Question about Whirlpool GHW9150 Front Load Washer
Whirlpool ghw9150pw1 no power?
I know this is such a vague issue, but my Whirlpool washer has stopped working completely and it's not even 2 years old yet. The wall socket works, and there is electricity, but I can't get my washer to turn on at all. Before calling someone here, I wanted to know if this issue is even fixable and if it's worth fixing? Or if possible, I can maybe fix it myself? Has anyone had similar problems at all?
I read that it may have to do with a 'lid switch' but what is that and how do I replace it?
Any help would greatly be appreciated!!!
  • 3 more comments
  • girrl Jun 17, 2008
    Oh wow. Thank you SO much for the detailed instructions. There are no
    lights on whatsoever, but I will try everything you mentioned. I really
    appreciate you taking the time to help!!
    Ok followed all of your directions and not sure what I did, but the control locked light is now on. However, when I hold down the End of Cycle button down for 3 seconds, the light will go off and nothing happens. It'll come back on if I hold down the End of Cycle button down for another 3 seconds.
    At least I got the light to come on?? Anything else I can try?
    Thanks so much...
  • girrl Jun 19, 2008
    Thanks Lumpy! I ordered the CCU today and will try to replace it. I'll post back whether that worked or not.
  • girrl Jun 23, 2008
    Ok on second note. New CCU installed, everything plugged in. The machine did click and saw/heard things moving and doing something. Then I got the --- in the display. I then unplugged it, and plugged it back in...and I'm back to where I was before. :( I hate this machine!!!!! What else can I do now except toss this piece of ****?!
  • girrl Jun 24, 2008
    Thank you for helping! Definitely still appreciate it!
    President:
  • 216 Answers
The drain spin button was accidently pressed for too long, it can lock the display controls. Hold it down for 3 seconds
Thanks .... My dad locked the washer up :() This Fixed my locked out mode ... Kevin.. Glasgow, Ky
Posted on Sep 03, 2009
I have had this same problem. Check the ribbon of wires from the front control panel to the CCU. About half way along the ribbon where it sits in the retaining clip, one of the wires is probably broken. Mine was and all I did was to solder a splice in the ribbon and now it works fine and I have a brand new CCU that I have no use for .
Posted on Feb 21, 2010
I'm back! I just replaced my CCU, plugged in my washer and I heard the click and the machine started running. BUT... now that it's stopped, I can't turn it on, on the display, I now see three lines like - - - . I'm so close!!! Do you know what this means and how I can finally get this working?
Thanks Lumpy816!!!!
Posted on Jun 23, 2008
  • 246 Answers
Given your model number, it's not going to be a lid switch. Front load washers have door latches instead. However, even a bad door latch should not keep the unit from powering up, only starting a cycle. Do you have any lights on? If the drain spin button was accidently pressed for too long, it can lock the display controls. Hold it down for 3 seconds. Did this change anything? No? Next, unplug the unit. Remove the top of the unit by unscrewing the 3 #20 torx bit screws on the back of the lid and sliding it slightly backwards. It will the lift off. You should see 2 green connectors at the top, rear of the unit. Using a volt or multi-meter, make sure you have 120 volts AC here. If you do, Next check your connections. Make sure all of your wire connections are firmly plugged into the white box in the top, middle, rear of your unit (expecially the white wires that run towards the front of the unit on the left hand side). This is the CCU (or main circuit board) connection to the display circuit board. Plug the unit back in after it has been unplugged for at least 2 1/2 minutes (this can reset a locked up board) If these all check ok, I would suggest getting someone out. To forwarn you most of these boards price out at over a hundered dollars. While you can try swapping out one of the boards on your own to see if it fixes your problem, most companies will not let you return boards once you have purchased them.
Posted on Jun 17, 2008
  • Toby Norton
    Toby Norton Jun 19, 2008
    Unfortunately, that was everything that's availible without test equipment. I would recommend either having a company that warrantys thier work come out or trying the board swap.
  • Toby Norton
    Toby Norton Jun 24, 2008
    Unfortuneately, that is all that I know of you can do without test equipment. If it were mine, the next step I would take is contacting the manufacture. Explaining the price that it cost and short life that was received, you may be able to convice them for a one time repair or even an extension of your warranty. Next, you could re-open a request for help with the same question. While I, myself am out of ideas that you can try without test equipment, there are many other knowledgeable people on this site who may have another idea. (I mention closing and reopening, because we are not able to send it back out to all of the other techs) Finnally if those both fail, I would recommend calling a well established repair comany that will warranty thier work. I'm sorry, I really wish I could give you something else to try.
Manual for Whirlpool front load washer #GHW9150PW1
Many Whirlpool appliance manuals are available here: http://www.whirlpool.com/manuals/ . Use the search function to find your model. The direct link to the manual for the GHW9150PW1 is currently http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208182674.pdf . Sears Parts Direct also has the manual; the direct link is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0606369.pdf .
I hope this helps.
Oct 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
What is Wrong with my whirlpool front load washing machine,Mod.#GHW9150PW1?
f06 relates to a motor fault....easiest fix is to replace the motor......
cheaper on ebay........cheers
Oct 13, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front-loading automatic washer problem
yea replace the ccu and the mcu more than likeley the mcu will do it tho
Jul 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hf error message
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. You can search for the meaning of the error code on the site. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Washing Machines
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
WHIRLPOOL ELECTRIC WASHER STOPPED WORKING MIDWASH BC OF OVERLOAD?
My wife did the same thing,trying to do all the laundry at one time.Even if it says high load compasity it will only handle so much.sounds like you killed your motor.Hope this helped.
For more help go to live chat.
lenwest
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Water inflow even after the cycle is complete
Seems to me that you having problem with water valve in this machine. Some solenoid on water valve is stock and water entering the washer even power is off.Water valve Part # 8181694.
Valve located on the top of the washer. Any questions let me know.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error F2
Kap, yes I have a manual for your machine. Unfortunately, FixYa has policies in place that forbid me from getting it to you through their website. You can try contacting me using my user name at hotmail, though.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
271 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
