Question about Sony KDF-E55A20 55 in. LCD Television
Kdfe55a20 The red led light blonks 4 times when I turn the tv on. Any ideas?
  • Dave Bies
    Dave Bies Jun 17, 2008
    This is a fan problem. One or more of the fans is probably not spinning.
    Novelist:
  • 135 Answers
Some of the fans are encased in areas you can't see. If you have a meter and want to determine which fan is in failure, you can find the small 3 wire fan connectors and measure the voltages on the wires.
Black wire - Ground
Red wire - 12v
White wire - 5v (RPM wire)
Zero (0) volts on the RPM wire means the fan isn't rotating. You will only have about 10 seconds or so to check the fans, so measure quickly and turn the TV back on to measure the ones you missed when it shuts down. Even a rotating fan can have a bad RPM sensor internally to the fan.
NOTE - these fans operate the same way they do in computers, providing rotation RPM to the motherboard for monitoring.
Posted on Nov 14, 2008
  • 320 Answers
You are correct that a 4 flash is a fan problem. It could be that one or more of the fans is not turning, I have also seen a failure of the fan rotation sensor that tells the TV that fans are turning cause this problem. Lastly, in rare cases a power supply problem can cause a 4x failure, when the supply for the fans fails.
Posted on Oct 28, 2008
Kdfe55a20 won't turn on at all It's a Sony
which LED lights on front are on and or blinking?
If the red or others blink look to see if they are blinking a specific number of times--like red one blinking 3 times, pause and repeating--this is a error code and may indicate what problem in set is.
Apr 24, 2012 | Sony Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Got a new lamp tv works great but wen I turn it off it has a very quiet hum is this normal also wen I turn it off the.red.light blonks green for a while befor eventualy going away what dose this mean...
Hello; The noise when turning set off is likely the fan that cools the lamp down gradually. The lamp can crack if the fan does not work. Dust in the fan can also add to the noise. When the set is turned on, the microcomputer watches the lamp come up to full brightness and shows this with the LED colors. All lamps containing mercury take time to get up to full brightness.This also applies to mercury compact florescent lamps, yard lights, and even neon signs that contain mercury.
Jun 07, 2011 | Toshiba 52HM95 52" HDTV Projection...
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
Mar 05, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Thomson scenium LED error code 45
When i turn it on red light flashes 3 times then 1 time, this keeps on repeading, no sound, no light
Sep 30, 2009 | Televison & Video
Sony kdfe55a 20
2 YEAR IS TIME TO RPLECE LAMP
Mar 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Where is the thermal fuse located and how can I replace it on a Sony Grand Wega model KDFE55A20?
It's actually pretty simple to replace.
Go to
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70
and request the troubleshooting package. It has step by step on how to replace the thermal fuse and where to get the parts.
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
Mar 27, 2008 | Televison & Video
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Oct 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KDF-E55A20 55 in. LCD Television Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
