Question about Microsoft Windows XP Professional
Error Report (send-Dont send issue)
I Installed a game called Virtua Tennis 3. But when i try to run it that annoying error report thing comes up. I have a config that matches the minimum config of the game. please help
  • 4 more comments
  • lethalweapon
    lethalweapon Jun 20, 2008
    Hi it was helpful
    i turned off the error reporting but the game still doesnt work..................Its seriously irritaing............Even Now the game doesnt start.......It just comes on and goes off in a sec except that now there is no error report.
  • lethalweapon
    No haven't applied patches.......................
  • lethalweapon
    lethalweapon Jun 21, 2008
    The game requires a 2.0 Ghz P4 processor
    I have a intel dual core 1.8Ghz processor
    u think that will cause problems??????
    Waiting impatiently for reply.............Will be very very grateful for a reply
  • lethalweapon
    its the minimum
  • lethalweapon
    Thanks...............if thats the case i may as well upgrade my pc..........isnt there any way to work around it though you know............change the coding or something to make it work............................THNX A LOT...............
  • lethalweapon
    K THNX
    Guru:
  • 859 Answers
You turn error reporting off.
You need Administer privileges to do this.
1) Right click My Computer
2) Click on the Advanced Tab
3) At the bottom right of the resulting property sheet click on Error Reporting
4) Select Disable Error Reporting and deselect 'but notify me, etc.'
This is a persistent setting unless you "Reinstall your OS" in that case you will need to do steps 1-4 again.
Restart your system.
You should be able to run the game at any configuration you want. Take a look at the settings in the game to see if it sends you error messages but I bet you've done this already.
As always make sure you are using the latest set of drivers, not Beta, for your Display Adapter.
Regards,
Worldvet
Posted on Jun 17, 2008
  • 4 more comments
  • Glenn Rogers
    Glenn Rogers Jun 20, 2008
    Did my instructions help you remove the error reporting?
    If so, would you please rate this a fixed. I do appreciate the Helpful rating, but we here who also work in the free area do appreciate the your rating a solution Helpful. It does mean a lot to us. If we have fixed you problem let us know by rating it as Fixed or let me/us know if it hasn't completely resolved the problem so I/we can assist you further.
    Thank you for your consideration,
    Worldvet
  • Glenn Rogers
    May I contact you tomorrow with an answer?
    Have you applied any game patches to this already?
    Thanks,
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 21, 2008
    Thank you for your patience. As I run my own business from a home office Fridays can be and has been a very busy day. Thanks for posting your current CPU and the Game requirements.
    To answer your last question, when it specifies the 2GHz CPU is that the minimum system requirements or the recommended system requirements.
    I'll be online for awhile.
    Regards,
    Worldvet
  • Glenn Rogers
    Hi, and thanks for your patience again, its been a really long day and a full slate tomorrow but bear with me while I give you something to go on below.
    If that is the minimum, most likely the following is happening and why you are getting the error report.
    The game installers today can and do inspect your motherboard for a report on what is and isn't installed in your system. This is called a bios query in programming terms. When it receives information that falls short of the game requirements you get the error report you are getting because your CPU is just under the minimum game requirements. You could, in the long run, look for a used copy of a previous version (if one exists) on Ebay.
    I would bet the manufacture my dollars to their dimes the game would still run on your dual core processor, but the program isn't smart enough to compensate for that CPU design only what the core speed is. Thus, you will not be able to install it.
    Unfortunately, game software is a problem to return but depending on where you purchased it and their policy, they may take it back and at least give you store credit; you could argue and bargin for at least that with a manager who has the power to offer it to you, the clerk at returns won't. Again, they may not at all. It is the problem because of pirating and returning it will be a problem you might be able to hurdle as I just suggested... demand a manager at returns but be polite.
    If you are using a laptop/notebook you're stuck with that CPU. If you have a tower pc or pc you may be able to upgrade your CPU if you want to play the latest game titles in the future or even today for that matter you will need to do so.
