Question about Zebra TLP 2844-Z Thermal Label Printer
My Zebra TLP2844-z has stopped printing and the red light keeps flashing, I have checked that the labels are still ok, I use the thermal direct printing so I don't need a ribbon and everything is closed as normal. Any help would be great. Thanks
Same problem happening to me. I'm betting that the paper sensor (photocell) has gone out.
Posted on Nov 10, 2010
  • fixerelief Feb 21, 2011
    same thing happened to me just now..and wiping the sensors clean with alcohol wipes did the trick. Maybe yours could work the same.
    best of luck
Zebra GK420T Red light keep flashing
Seems its loosing calibration, try to reset to factory defult setting and it will calibrate with the labels that have at the moment. Please check settings at windows drivers (should be set up at Thermal transfere if using ribbon otherwise Direct Thermal if not using ribbon.
That issue can happen aswell if when sending a job to the printer with wrong settings, it will overrwrithe the previose settings of the printer.
you can untick the setting " use printer settings" at drivers as well.
if you need diferent driver go to www.seagulldrivers.com - this driver let you to resett printer to factury defaults. Hope it helps.Paulo.
Apr 03, 2014 | Zebra GK420t thermal transfer and thermal...
My labels do not print clearly, I have a zebra TLP2844
Check the Ribbon type and adjust the darkness levels accordingly, Wax uses less heat and Resin uses more. Another thing to check is if you are using Direct Thermal Labels as this could cause a clarity problem. Also cleaning the Print head with Isopropyl Alcohol each time you change the ribbon will keep the head in good condition.
Dec 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Every time I print a label, the label comes out.
Have a look at the way the driver is setup, by sound of it you might have it set for thermal transfer, it needs to be set to direct thermal. Thermal Transfer is for the TLP2844. the next time you print will send the changes to the printer
Oct 12, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844
TLP2844 does not support Line mode.
but the LP2844 does.
If you neeed to use line mode change your printer. from TLP2844 to LP2844.
I had this issue last week.
Jan 20, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Error triying adjust labels on zebra tlp 2844
Try to calibrate it: turn off your computer, press the button and turn on, release the button and let progress labels.
Oct 20, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP2844 print output very light
The problem was the power adapter appeared to be not original, instead of the required 20V this one produces 15V, found the original power adapter and the printout looks fine, darkness looks ok now.
Regards,
Edwin van Hek
Oct 14, 2008 | Zebra tlp2844ps Thermal Label Printer
TLP2844 won't print
Hi David,
Default the printer so you have a green light.
Print a configuration label so you have the printer's settings.
Check the document you are trying to print.
If your "normal document" is using PCL, it won't print because you aren't speaking the printer's language.
Make sure you are using a Zebra driver and that the label/media settings match your printer. Look at your direct thermal/thermal transfer setting and your media length setting -- especially continuous vs. non-continuous.
Sep 21, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra 2844 Not printing at all
Antztech,
if the red light is coming on and staying on, it might be a sensor problem. Try pushing on the lid and see if the light goes to green. If it does, it' s the gap sensor. This is how the printer "reads" the labels gaps-the little spaces between the labels. We've solve this in the short term by covering the sensor and manually setting the gap through the programming command prompt,
Mar 28, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
486 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
