Question about Tunturi T85 Treadmill
Tunturi T80 treadmill comes up with 'system check fail error' when turned on and will not operate. What could the problem be?
SOURCE: TUNTURI 620p TREADMILL displays 51, or S1 WHEN
Solution:
press and HOLD the button that says display above it and Reset below it untill you see the normal start up Screen and yoru good to go!
Posted on Apr 22, 2009
SOURCE: Abrupt stop Tunturi J 660.
I am all set. I located a Tunturi service person in my area. We have an appointment set up. Thanks for following up. I. Hazelhoff
Posted on Jan 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: IHAVE A TUNTURI 800 TREADMILL THAT IS ABOUT 18
Call Accell Fitness of North America they are a Tunturi distributor: Call 1-800-388-6887 they should be able to tell whether parts are available for your unit
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 33 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Your problem could be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
System check failure
You can completely switch off the power for a few minutes and there is also a 'reboot' button at the front/bottom of the treadmill that needs to be pushed for about 5 sec (check manual). In my case that did not work and I had to replace the complete control panel/dashboard. My problem was different, I got funny messages about errors and flashing numbers on the dashboard. Tunturi was helpful in getting me the necessary spare parts. Good luck.
Mar 30, 2014 | Tunturi T60 Folding Treadmill
Not working after initial start up.
is the new outlet the same as the old or did you put a adapter on the plug? sometimes if the machine does not "feel" the ground, it wont come on.. its a safety thing..
Mar 08, 2014 | Tunturi T60 Folding Treadmill
Have a J620P and just received a 51 code. What is it, and how do you fix it?
Follow the next step:
Scan by 3 seconds for to clear the error the display and restart the treadmill
If the error Do not appear,continue.Electrical fluctuation can be have actuated in the system electric power, and cause the display error.
If the problem persist call:206-881-7392 tunturi treadmill
God bless you
Oct 01, 2013 | Tunturi Exercise & Fitness
Tunturi T85 data transfer error
Yoy need now lower power board
Dec 29, 2012 | Tunturi T85 Treadmill
Tunturi t80 treadmill gives check lubricant message after multiple times of lubricating the belt
RESET the machine. Use your owner manual read section troubleshooting and proceed according.
God bless you
Aug 02, 2012 | Tunturi T80 Treadmill
System check failed
  • Press the "On/Off" switch to turn the treadmill off.
  • 2Unplug the power cable at the bottom, base of the treadmill.
  • 3Push the safety switch in.
  • 4Plug the cable back into the treadmill and set the "On/Off" switch to "On."
  • ssincerely. Merry Christmas.
    ERNESTO CUADRAmanagua, nicaragua
    Dec 26, 2011 | Tunturi T80 Programmable Treadmill
    My tunturi treadmill 661f is showing E1 on the
    May 16, 2010 | Exercise & Fitness
    My Tunturi J620P stops and E-1 shows in display
    Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the powerswitch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
    May 14, 2010 | Exercise & Fitness
    Speed sensor error
    Your speed sensor may have failed and cause this condition Call Accell Fitness Of North America @ 1-888-388-6887 they are the Tunturi Distributors
    May 04, 2010 | Tunturi Programmable Treadmill with...
    Open Questions:
    See all Tunturi T85 Treadmill Questions
    Tunturi T85 Treadmill Logo
    352 people viewed this question
    Top Tunturi Exercise & Fitness Experts
    gbob59
    Marvin
    Marvin
    Harrie
    Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
