Question about Candy 24 in. CD623 Free-standing Dishwasher
My candy aquaviva cd 623 runs the full cycle but does not heat up,the elements are fine,is there an overheat stat in line or is the problem with the programme control dial regards gary
  • garyfixit Nov 13, 2010
    hi thanks for your advice,i have tested continuity of the elements and they are fine but i could not find a thermostat do you know where it is positioned in the unit
    regards gary
  • Candy Master
  • 19,396 Answers
Hi.
If the machine does not heat up, then rather then the element, the most common reason for no heat is a faulty thermostat.
The thermostat can be tested removing it from appliance and reading Ohms at its terminals, or jumping it and running a controlled cycle (the element will overheat in this conditions and cycle must be stopped manually).
To test continuity (read Ohms), set the multimeter to impedance. With the multimeter probes touch the contacts of the thermostat. If the thermostat is good it will read zero or low impedance. If it is bad, then it will have no continuity (circuit open and Ohms infinity, same as in the air).
The element is tested in a similar way. If the element has no continuity, then it is gone.
The timer board is the last part to be tested and replaced. Thermostat and element must be tested first. Before eventually going for the control module, also test wiring to heating system.
Regards.
Ginko.
Posted on Nov 10, 2010
Hi i have a candy 580c condensing tumble dryer no heat when running checked element got continuity checked the stats one is closed ctt the other is open cct ?? any ideas please
CHECK THE THERMAL CUT OFF, THE HI-LO AND THE CYCLING THERMOSTATS BY THE WAY U ARE GETTING THE FULL 240 VOLTAGE, IN SOME UN ITS IF UR ONLY GETTING HALF THE VOLTAGE DUE TO BAD TERMINAL BLOCK OR HOME OUTLET? SOME MACHINES WILL USE 2 SPEED MOTORS IN OTHER WORDS IT USES 120 TO RUN THE MOTOR AND ANOTHER 120 TO RUN THE HEATING CYCLE THUS IF U ONLY GET 120 AT UR TERMINAL U MAY ONLY BE ABLE TO RUN THE MACHING BUT NO HEAT WILL BE GENERATED
Dec 16, 2014 | Candy Dryers
Water is not being taken in on our candy Aquaviva CD 623 dishwasher
First check and see if there is plenty of water coming into the machine by examining the fill hose inself.
You likely will have to disconnect that hose, not at the machine end, the sink end.
Then, find a way to test the wires to the fill valve, should likely be 110 volts when the machine starts, allowing the fill valve to open.
A volt-ohm meter will tell you, set it to over 110 volts on the A.C. setting.
If no power to the fill valve, you may be facing a new timer.
Be blessed.
Jan 24, 2013 | Candy 24 in. CD623 Free-standing...
Candy DWI 160 dishwasher water not heating.
the only things is the TIMER: CAN BE FAULTY, maybe is stuck, not completely the cycle.
Clean the contact with special spray, loose the wires, replace burn wires, or break wires.
May 08, 2012 | Candy Dishwashers
HI THERE I have a candy aquaviva 800 washing machine and it seems to not want to drain all of a sudden, i have taken out the hose at the back and given a good wiggle and sat with it in a bucket while
Your drain pump is dead. Have a serviceman replace the pump. How old is the unit? If it's old enough that it has the old belt-driven style, have them check to see if the belt is stretched or broken.
Apr 30, 2012 | Washing Machines
I need the operating instructions for a candy aquaviva cd623 dishwasher. Can anyone help with a pdf version I can download?
I am sorry to hear that you have problems with a candy dishwasher. I have had two or three pieces they just died of old age.
But seriously on line there is this manualsonline.com
You will most certainly find your candy manual there for downloading free.
Goodluck
kolbrun
Mar 24, 2012 | Candy 24 in. CD623 Free-standing...
Candy aquaviva 1300 no heat while drying
disconnect the unit from the mains supply and remove the lid you will find a thermostat with a red button on it, press this and if you hear a click, problem solved to prevent fault reoccurring always let the dryer cycle finish its self as stopping it early can cause the heater box to overheat.
regards
Ian.
Apr 17, 2011 | Candy Dryers
Candy CD 950
We have sorted it out, we have managed to change the heating element for a new one, I actually asked a Candy Engineer who told us what to do, thanks.
Jul 07, 2008 | Candy 24 in. CD950 Free-standing...
CANDY AQUAVIVA WASHER/DRYER
its either the motor or element gone, remove the back of the machine and remove the wires from each component mentioned. try the element first , MAKE SURE U TAPE UP THE REMOVED WIRES BEFORE TURNING THE MACHINE BACK ON , U WILL GET A SHOCK IF U DONT!!!. if it does not trip , then the element is gone. like wise do the same to the motor. just one more item to check is where the mains cable enters the inside of the machine. good luck
Jan 22, 2008 | Candy AQW130 Front Load Washer / Dryer
Candy aquaviva 1000 es
Are you sure that this not is the cooldown phase of the mainwash? Most frontloaders have this feature.
Nov 28, 2007 | Candy AQUA1000T Front Load
Candy 24 in. CD623 Free-standing Dishwasher Logo
215 people viewed this question
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
