Burn 2 resistor near at the relay what is the value of resistor
    Genius:
  • 1,112 Answers
Hi:
You can only find this out by purchasing the schmatic diagram.
Try www.servicemanuals.com
Posted on Nov 10, 2010
LG crt tv 21fs4rge-TS resistor R407 burnt i don't know the value
A burned out resistor means too much power has flowed and burned it out.
you need a schematic to find the resistor value but also what other parts have blown as I can guarantee just replacing the resistor would just mean another burned out resistor.
Jun 16, 2018 | LG Televison & Video
How i can recognize the value the 2 resistors that were burned.
Measure The Resistance Of Each Resistor With A Digital Ohm Meter, If They Still Read Value, The Original Value Is Much Much Less..What Circuit Did TheyCome From ?
Sep 10, 2014 | Televison & Video
Resistors value was burned
Your can still get the value of the resistor by testing the half and one lead of the resistor and then plus it to the other side. So your will see the resistance. Then look at the standard chart will is near to that value.
Sep 24, 2011 | Sanyo Televison & Video
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
I have a konzert amplifier av-502 that has two burnt resistor r130r and r130l. could you please let me know the value of the said resistor thank you very much.
Is it the resistors near the relay? that would be 10 ohms. You may replace it with a higher wattage (like say 5 watts)
Aug 02, 2010 | Audio Players & Recorders
I have a Minwa MW79 7 output A.C-D.C adaptor it has 3 resistors and one of them has burned up so can you tell you me the value of each one of thous resistors
I have the same adapter and the same problem, the 2 smaller once are ok, the bigest one inbetween capacitors diodes and transformator is burned out it is so hard burned that it cannot be read if you may be have this one OK can you read the values? i could read the two smaller ones
Jan 22, 2010 | RTO MINWA MW-222 DELUXE Battery Tester
Burned resistor, need value for replacement
I re-drew the schematics from the PCB-layout and did some backward engineering to determine the resistor value. The machine is now again in excellent working order.
Jan 20, 2009 | Sewing Machines
Resistor identification
Hi fccjben;
The color code is as follows: blk = 0; brn =1; red = 2; orange = 3; yellow = 4; Green = 5: blue = 6; violet=7; Grey = 8; white = 9
Unfortunately, if it is wirewound, they usually printed the resistor value on the body of the resistor. For sure it shouldn't be glowing. Sorry I can't be more help, but without a schematid, can't do much else
Good luck Loringh
Nov 26, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Burned resistor... no clue what is its value
brYze,
take a look and get the resistor number printed on the pcb. i might be able to give you what you're asking for.
Francis
Aug 31, 2008 | AOC 4 Vn 14" CRT Monitor
PHILIPS 43PP920217 DPTV305 PROJECTION SET
those are 6.8 ohm 1watt metal film resistors 5% tolerance
Jul 22, 2008 | Philips 43PP9202 43" Rear Projection...
 Grubhead
Grubhead
Marvin
Marvin