    If you have a tower or just a PC let me know. If you have a computer shop near you you trust or another a friend or neighbor who can recommend or even your chamber of commerce can sugges you could have them upgrade yout. We also have a repair shop locater in our home page link where you put in your zip code.
    You may be able to do this yourself too with some guidance from a book like PC Upgrading for Dummies where everything is written in plain English and not geek speak.
    We here, would also guide you in upgrading your CPU yourself, just be aware it is full of black holes and require care and patience as well as guts to do this yourself the first time and a couple of tools.
    Sorry again for the delay and really sorry it took us so long to disappoint you with this news.
    Looking forward to your reply.
    Worldvet
  • Glenn Rogers
    Sorry no, you can't trick it out, we've all tried at one time or another.
    Me, I've been waiting for certain game titles to come out and built a new machine myself buy parts one at a time over the last year to have a dual core AMD 5200, etc. etc. ready and waiting.
    Best of luck and let us know if there is anything further we can do for you.
    Regards,
    Worldet
  • Glenn Rogers
    You're welcome.
    Master:
    Sergeant:
  • 460 Answers
This can be solved only if u upgrade ur pc or reinstall your OS..!!!
Thankyou
On starting gta san andreas, the error report pops up. everytime i click on dont send but next time same happens again. what to do???
Doesn't matter what you do when error report comes up. Difficult to know actual reason for this. Did you try reinstall?
Btw looks like this is very common problem.
Here, check posts #10 and #15
http://steamcommunity.com/app/12120/discussions/0/846965882796200781
Jun 09, 2015 | Rockstar Games Grand Theft Auto: San...
First i have same pentium p4 i played total overdose its great working then after few days i intalled new windows xp on my pc and installed total overdose and played then after some time it automatica
Win XP is not powerful enough for games due to the lack of the amount of memory that can be installed.I guess you had the 32bit version and that is the main problems running apps or games with not enough memory..
Dec 12, 2011 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Game problem
Does your system meet the necessary specifications to run the game ?
Navigate to this website to see whether or not your System supports this game.
Also consider downloading the latest Direct X and your newest display driver for your graphics card.
Jun 04, 2010 | Microsoft Windows XP Professional
I've installed the latest version of msn yesterday. 5 seconds after i sign in i get the ''Windows Live Communications Platform has encountered a problem and needs to close. We are sorry for the...
Although the solution is being posted months after the question is raised, let this help others having the same Dr.Watson issue.
For this, you can ignore the Error Reporting window, or turn off error reporting so it wont dump your windows drive with GBs of unwanted error dump data. If you are good with Registry Editor, follow the steps below:
Open your Registry Editor and browse to
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionAeDebug . Create a new string value (REG_SZ) with name 'Auto' and enter its value as 0, so error reporting gets disabled.
May be this article should help you.
Oct 06, 2009 | Microsoft Windows Live Messanger
Trying to set up fax to print when sending fax
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
● Every fax error (the factory-set default)
● Send fax error
● Receive fax error
● Every fax
● Send fax only
● Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
Sep 24, 2009 | HP LaserJet 3390 All-In-One Printer
Problem With My PC
When did it first start happening?
Do you have restore points activated? Try restoring your machine to an earlier date to see if it fixes the problem.
Feb 05, 2009 | Microsoft Windows XP Professional
I cannot signed in to yahoo messenger even my wife and my kids
uninstall yahoo messenger and re-insall again.
Nov 19, 2008 | Yahoo Messenger
Diablo2 installation problems
Well no doubt that the game you downloaded is not good, i mean the game itself maybe its something in the burn, maybe in the extract... download another file of this game or buy it, the game is really old, whats mean that its really cheap.
Jun 07, 2008 | 2007 Lamborghini Diablo
Guitar hero 3 for pc
Can you let me know what's your operating system?And another please make sure you have all of these installed on your pc/laptop..
.Net framework 2 or 3..
Java..
Microsoft visual c++ 2005
Goodluck..
May 16, 2008 | Video Game Consoles & Games
Send error report
there is not necessary to send the error reports
Oct 08, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional Logo
593 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
