Question about Frigidaire Dryers
I have a brand new Frigidaire FTF5000h dryer that starts, runs for a few minutes and then stops. When I check on it, all the lights are flashing and instead of a time, the display reads "ad". What is going on?
  • 525 Answers
If this is a brand new unit, it will come with a factory warranty. ANY work done on the unit by an unauthorized servicer will VOID the warranty on the whole unit. I would advise contacting the selling dealer and have them send out an authorized servicer at no charge to you. If they are unwilling to help, post me back and I can find you an authorized servicer near you.
If this advice helped fix your problem, please rate my advice on the strength of help that I provided.
Thank you,
Dave E. (Illeagle)
Posted on Jun 17, 2008
I have a DV42H5400 dryer less than a year old that runs for a few seconds than stops. No error code but the cooling light flashes. After a few minutes it repeats the process.
Clothes Dryer Stops and Starts ' HomeTips
www.hometips.com/repair-fix/clothes-dryer-stops-and-starts.html
Apr 23, 2015 - The dryer's heating element works and the motor runs smoothly, But it... and then running the dryer with nothing inside for a few minutes-if it ...
Sep 26, 2015 | Dryers
I have a gallery series dryer and after a short time, maybe 20min, the dryer stops and all the lights on the right side start flashing
Good Morning Catherine Funk, thank you for your post!
From my understanding your Frigidaire dryer will start and stop after 20 minutes, also the lights on the right side start flashing. Could you provide me with your model number, please? You can usually locate it on the door frame of your dryer. With that information I can examine your control board and provide any further assistance. -Matt
Feb 22, 2015 | Frigidaire Dryers
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Dryer will run but will not heat and the lights all flash
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# GLEQ2152ES, will run for a few minutes and then stop and display "AD" with the lights flashing. The "AD" means that your appliance was in an automatic dry mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Affinity Front Loading Electric Dryer. In about 5 minutes of starting the dryer, an error "Ad" shows in the window above the start button. Then the dryer stops and the lights under the "Ad"
I believe that code means auto dry. Lets make sure the lint and dust is clear from the machine. Check all of your wiring out well since is generally a cause. You may ave to replace the thermistor. Have you gotten any other code along with this.
Mar 04, 2013 | Frigidaire AEQ7000ES Dryer
I have a Frigidaire front loaded dryer that is just a few years old. It continually beeps and the lights on the front panel flash and after few minutes it shuts off. How do I fix this problem?
I had encountered issues like your concern regarding the problem Frigidaire dryer. Most of them had contacted the Frigidaire repairman to check and put in a new control board and it works like brand new. Though it costs $100 for the service but this amount will be refunded if you contact the Electrolux and ask for a code to give unto the repairman to cover the cost of the board.
You may contact also:
Chris Polk
Escalation Specialist
Electrolux Major Appliances
chris.polk@electrolux.com
So you may be guided, just send your contact information, and the best time to contact you. He would also need your model and serial number and a file number if available.
I hope it helps ^_^
Aug 26, 2012 | Frigidaire Electric Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Brand new Dryer starts then stops after 15 seconds
Stop what you are doing. It is under warranty. This will be more costs and it is not necessary. It is a mfr problem.
Feb 08, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer runs but no heat
check the air flow sensor is at fault
Jul 01, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
119 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
