Had tv for about 2 years then went to turn it on one day and the power light dint come on check fuse in plug was not that so took back off tv to check fuse in side tv it had blown so replaced it put back on tv turned it on and the power light flashed for about 1min and then blow the fuse inside again model 42 inch acoustic solutions tv lcd42805hdf
zjut
  • 106 Answers
SOURCE: panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Posted on Jan 01, 2008
skotkolr
  • 558 Answers
SOURCE: funai 32 inch plasma tv
bad components on the power board needs to have service tech look into blown capacitors or transformer on the power board inside the tv.
Posted on May 28, 2008
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
SOURCE: westinghouse 42 inch lcd flat screen tv
only get sound from my 42 lcd screen fro westinghouse, no display
Posted on Feb 21, 2010
  • 8457 Answers
SOURCE: acoustic solutions tv lcd32762hdf will not turn on
Power Supply board is dead.Replaced the power supply board.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 17, 2010
TV will not turn on, 3.15amp fuse keeps blowing on power board
I have an ln40b630n1fxa and my fuses keep going out as well i took it all apart and seen nothing blown. What would be my next step
Nov 06, 2012 | Samsung LN40B630 40 in. LCD TV
Samsung sp-r4232 power button blinks 4 times but tv wont turn on
I have this TV. My father in law tried to turn it on one day and it started making a clicking sound and never came on. So he went out and bought a new tv and gave it to me. It came on when I brought it home and worked for a couple weeks. Then just the other day it stopped working. When you hit the power button the light around it blinks four times and then you here a clicking sound. TV does not come on. Took the back panel off and I don't see any damaged caps or fuses. b435b80e-6d09-419f-a021-9b8a430e0a74.jpg
May 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
No picture, no sound, power light steady green
First: Check the power outlet. Check it with a good lamp so you know you are getting power to the set.
Secondly: Check the power cord. Wiggle it around the molded ends to make sure it is not open inside the molded portion of the plugs.
Thirdly: If you know for sure the set is getting power and still no indication at all (you should be getting some little light on the front panel; standby indication) then there may be a fuse on the back panel or just inside the back cover (you will have to remove it; after unplugging the power cord) that needs replaced.
Fourthly: After all these checks if you are getting nothing, you may have some failure inside that is very serious. Normally we do not recommend serious repairs to a set over 4 years of age. This is because the set is likely to develop some other problem soon after the repair is made; further, the repairs are getting more expensive day by day while the price of new sets is coming down dramatically. Lastly, the new sets have better picture, longer lasting circuits and better features.
Hope this is a good solution for you.
thanks for your questions.
Aug 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
NO POWER
Viewsonic's are typically well built. Are there any lights on? If you've already sit for a while and then plugged it back in and still nothing, pop the back off again and see if there are any blown (popped up) capacitors on the power supply. Maybe it took a light surge. If there are any bad caps, they usually only cost around a dollar a piece to replace.
We had 2 42" Viewsonic's that get used every day go through a building surge while one was on and it still works great a year later.
Apr 26, 2008 | Panasonic CT-32SL14 32" TV
Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Ge model 46gw945
NEED SOME TECH EXPERIENCE ON THIS--- UNPLUG THE TV,,,I REPEAT ,UN PLUG THE TV FROM AC---TAKE THE BACK OFF--CHASE
THE CORD THAT GOES INTO TV AND YOU SHOULD SEE A SMALL 5 AMP FUSE IN A HOLDER,,CHECK TO SEE IS IT;S BLOWN--IF SO ,,REPLACE IT WITH"""THE SAME FUSE""""""""""" ,,AFTER REPLACING --REPLACE BACK OF SET ,,PLUG IN AND TURN POWER ON,,IF IT STILL DOES NOT COME ON --CALL A SERVICER,,,,,IF IT WORKS ,,,,,,,,,,,,,YOU OWE ME 35.00--HA!!!!!!!!!1
Feb 09, 2008 | GE 46GW945 46" Rear Projection Television
Television has no power
check the fuse. The person i got mine from said it was dead. i took it home opened the back and the fuse is very obvious replaced it with a slo-blo fuse and its back to normal!
Dec 15, 2007 | Panasonic CT-32SL14 32" TV
Will Not Turn On
hi,
iandojay
check PW suppy is ok check all voltages in the micro controller IC
Dec 05, 2007 | Televison & Video
TV doesn,t turn on
the power regulater for your system have a short take it to a tech to have him fix it orelse you might cause further damage.
Feb 17, 2007 | RCA P46812BL 46" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
