Question about LG 42LP1D 42 in. LCD HDTV
My 42" LG LCD turns itself off
I turn on my TV on and within 5-10 seconds, it turns itself off. I can hear sound when it's on, but there is no picture. Please help!
  • 1 more comment
  • tomrus Jul 02, 2008
    My 42" lg lcd loses the picture after about three minutes, but it still has sound. The green power light will finally turn red and the tv shuts down.
  • bmorel Sep 13, 2008
    When I turn the TV on, it keeps clicking off and on continuously and I cannot turn it off. I have to unplug it and plug it back in and it will stay on. I have searched the LG website but have found nothing related to this problem.
  • Anonymous May 06, 2009
    I have the same problem, it makes the clicking sounds and turns on and off!
There is probably a firmware update on the LG website that should take care of this.Go to the downloads area and enter the model number for available updates.
Posted on Jul 18, 2008
  • ajs6088 Dec 07, 2010
    There is a safety feature on all larger LG LCDs that if the unit is to full of dust to let the fan cool properly or the fan is to full to operate at full speed the TV will not turn on it will flash green when powered on then click and go to red. I brought mine in the first time it cost $50 to get it cleaned and reset. If you are electronics sauvy its not that hard to do your self . Hopefully its that simple for you as well other wise these are all good places to start.
It shuts off 2 seconds after i power on.
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
42 in LG LCD TV turns off by itself
May 06, 2016 | LG 42LG50 42-Inch 1080p LCD HDTV
Sony Wega 42
Sounds like the bulb popped up... does it smells like there something that burned? any error light?
Apr 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Vizio E422AR firmware update problem
see if you can rollback to your previous settings. Hope you backed up before you accepted the download. That's the beauty of restore points
Feb 20, 2014 | Vizio E422AR - 42" Class 42" viewable LCD...
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
My TV turns itself off within 5 seconds after I turn it on. Whether I use the remote or turn it on manually it shuts off.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
I turn on my TV on and within 3-4 seconds, it turns itself off.
  1. Might have a power supply issue take the back off and see if there are any bulging caps on the power supply board. If you dont know what your doing call a tv service tech.
Aug 23, 2009 | LG 42LP1D 42 in. LCD HDTV
TV turns itself off after a few seconds, no picture at all
Solutions?
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Jan 22, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LP1D 42 in. LCD HDTV Logo
554 people viewed this question
Computer Repairing
Computer Repairing
