Question about Car Audio & Video
Audi A4 aerial has split. can it be replaced? part number is 921775003
SOURCE: audi 02 a4
I managed to find something in the back of the car above the back seats. I removed the panel above the back window and there is a 3" x 8" black part that is attatched to three wires which presumably run up to the radio and maybe a ground wire. It attaches to the antenna that runs through the back window with metal leads. It is easy to remove both the panel and the part.
I fiddled with it a while and the radio reception goes in and out. It has a circuit board underneath and chips/resistors, etc. Maybe this is one of the "boosters". The replacement part from the dealer is $250 which is ridiculous. It is also a poor design to place this part directly under the black part of the back window which probably gets incredibly hot in the summertime. My guess is the heat fries these parts up good. My guess is the Germans don't have 100 degree heat.
I bit the bullet and ordered this part to see if it solves the problem. I'll keep my fingers crossed.
Posted on Nov 05, 2008
j_del
  • 1586 Answers
SOURCE: Core Support and Radiator Replacement , Audi A4 Quatro 1.8
Very easy - the car is designed to have these parts as being removable for the timing belt service. Opening the car is called the "service position" and involves taking these parts nearly off the car. Use the link below (it's a link to a DIY procedure for doing the timing belt on the car) - it'll show you what to do in order to remove the front clip of the car and remove the core support and radiator.
http://www.audiworld.com/tech/eng35.shtml
Posted on Feb 10, 2009
  • 102 Answers
SOURCE: engine number location for 2002 audi a4
is it a 1.8 turbo or 2.8 V6 or 2.7 biturbo V6 ? on most models what you will be looking for is a 3 letter code like ATQ or APW and is normally on a sticker on the timing belt cover, it is also stamped into the engine on a ledge up high. if no luck there check the owners manual, around the 3rd page there will be a sticker that was put in the book during predelivery inspection this sticker is about 3 inches by 3 inches and filled with id codes for almost everything. If the pdi wasn't done right another copy of the same sticker will be under or next to the spare tire in the spare tire well.
Posted on Mar 24, 2009
  • 21 Answers
SOURCE: Audi A4
Not sure if they've changed it but this is what i do for my 99 a4
First remove the screw in the handle pull, it should be next to where your fingers go.
Pull down on the black piece of plastic and remove the screw form the door
Then remove the screws on either end of the door, one near the door jam on top and one near the other side, same place.
Finally pull up then out and the door panel should come out
Hope that helps
Posted on Jun 17, 2009
SOURCE: Audi A4 need to replace rear brake light on audi a4
Inside the boot is a plastic cap embeded in the boot liner. Remove the cap to reveal a screw. Undo the screw and the whole rear light cluster will come away in a sideways and not rearward direction to reveal all of the bulbs. Hope this helps.
Posted on Jul 11, 2009
My 1999 Audi A4 quattro 1.8 won't go in to gear. I was about to have the whole clutch replaced until someone said to just check the fluid first. But where do I check it and what kind of fluid do I put...
Do yourself a favor and let the dealer check it. Audi trannys are very fussy and 98 is a split year. May be more than one fluid availble.
Aug 09, 2013 | 1999 Audi A4
How do I get the safe code for my 1998 audi a4
Aug 08, 2013 | 1998 Audi A4
1998 Audi A4 trans temperature allways at 350 deg F, what can cause this problem?
bad tranny
low fluid
bad trans cooler
burned fluid
bad torque converter
and the list goes on
go to AAMCO snd get a free quote they will know likedy split and give a fair quote
Jan 10, 2010 | 1998 Audi A4
I have split seats in my audi a4 but bought second
It's simple "They are the wrong application" for what you need done unless you have a welding unit and fabricate the ones you have.
Oct 16, 2009 | 1997 Audi A4
My Audi A4 1.8T saloon has lost aerial reception and every station is unlistenable, my aerial is built into the back window, any idea what the problem could be? Thanks, Jim.
It is probably the stereo.. It could be that the pre-amp (which is a small amplifier on the signal coming in from the antenia) has failed.. With out the pre-amp working the reception will be very poor..
Good luck..
Sep 21, 2009 | 2001 Audi A4
Another A4 cabriolet radio aerial in boot problem
did the aerial rise up when you turned the radio on??
Aug 14, 2009 | Audi Cabriolet Cars & Trucks
My engine cuts off when driving
get a code check done,it could be a crank or cam sensor going down
Jan 02, 2009 | 2000 Audi A4
IS THIER A AUX INPUT FOR A 1998 A4 RADIO
not sure check with manual or talk to a stereo shop i think there is a connection that fits on to the aerial cable. joe
Nov 18, 2008 | 1998 Audi A4
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
