Question about Car Audio & Video
HOW TO CONNECT SUB WOOFER IN 4CH CAR AMP
PLEASE ADVICE HOW TO CONNECT A SUB WOOFER ON A 4 CHANNEL CAR AMP, ALREADY CONNECTED 4 SPEAKER IN EACH CHANNEL
    President:
  • 624 Answers
Sounds like you need another amp, if the amp has a speaker already connected to each channel, you have no open channel to connect a sub-woofer.
Some years ago I seen an amplifier that was designed to use 3 speakers on 2 channels. what they did was had a speaker on each channel and then they bridged the 3rd speaker across it. That amplifier was designed for this configuration, unless you have an amplifier like that you should not try it. It may result in smoke from the amp.
Posted on Jun 17, 2008
I need a wiring diagram from car stereo to 2 x 6 " x 9 " and a sub woofer please
You can connect the two 6x9 speakers to the two individual left and right outputs of the car stereo.
Connect each of the left and right channel with the correct polarity . Now the Sub-woofer requires an amplifier to be connected separately and so you need to use the car stereo to be linked to a sub woofer amp which powers the sub woofer.
Mar 26, 2011 | Car Audio & Video
What is the best way to wire four 6" 55 watt
My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
dreamsystems.
Feb 10, 2011 | Clarion APX490M Car Amp
I have a power acoustik 0V4-1200 amp and 2-12" kicker cvr dual 2 ohms. My amp keeps getting really hot and turning off. I have two pair of rca jacks from my cd player to the amp. One speaker hooked up...
i have found the specs to your amp. 1. Amplifier connections: Lets make things simple. As we look at the amplifier speaker connections, we will number the outputs 1 2 3 4 from left to right for the top connections and again 5 6 7 8 from left to right for the bottom connections. 1 should be connected to a positive (RED) (+) on sub woofer A on voice coil (a) 4 should be connected to a negative (BLACK) (-) on sub woofer A on voice coil (b) Now using a small piece of cable, connect negative of voice coil (a) to positive of voice coil (b) Follow the same procedure for the other sub woofer using 5 and 8 as 1 and 4 This configuration should make the amp run at 4 OHM BRIDGED x 2. i hope this helps. dreamsystems
Feb 07, 2011 | Car Audio & Video
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
Hi,just bought a 6x9 jbl gto937 speakers for my car,each speaker is 100watt rms and 300 max .Can anybody advice on what amplifier should i get for them?I know i can run them without any amp but think they...
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
Jul 05, 2009 | JBL GTO937 Car Speaker
SOLID AUDIO F-45 4CH 900W ONE OF THE FRONT CHANNELS ...
HI DUDE TRY TO CONNECT ONLY 2 PC OF UR 6x9 AT FRONT CHANNEL TRY IT OUT COZ IT MAYBE THE DONT HAVE MUCH POWER TO HIT VOLUME OR ELSE TAKE OUT UR SUB CONNECT TO FRONT CHANNEL OR CHECK UR SUB VOLUME .,...
Apr 01, 2009 | Solid Audio Formula Series F45 4-Channel...
Home theater system protection kicks out
Nice write-up.
http://www.sherwoodusa.com/pdf/RD-6500(English).pdf
On page 6 of the manual it states you should use a powered subwoofer and the unit provides a sub output on the rear panel for it. The message from the amp kicking out is that you're not going to get away with your workaround.
I would advise you to purchase a nice amplifier (2-channel bridgeable or single channel) for the subwoofer. That way you'd be sending only LFE signals and your receiver has provisions for adjusting its volume relative to the rest of the channels. I use a nice 5-channel Carver for my 3 subs and both Rear Surrounds.
On eBay I see what I would get if I were you - a Carver M-200T (120W x2; 300W bridged). I have one.
http://cgi.ebay.com/Carver-Magnetic-Field-Power-Amplifier-M-200t-120WPC-Amp_W0QQitemZ200327110781QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item200327110781&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
Mar 02, 2008 | Sherwood RD-6500 Receiver
Sub woofer freq prob
Without hearing the noise, it's difficult to determine the exact cause. I've seen enclosures do this if the panels were not glued together well.
Try connecting the speaker to one channel at a time to see if one particular channel causes the problem.
Oct 12, 2007 | Car Audio & Video
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
Car Audio & Video Logo
1,168 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
