Question about Car Audio & Video
What is the best tramission oil to use in Audi A6 5 speed manual gearbox
  • 6,826 Answers
Manual Transmission Lubricant
Manny manual transmissions use gear oil viscosity of about SAE 80W or 90
grade. This is a gear oil viscosity and has nothing to do with motor oil
viscosity. For instance, SAE 80W gear oil can have the same viscosity
characteristics as SAE 40 or 50 motor oil.
However, not all-manual transmissions use gear oil. For years, Chrysler
Corporation specified the use of automatic transmission fluid in their manual
transmission vehicles. Some transaxles, both foreign and domestic, use either
ATF or engine oil to lubricate the transmission. For this reason, it is always
best to consult your owner's manual or your dealer if you are unsure about what
sort of lubricant to use in your manual transmission.
Posted on Nov 10, 2010
  • Duane Wong
    Duane Wong Nov 11, 2010
    Thanks for the rating.
Tip
How to change (check) AUDI transmission oil
Transmision oil for Audi A4 (1.8, 1.8T, 1.9 TDI):
Manual gearbox (5 speed):
- Capacity = 2,25 liters
- Specification: Gear oil SAE 75 W 90 (synthetic oil)
Part number G 052 145 S2 (1 liter)
- To check oil level, unscrew oil filler plug placed on the left side of the gearbox in front and near of transmission axle, using an Allen 17 mm key.
- Check oil level with locally manufactured tool, e.g. a piece of angled wire.
- Specification: oil level 7 mm below bottom edge of oil filler hole.
- Install oil filler plug, tightening torque = 25 Nm.
on Dec 19, 2009 | Audi A4 Cars & Trucks
Car manual repair
Here is a break down of the gear box for your Audi A8
AUDI A8 A8 FAW VW 1996 GEARBOX 30140 GEAR HOUSING FOR 6 SPEED MANUAL...
I hope this helps and good luck!
Sep 27, 2015 | Audi Cars & Trucks
What kind of oil go's in Tramission stander 5
In the transmission dipstick are the required type, its ATF+4,
Mar 17, 2012 | 2000 Jeep Cherokee
What kind of transmission oil carries the manual aidi a4 2000
The transmission oil type for Audi A4 MY 2000 with manual gearbox is:
Synthetic oil SAE 75 W 90, part number G 052 145 S2 (1 liter).
Example:
Castrol Syntrax 75W-90 Full synthetic SAE 75W/90, API GL5. manual transmission, transaxle and rear axle lubricant with outstanding extreme pressure, synchroniser and high temperature performance.
Oct 16, 2010 | Audi A4 Cars & Trucks
What type tramission fluid to use for 5speed manual-4cyle?
1992 Ford Ranger came with two different type of 5 speed stander transmission's that year.
For a Mazda stander trans it take's Automatic transmission fluid Mercon.
for a Mitsubishi stander transmission it take's Ford manual transmission fluid.
Hope this help's.
Jun 28, 2010 | 1992 Ford Ranger
TYPE OF GEAR OIL FOR AUDI A6 TYPE CPE NR. WAUZZZ4AZSN064658
Manual gearbox- SAE 75 W 90 Synthetic. Auto Gearbox- VW ATF only available from Audi dealers. Differential SAE 75 W 90 Synthetic.
Jun 03, 2010 | 1996 Audi A6
2001 audi a4
Transmision oil for 2001 Audi A4 1.8 l turbo:
Please Rate my Response! Thanks!
Sep 27, 2009 | 2004 Audi A4
Transmission
Well, I'm not sure. Try changing the gearbox oil and try again. I saw on the other postings that most Audi gearbox problems pointing to a gearbox swap can be solved through oil change. I just had mine changed and it has reduced sluggishness and shuddering at low temperatures (from cool engine). It's a special gearbox oil you need to get from Audi, by the way.
Jun 14, 2008 | 2001 Audi A6
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
