code which should be on a sticker on the base of your laptop
Hope this was useful to you
Feb 25, 2011 | Acer Computers & Internet
I'm Windows XP... I can copy many files to the Verbatim. But when I try to copy a 1GB+ file, the copy craps out. I Googled and found some Microsoft problem when copying 1GB+ files to external drives, but...
The usual limit is exactly 2GB, not 1GB.
It's a limitation of the file-system used for the directory of the disk-drive, when formatted according to the 'FAT32' specifications.
So, copy all the files currently on the Verbatim to your disk-drive.
Then, "reformat" the external (not the "internal") disk-drive, using the 'NTFS' file-system. This file-system has a maximum-file-size limitation for one file that is _much_ larger than the capacity of your Verbatim.
Then, copy all the "saved" files back onto the Verbatim.
Finally, copy your "large" files onto the Verbatim.
Sep 30, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
F2105 hp monitor went to sleep and cannot wake.
i cannot help you its either your moniter or the vga port at the back of you tower there the only things i can figue out
Jun 01, 2010 | HP f2105 21" LCD Monitor
Im trying to review pics copied onto a dvd-r disc and i can't review them
Are you able to see the files on the DVD? Try copying the files onto your computer first before viewing them.If the problem continues, try to use a different computer because your DVD/CD drive might be having trouble viewing burned DVD/CD(s).
Feb 11, 2010 | HP Pavilion dv9000z Notebook
First one and now 2 vertical lines on my HP f2105 monitor. Would this be the actual screen or a component that drives it? Thanks
Move the mouse cursor across the lines then check if it shows up fine. If it shows up fine, the problem is in the video card itself, not the monitor. It can be caused by VRAM or GPU overheating. Clean the video card thoroughly. Using a compressed air is a good alternative.
Oct 18, 2009 | HP f2105 21" LCD Monitor
Want to use clone hard drive to run XP
Because the HP and Fujitsu have different devices, you cannot clone (or create an image of) the hard disk and expect it to work on the other laptop.
Your best bet would be to copy your data files onto a USB memory stick or an external USB hard drive and plug it into the HP. You can open the files on the USB memory Stick/hard drive to work on them or copy them to the HP's hard drive to work on them.
When your Fujitsu has been repaired you can copy the latest files from the USB memory stick/hard drive back onto your Fujitsu.
Jun 19, 2009 | Fujitsu LifeBook S7010D Notebook
Not able copy folders from able to copy folders across from Passport drive onto PC desktop
hmm..is the drive visible in the my computer panel? and you could do a global search and copy and paste if that goes quicker..
Oct 15, 2008 | Western Digital Passport WDXML800UE...
Computers & Internet Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
