Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore range range beeped with teh same sound it does when the temperature is acheived. The display stated F13. I pressed stop to make it stop beeping, and the display is now dark, and the oven door is locked. It seems the oven is hot, and if my spouse didn't turn it off after dinner, it would have been on about 2 hours. that has never been a problem before. What should I do?
Found the manual
1) let oven cool
2) unplugged, replugged, reset clock
3) Held stop button for about 3 seconds to reset the oven door lock.
Still not sure what caused it, but seemed to solve the problem.
Posted on Jun 17, 2008
How do I make it shut up?
You probably have an error conditon. Is anything displayed on the control panel? If it's displaying "PF", that means "Power Failure". Press the STOP or CANCEL button, then set the time. That should stop the beeping (if it's displaying PF). if any other error code is displaying, I would need to know your range model number, and the code that was being displayed.
May 13, 2015 | Kenmore Electric Smooth Top Stove
The display screen on my Frigidaire 30" Freestanding Gas Range Model: FFGF3047LS is makeing a beeping sound and is not respondig. it only showz "F 13"
Hi j3wain520,
This error code F13 description is a bad Clock ERC. Please follow the steps below for you determine whether the ERC or touchpad is defective.
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F13 code comes back (usually accompanied by a beeping sound).
7. If F13 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Sep 15, 2011 | Kitchen Ranges
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Continuous warning Beep & "F3" displayed.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Jul 22, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
When turning on oven it says f3 or f13 err and i can erase it
Apr 06, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Kenmore drop in range code F7
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Oct 17, 2008 | Kenmore Kitchen Ranges
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
313 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
