Question about AEG B2100-4 Electric Single Oven
Another element problem...Have just replaced the element in our aeg oven and reconnected as usual. However, on putting the power back on the main oven is not working at all (no light, no fan etc), The grill still works and there is power to the unit, so don't think its a short? Any advice would be appreciated. Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Make sure you have set the time of day. come back if this is no use
Posted on Nov 10, 2010
I have a ZDF20X double oven and the main bottom oven is not heating, The fan and light are working but it is not heating. HOw do I repair this - is it an element and how do i replace ? Thanks v much.
Most likely it is a faulty oven heating element.
You will need to replace the element.
Usually the element is a circular shape which is situated near the fan, normally you will need to remove the back of the oven, Switch off the power at the wall first, locate the element and remove the fixing screws and electrical connections then fit the new element and reconnect.
Only attempt this replacement if you are confident to do so and have a basic electrical and mechanical knowledge.
Dec 11, 2010 | Zanussi ZDF490 Electric Double Oven
Aeg double oven 3210 bu model bottom oven not heating up .
your oven element has failed. it can be changed from inside the oven by removeing the back panel and unscrewing the element, take care not to lose the wires when you disconnect them. other wise you have to take the oven out to reconnect the wires
Nov 09, 2010 | Ovens
I have an AEG Competence Single oven model B2100-1-w The oven is not reaching or holding temperature I have noticed the fan is not spinning
Hi steve sounds like your fan motor is faulty they are not very powerful any resistance in the bearings can stop it starting. oiling the bearings wont help you need to replace the motor also it will have damaged the element no air circulating it will of overheated. an overheated element usually lasts till xmas morning.
Nov 09, 2010 | AEG U3100-4 Electric Double Oven
Oven has gone bang!!
The wires to the element shorted out by not being connected and to close to the metal cavity. This should have tripped your circuit breaker. Before resetting reconnect the old element or put in the new one then turn on power. If nothing illuminates you will need to replace the main control. This is easy to replace but not inexpensive. You can get diagrams and illustrations at www.appliancehelponline.com All parts come with installation instructions.
May 12, 2010 | AEG B2100-4 Electric Single Oven
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
I need to replace the bottom element in my oven
You need to check the heating element for continuity and the thermistor for continuity. Use an ohmmeter or multimeter to check. The element should not be any reading over 24 ohms for a 220-250V supply and not over 12 ohms for a 110Vac supply. A good tip is to take digital photos of the job before starting on removing and testing wiring etc so that you can refer back to it if you have to replace any items or forget which wires attach to any particular terminal etc.
To test and replace the element:
  1. Turning off the mains power to the oven.
  2. Remove the lower back panel. Fan assisted ovens will have a coiled 2 or 3 turn element around the outside of the fan.
  3. Remove the 2 power connectors to the grill element if one is fitted.
  4. Check the element resistance reading on the main oven heating element and not the grill element.
  5. The thermistor or fusible link is located on top of the oven cavity if fitted and has two wires attached to it - most likely to be red and black or both white wires.
  6. Remove the earthing wire to the main oven heating element screw terminal.
  7. Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your oven. Do this from inside the oven cavity itself.
  8. Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
  9. Reconnect the earthing wire to the element screw post.
  10. Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
  11. Reconnect the power cables to the main oven heating element.
  12. Reconnect the power cables to the grill element if one is fitted.
  13. Reconnect the power and check that the element works correctly.
  14. Disconnect the mains power again and replace the rear panel(s).
  15. Reconnect the mains power and recheck that the oven, and if appropriate the grill, functions correctly.
Nov 14, 2009 | Ovens
AEG B2100-4 Electric Single Oven Logo
144 people viewed this question
Top AEG Ovens Experts
Steve Allison
Steve Allison
Sal De
Bee4Mee
Level 1 Expert
Are you an AEG Oven Expert? Answer questions, earn points and help others
