Question about Home
We have lived in our flat for 3 years and have had to replace the fuse for the bathroom fan 4 times in the last few days!!!!!! It makes a pop noise. We are not using anything else nor have we changed anything. It was fitted with a 3 amp fuse which is what we are replacing it with. Is this strong enough? Help!
  • 557 Answers
This are mostaly internal electric problem buy new one
the fuse 3amp are good for the fan
i think the motor bearings are goin and the motor are in unbalance.
Posted on Nov 10, 2010
Why no picture, no sound?
A loud "pop" in any electronic device is the equivalent of a massive heart attack for a human. They normally don't survive them. The noise is from some capacitor somewhere in the device exploding from old age or a power surge. And old age for newer TVs is in the range of 3 years, some even less. It's the way they make them these days...they want you to be buying a new one in just a few years, so they under-engineer the electronics to the bare minimum so they don't have the long-lasting lifetime of the older style electronics we have come to appreciate.
Feb 19, 2016 | Toshiba Televison & Video
My vizio VO47 L has a black screen and sound. I do get a light on the vizio logo on the front. I see no illumination coming out of the back of the unit. what is wrong?
Power Supply popped a cap and fried the metal resistor bank. Replace the cap C241 and solderer the resistor bank. Worked for two months then pop out again. This time the resistor bank burnt through. Bought a new power supply DPS-38cp-1a from ShopJimmi.com $56.00 Replace supply which lasted 1 year 1 day and the same thing happen. Same components. Got this TV free but its costing me time and money now.
Oct 24, 2012 | Vizio VO47L 47 in. LCD TV
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
The 12 volt battery(LUCAS 065/3) on my FORD FIESTA 1100cc is 4 years old, in that time i have only driven 1,600 miles as my journeys are usually very local. I make sure i use the car twice a week to keep...
Running so few miles has accelerated the aging of the battery - the battery never had a chance to fully recharge in such small trips -  so now you have to replace it a year sooner than usual.
Just replace it.
Aug 28, 2010 | Ford Escort Cars & Trucks
Last year my gable fan seemed to work fine. I
As it's protected by circuit breaker it also might be fused, so check for fuses.
Next just dig to the wiring and measure the resistance betveen Live and Neutral using simple multimeter. If there's no reading then there might be a small fuse (or thermofuse) attached to the windings, make sure this one is fine, if yes then motor windings are burned and you'll need new fan, otherwise just replace the fuse.
Good luck
Jun 24, 2009 | Gable (53315) Wall Mount Fan
3 amp fuse blowing in York central A/c
a blown fuse is a sign of a short circuit. either connections are touching each other or a relay is busted. Have it checked. Have the system leak checked also, this would result to better cooling/heating and energy savings.
May 13, 2009 | Heating & Cooling
Turn signals flash sometimes other times they just light up
replace flasher, or switch with emergency flasher to test.. Should be in with fuses or in that area.
Jan 30, 2009 | 2000 Ford Explorer
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
55 in Sony KDF55WF655 Goes to standby and red light blinks 4 times
Check the thermal sensor fuse part# 1-910-023-93 or possibly one of the four fans. If the unit goes into Fan/Thermal Protect shutdown (4 blinks) it can be difficult to determine the cause since the unit turns off too quickly to troubleshoot. Solution: Ground the data line by inserting a jumper between pins 3 and 6 of CN44 on the H4 board. This overrides the protection circuits for troubleshooting. Do this right after turning the unit on and as soon as the lamp is seen lighting. Check pins 2, 5, 8, and 11 of CN6000 on the G2 board for less than 1VDC. Any voltage higher than that indicates a faulty fan. If all voltages are within specs, the H4 board must be replaced. If a fan is found defective, the optical block will need to be replaced if it is located inside the assembly. H4 Board Part Number: A1054674A Replace the following part based on which pin of CN6000 is out of specs: Pin 2: Fan 1 (part of optical block) Pin 5: Fan 2 178723211 Pin 8: Fan 3 178706511 Pin 11: Fan 4 178708111 Optical block Part Number: A1084662A
Aug 26, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Home Logo
148 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
